Schwinn Sports Tourer question
Quoted: 243 Post(s)
Liked 172 Times
The bike is a 1971 model, it came with a Campagnolo Gran Turismo rear derailleur, which is not working.
What replacement I have for it?
I tried a Cyclone GT long cage, but it is not good also. The chain adjustable screw is not doing anything, because of the different shape of the hanger.
See the picture attached.
1992 Torelli Nitro Express; 1972 Claud Butler.
So it goes.
Bikes: A few. Quite a few.
Quoted: 432 Post(s)
Liked 639 Times
I have an ST I haven't got around to working on yet, but it has this dropout (Huret?) and came with a Shimano Crane ( Schwinn LeTour) GT derailleur.
Pohl's law: Nothing is so good that somebody, somewhere, will not hate it.
Likes For PilotFishBob:
Likes For trainman999:
Likes For rgvg:
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Another option, not popular but I like 'em, is the long-cage Allvit they used on the Super Sport. Not as good as a Crane, but better than the Campy IMHO.
Alternatively, can you say why your (OP's) Campy isn't working? Are you sure it can't be repaired?
Likes For bulgie:
Quoted: 243 Post(s)
Liked 172 Times
Thank you.
Probably that Huret washer #759 should be the solution.
It is one on ebay for 17$, from Greece, looks expensive for me.
Quoted: 243 Post(s)
Liked 172 Times
Yeah a Crane, or the Schwinn-branded Le Tour version, shifts well, fits the existing dropout, and was original equipment on some Sports Tourers ('73?)
And both red "C" are scratched badly.
It is ugly.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Liked 2,576 Times
Don't throw it away though, offer it up here, in case someone needs it for parts. Two broken derailers can make one good one if they're broken two different places.
Likes For bulgie:
Quoted: 3814 Post(s)
Liked 3,345 Times
the Campag Gran Turismo rear mech is OEM for the cycle model and year
not surprised to read it is not working
every used one which comes through my workshop has had the same problem
there is a thin sheet steel washer with a round hole out from the centre which serves as as an anchor for the spring end of the upper spring
the washer has a single pointed tooth which fits into a keyway on the gear mech's mounting bolt
the spring is too strong for this washer and strips its tooth very quickly
the part was never offered
one odd thing about the Gran Turismo rear mech is that while it got into the catalogue there was never a parts drawing
one exists however in the Schwinn Dealer Catalogue which our member @Metacortex has onhand
thought had it on me hd but seems to have vanished
spent a few minutes searching this and another forum for it without success
Likes For juvela:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Liked 2,576 Times
Sorry if I misunderstood.
SE Wis
Liked 3,401 Times
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
The Schwinn-modified Huret dropout doesn't play well with derailleurs designed for Campagnolo-type dropouts. Besides the Crane GS and its Schwinn-approved "Le Tour" version, a 1st generation Campagnolo Rally would probably work, or a Huret Duopar. Otherwise, you'll need to either modify the dropout or cobble up an adapter.
Quoted: 809 Post(s)
Liked 712 Times
The Schwinn-modified Huret dropout doesn't play well with derailleurs designed for Campagnolo-type dropouts. Besides the Crane GS and its Schwinn-approved "Le Tour" version, a 1st generation Campagnolo Rally would probably work, or a Huret Duopar. Otherwise, you'll need to either modify the dropout or cobble up and adapter.
https://www.bikeforums.net/classic-v...r-options.html
Jeff Wills
Jeff Wills
Old fart
Liked 3,401 Times
As above, this thread links to instructions on how to homebrew an adapter:
But this assumes that you're willing to deal with the resulting paint damage. If that's not acceptable for you, a compatible derailleur as suggested above is the suitable answer.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Likes For The Golden Boy:
