Brooks Saddle Revisited
Quoted: 200 Post(s)
Liked 65 Times
Sometime ago I posted an issue with my B17 saddle. One of the steel rivets is no longer flush. As time goes by it is getting worse. I emailed Brooks. They responded by saying that I should hammer the rivet. That did not work. It worked on my Brooks professional saddle that has copper rivets. I need to remedy the problem before my cycling shorts gets torn from the rivet. Any suggestions would be appreciated.
Quoted: 4211 Post(s)
Liked 3,881 Times
Look up Brian(?) Firth's "shop" that just showed at the Philly Bike Expo. He's done a lot of Brooks saddle work. Firth & Wilson Transport Cycles | Phila. PA Andy
AndrewRStewart
AndrewRStewart
Quoted: 569 Post(s)
Liked 589 Times
Is there a reason you can't drill out the offending rivet and replace? Lots of people make screw together rivets that should be close to your size, Brooks sells hammer type and screw type but only for Cambium, Selle Anatomica sells rivets and Chicago screws as do lots of other manufactures.
Quoted: 504 Post(s)
Liked 437 Times
Quoted: 1034 Post(s)
Liked 1,292 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
You need something along the lines of a rivet set to be the anvil underneath the saddle to really get a good smack down.
Probably even a piece of bar stock or maybe all thread.
https://tackstore.org/shop/heritage-...burr-setter-9/
Quoted: 455 Post(s)
Liked 112 Times
I have successfully replaced steel rivets with copper ones on 3 or 4 saddles. I bought the correct rivets from McMaster Carr. They must be annealed before doing g the work.
Quoted: 5793 Post(s)
Liked 2,593 Times
Quick check----
You do know that you have to dolly the rivet for hammering to work???
My preferred method is to stand a rounded punch in a vise. Set the inside of the rivet, then hammer on the top side.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 200 Post(s)
Liked 65 Times
Quoted: 200 Post(s)
Liked 65 Times
I am ashamed to say that I had nothing to support the underside of the rivet. Thanks for the reminder. For the price of the saddle, I should not have to come up with solutions.
I have just lost a rivet, the one at the tip of the saddle. Didn't even notice it until a friend asked me how and when it happened.
My plan is to visit one of the leather shops in the area and see if they can hammer one in. Brooks is just plain awesome, I haven't worn a padded shorts/bib in more than five years i.e. since I switched to Brooks.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Awesome guy.
Liked 1,292 Times
Remove the rivet as shown on the video, and replace it as shown on the video. You honestly are not going to flatten the steel rivet from its top, that is not how they are intended to be set. It needs to be set from the bottom whilst supported on its top. You cannot hit it on the top and expect it to stay down. The bottom of the rivet needs to be spread out as it is being set to keep the head down flush.
It is easier to remove and replace, but you can reset it if you do it right.
Liked 2,593 Times
My Brooks Pro from 1967 is still OK with something like 75k road miles on it. BITD Brooks did not peen the rivets, that became cool later, but it comes at a price, namely edges that can lift and rip shorts, but it takes minimal effort to maintain a comfortable saddle for eons.
FB
Chain-L site
FB
Chain-L site
Liked 3,881 Times
Some of us grew up with baseball gloves and made their own belts as a kid. Leather is a cool material that has some interesting qualities, age/exposure patinas. Andy (who is wearing a well patinaed self made belt)
AndrewRStewart
AndrewRStewart
