painting helmets...?
Bikes: 06 rockhopper, 2012 Trek 7.2 FX, 2013 Kink Gap XL, 2013ish Soma Saga
Is it safe putting chemicals onto the outer shells of helmets? Is there a specific paint and/or clear coat that should be used? Universally of course, I'm also going to be checking with the manufacturer of the helmet in mind before purchasing as this would just be one more helmet for special occasions.
edit: I see helmets with custome graphics so I know it can be done...Currently checking with a manufacturer of a helmet I do like...I almost don't expect to hear back from them as it probably comes off as a 13 year old looking for sponsorships.
That Huffy Guy
Bikes: Old School Huffy Bikes
Quoted: 79 Post(s)
Liked 6 Times
Painting the plastic shell part of the helmet should not be a problem, but not the foam part. Not sure what paint would be best though.
That little thin plastic shell is mainly for aesthetics. It offers little to no added protection to your head. At best it delays tearing of the foam if you slide after a crash. I don't see how paint could harm it.
apocryphal sobriquet
Water-based paints are probably OK for use since they would be less likely to damage the styrofoam but other types of paint, particularly those that contain toluene as a solvent could easily damage the helmet.
Quoted: 1572 Post(s)
Liked 643 Times
The helmet manufacturers say not to do it - but I have.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
And do you know if the structural integrity has been compromised by painting them??
There has to be a reason owners are cautioned not to paint helmets.........
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Anywhere I roam
As long as no chemicals/paint gets on the foam part of the helmet it will not effect the helmet's ability to protect your head. The reason the companies say not to do it is because they have no idea who's competent and who's not. It will void the helmet's warranty of course. I've painted the shell of a helmet before with regular Krylon spray paint and it did not harm it. That was in the days when it was still easy to remove the shell by peeling off the thin strip of tape that held it on.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Perhaps the same reason helmet merchandisers recommend replacing helmets every few years. You want another color? Buy another helmet!
Anywhere I roam
The problem is going to be getting the paint to adhere well since sanding/scuffing the helmet's shell will not be an easy thing because of its many vents with small nooks and crannies that are hard to get to. I know Krylon has a paint ,(i think it's called Fusion), which is specifically formulated to bond to plastics.
Anywhere I roam
The reason helmet manufacturers recommend replacing your helmet every few years is because the foam gradually deteriorates over time. The bike helmets of old had no shells over the foam and the u.v. rays from the sun accelerate the deteriation process even more. The shell protects the foam from u.v. rays and from minor scuffs an abrasions and looks better, and that's mainly all its for.
Liked 643 Times
Don't know. That was about 20 years ago. All I can tell you is those helmets never failed in any way and I don't remember ever crashing seriously while wearing one. I don't remember what kind of paint I used.
Quoted: 18378 Post(s)
Liked 4,512 Times
How about getting some of that 20 year old foam helmets covered by netting...
Then you could custom sew some netting.
For that matter, perhaps consider making some custom bug-proof netting for your modern helmet.
Anyway, I would tend to agree... for the thin-shell helmets, the thin plastic is mainly there to protect the foam (like the netting was 20 years ago). The foam is what protects your head, whether it disintegrates on impact or not.
I would have to question about all the TDF riders that have matching team helmets... and yellow helmets and polka-dot helmets. Are all those custom designs actually formed into the plastic, or are they just painted on?
Perhaps you could try water-slide decals.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Your forgetfulness is likely a result of suffering a crash while wearing a hand painted helmet.
Liked 643 Times
Yeah, that's probably it. My short term memory is even worse.
Liked 643 Times
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Glittery Gold...
Like Conrad Birdie in his swanky motorcycle outfit. Made Ann Margaret swoon...
Just sayin'
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
I'm guessing that along with wanting to sell additional helmets, the reason a manufacturer would discourage painiting helmets would be that the helmets as they are delivered are tested, and any change could tweak a characteristic of the helmet. If you crash with a painted helmet, and some solvent got on the foam, your heirs could sue the manufacturer... they can defend themselves well if they have a policy against painting helmets.
I'm guessing they would use the same defense with my heirs for my helmet, even though the only modification is a name sticker on each side.
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,536 Times
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Yep, just like medicine and canned food... We shouldn't eat our canned food because it expired last month, but I suspect if I threw it out, and someone found it in the land fill in 4 years, they wouldn't be able to tell the difference between it and a fresh can.
