Upgrade steel rims to alloy?
Quoted: 340 Post(s)
Liked 276 Times
Riding this old Raleigh Mixte for old times sake. A similar model with drop bars was one of our first bikes 46 years ago, I recall that the steel frame always soaked up bumps and this one still does, Changed the bars/quill, all cables/sheathing, new tires, and.KoolStop pads/shoes.
The rims are rusty, between the spokes, and I had planned to polish them this winter. If I change them to alloy (I can spoke wheels) , or buy new wheels, will I notice the weight savings? It's not a light bike, but it is lighter than my newer models, and easier to pedal even at my low speeds..
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Probably the best upgrade to a bike like this.
Quoted: 811 Post(s)
Liked 1,024 Times
Nice Mixte @Doc_Wui . I agree with @dedhed that this is the best improvement you can make. You may know this technique already, get a pair of aluminum rims and the tape the new rim to the old rim while keeping the valve hole lined up and transfer the spokes to the new rim. The bike should be noticeably lighter. One thing is that you probably have 27" rims. You could get 27" rims, but the market has moved to 700C rims which are about 4mm smaller. That is assuming that you have the same diameter of the circle that the nipples will be. You may have to make some measurements to get the this to work with the original spokes. Or just get 27" rims and skip the measuring and looking up the ERD Effective Rim Diameter. \
Likes For Velo Mule:
Quoted: 1821 Post(s)
Liked 1,697 Times
Upgrading to alloy rims is a huge improvement and it isn't only about weight. In wet conditions alloy rims will still provide decent braking. Steel rims, on the other hand, pretty much provide zero braking in the wet. Even on a dry day, if you should ride through a deepish puddle, don't plan on stopping fast anytime soon
Likes For alcjphil:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
Just going to back up that any weight savings with the wheels I would buy for the bike would have minimal effect that would probably be not noticed. The ride itself would be significantly improved with a decent, not expensive, wheelset. The braking would feel like you could actually stop the bike quickly for the first time. The bike is well worth the investment.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Decent 27" wheels are not hard to find, nor are they very expensive. In fact, most of them come with 126mm freewheel hubs, so it's a straight swap for your vintage "ten-speed "
Here's a nice set from Velomine, with double -wall Weinmann rims and QR hubs, for not much more than you'd pay for the parts to re-string your old wheels
Likes For Ironfish653:
Quoted: 7653 Post(s)
Liked 3,482 Times
Biggest advantage is wet-weather braking, which is nearly non-existent. The lower weight is a small bonus.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
Do it. In the early eighties I had a Schwinn Varsity I had ridden for years. I rebuilt the wheels with aluminum rims. Best way to keep up with the fancy bikes in school.
SE Wis
Liked 3,401 Times
Likes For dedhed:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Those VM's are probably some of the nicest 27x1-1/4s you can find, and it's a sub-$150 wheelset. You can get under $100 for bolt-ons, with a little looking.
In the end, it's up to the OP to figure out the time, effort, and dollars it's worth investing into this particular bike.
SE Wis
Liked 3,401 Times
Quoted: 523 Post(s)
Liked 230 Times
Any bike that came with chromed steel wheels was probably entry level at the time it was made. I agree with the many suggestions you try to find a set of 27" used wheels. That way the reach on the brakes will match up with the rim. It doesn't look like finding a set locally would be much of a problem.
Here is one from Arlington Heights for $15 https://chicago.craigslist.org/nwc/b...542549818.html It's worth calling the owner. That's a lot closer than Milwaukee.
I would disassemble the axle set and clean and re-grease the bearings.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I’ll be that guy..
I would put zero dollars in 27” wheels and tires, longer reach brakes just don’t cost enough to make me buy in into a dead wheel size. 32/36 spoke 700c wheels can be found dirt cheap and the tires and tubes are far more plentiful. A drop to 700c will also allow bigger tires which is plus for most of us.
Before I bought anything I’d make sure the seat post came out and the bottom bracket and headset wasn’t turning to dust.
Likes For Germany_chris:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Yes, it's a far better idea to swap out the wheels, brakes, (and don't forget the cassette) so that you can run your Paselas in 622x38 instead of 630x32. Makes far more economic sense.
Seriously, the kinds of use that these 40-y/o, 2x5 27" bikes typically see, doesn't really call for high -performance, specialist rubber.
There's probably more choices for 27" tires than there were back when these bikes were new; you just can't go into any one shop and expect to find them all on hand.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
What kind of riding do you plan on doing with the bike?
Quoted: 272 Post(s)
Liked 448 Times
Here’s a thought. Change to longer reach brakes and switch to 700c wheels. I did this with an old Trek. May be a little more room for wider plusher tires.
Quoted: 340 Post(s)
Liked 276 Times
They rust like steel though. I will put some anti-seize on that post. Thanks for the tip!
Likes For Doc_Wui:
Quoted: 185 Post(s)
Liked 36 Times
I have that very same bike/year. When found, it wasn't in rideable shape, so I was doing an entire swap out of parts anyway. Long reach brakes, and put an extra set of 700c wheels on it. Standard 130 width behind, it seems to fit fine. Bike lost a bit of weight, and despite it's humble origins, is a nice, springy ride.
Likes For Craptacular8:
