Totally Tubular
#76
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Originally Posted by cyclodan
Not only do they exist they are the choice of the pros. But you better break into the piggy bank!
https://www.store.yahoo.com/cyclocros.../tubulars.html
#77
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
If your seriously into tubulars, the best thing you can possibly have is a LOT of old warped tubular rims hanging around. Back when I rode them, I had seven dead rims, every one storing a spare tyre.
Now that I'm about to get back on them, I gotta start looking for trash rims again.
Syke
Deranged Few M/C
Syke
Deranged Few M/C
#78
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
syke,
I found alot of old tubular rims at LBS in the back room, no one wants
to ride them and they were happy to sell them to me cheap (got
a pair clement paris roubaix tires thrown in too!). Best deal I found
were some undrilled rims for $10 a pair that I bought for stretching tires.
marty
marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
#79
Guest
Posts: n/a
Quoted: Post(s)
I do not understand the need to stretch the tire over time. I haven't used old rims to stretch the tires.
I've always been able to put a new tire on the rim without too much trouble and minimal stretching by hand while mounting the tire.
The act of stretching the tire during storage seems foolish to me as it would cause a loose fit on the rim when needed.
#80
juneeaa memba!
Quoted: 13 Post(s)
You won't stretch it that much. what stretching does, mostly, is give you a little clearance so that you don't make a huge mess on the sidewall when you put the glued tire on. storing good tubulars on a rim is also a good idea, as folded tires will eventually crack at the sharpest point of the fold. I don't have any good tubulars, so I don't worry about it too much...
#81
Guest
Posts: n/a
Quoted: Post(s)
Perhaps storing a sharply folded tire is not a good idea; but stretching during storage seems like a worse idea. It is not wise to ride on a overly stretched loosely fitted tubular tire.
A spare spoked wheel may be useful to check repaired tubular tires as the tire should not be inflated without the support of a spoked wheel.
None of my folded spare tires have cracked while stored in the seat pack.
Perhaps your tires were affected by something else; such as direct sunlight or open air and changing temperatures.
I store my new unused tires loosely across two pegs in the basement. It's cool and dry in the basement and no direct sunlight shines on the stored tires. This method has worked for years without any problems.
#82
Señor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
Originally Posted by wildjim
Per instructions the glue is left on the tire and rim about 20 minutes after the initial application to dry to a tack then the tire is mounted so there is no mess on the side wall of the rim.
From my somewhat limited experience, I've found that some models of tires are tighter than others. There's no way that I'd have been able to mount the batch of Futurox tires I've gotten without stretching them first. The way I do it follows the advice I was given by a real old-timer (a former six-day racer). I put some air in the tires (minimal pressure) and let them sit for a few days. Then, I deflate, and put them on a wheel that I'm not using, and pump them to about 40 psi. Then I hang the wheel up. The tire will subsequently lose air over time, and this is ok. Nothing bad comes of this. Think about it, the higher pressure on the tire after it gets mounted will press on all directions, holding the tire more firmly against the rim.
What are the advantages of this? Well, by "stretching" the tires, I've trained them to live with the stem pointing in, and I've ensured that I can improve my vocabulary when the time comes to actually install them. I don't have a long record of success, but I can say, "so far, so good".
#83
Guest
Posts: n/a
Quoted: Post(s)
Originally Posted by USAZorro
As with many things, there are many ways of preparing and mounting tubular tires that will work fine. I employ a stretching technique, and others don't. I'm not saying this is the right way to do it, but it works for me.
I guess everyone does have their way of doing things; but it must require at least three days before you can mount the tire with your procedure or you have a lot of tires being prepared in waiting.
As for me I put the tire on immediately and only have a few spares; mostly because I buy a few at a time if the deal is right.
All the tubular tires I've ever used mounted on the wheel with the stem pointing down properly. No training required. . .
#84
Señor Member
Liked 1,095 Times
. . . I guess everyone does have their way of doing things; but it must require at least three days before you can mount the tire with your procedure or you have a lot of tires being prepared in waiting. . .
#85
The method Zorro describes is essentially the same method that I have used over the years. It also works well for me. To me, perhaps it is becuase I am all thumbs, mounting an unstreached spare quickly and neatly on the road ride is easy with a streached tire. With an unstreached tire, it can either be neat or quick, but not both. This method has worked well for me as in 30 years of rinding tubulars I have only rolled one tire, & that was entirely my fault, not the tire's. Bob
#86
Guest
Posts: n/a
Quoted: Post(s)
Some glue gets on my finger tips but it's a small amount and easily removed.
I could maybe understand a woman or someone with small hands and lack of physical strength may not be able to mount a new tubular tire.
Maybe it's the brand of tire used. I use Vittoria CX, Continental Sprinter and Challenge tubular tires.
#87
Señor Member
Liked 1,095 Times
I don't understand all the fuss as it has always been easy for me to mount a new tubular tire on the rim.
#88
Guest
Posts: n/a
Quoted: Post(s)
I suspect it's the brand/model. I've had some that went on quite easily. My Vittorias went on quite easily. My Clement Futurox - well, they put up quite a struggle.
#89
Quoted: 15 Post(s)
Liked 9 Times
Conti Sprinters and Competitions go on quite nicely.
Prestretched Clement Paris Roubaix go on, like buttah. . .
I would imagine the Rally's could use a good stretch.
Marty
Marty
#90
When I am on the road, I don't want to be wasting 20 min. waiting for glue to tack. It is too easy not to pre-streach & pre-inflate. I think I can still pretty quick @ changing a tubular. Personally, I would rather tinker with my toys in the garage while drinking a beer & relaxing, vic on the road.
I doubt that it is the hand size/strength thing you mentioned either. While my upper body strength isn't what it was in my prime, it ain't bad either.
Different strokes for different folk. Just my $02. Bob
#91
Guest
Posts: n/a
Quoted: Post(s)
The typical recommended tubular tire glue; such as Vittoria Mastik does not dry hard as it is a contact cement designed to adhere to the glue already applied on the rim then form a bond under compression as the tubular tire is inflated on the rim. This is why I believe that stretching the tubular tire too much may deform or damage it and reduce the amount of compression the tire may otherwise have had. Barnett's method suggests that the tire may be stretched as inflated on a wheel for 24 hours prior to mounting to ease the mounting procedure but not as a tubular tire storage method.
As designed tubular tire should not be inflated without the support of a wheel as compression without proper support will damage the base tape and or rip the stitching.
Practically the tubular tire is designed ready to mount and use as the glue is properly applied to both surfaces of the rim and the tubular tire base tape. The instructions are printed on the tube of tubular tire glue.
#92
BIKE MECHANIC
Bikes: 1975 Full Campy N.R. Centurian Super Lemans,1984 Focus Vintage pre susp. mountain, hardtail,suntour xc sport, many treks, diamondbacks, and, 1950' crusier J.C.Higgins,triex (road) and kakakura silk (road)
Yes! Mike Oldfield's Tubular Bells!!
Fantastic! One of my desert island albums,for sure!
Tubulars ride so much nicer than clinchers. I just hate the glue and mess, but it's really worth it.
#93
Quoted: 15 Post(s)
Liked 9 Times
uh folks, can I remind y'all that the purpose of this thread is
to post tips for using tubulars, tricks for mounting etc.
Its express purpose isn't to debate the merit of tubulars vs clinchers,
different mounting stratagies etc.
thanks,
Marty
thanks,
Marty
#94
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,063 Times
Wahhh, my piggy bank is empty! I ditto the request for a tip on some INEXPENSIVE 'cross tubulars, if they exist. I scored a used wheelset and that plus this forum has got me interested enough to MAYBE repeal my 25-year personal ban on sew-ups and try them again on my 'cross bike...just to see. I had a bad crash years back due to the tire rolling off the rim during a crazy down-hill descent (trip to the ER), and NEVER developed the finesse to mount one without glue going on EVERYTHING...just hated it. But the idea of Tufo tape and crashing in some nice soft mud has got me re-thinking...The wheels have Clement knobbies on now, but one tire is burnt toast...is there anything out there for less than $69?? (PS, Thanks for this great thread!)
#95
#97
Bikes: Lemond Alpe d'Huez, 03 Gary Fisher Tassjara, Quattro Assi Scandium
I'm building a bike with a set of tubular rims that came on it and have some questions. It came with 2 Vittoria Nuovo Pros and a Wolber. The rear Vittoria dosent hold air and apparently was ot glued to the rim. Is there a way to fix it? I tried to put the wolber on thhis rim but it just wouldnt fit any tips? Also the front holds air but after the rear wasnt glued on I checked and made sure this one is glued on but the glue is kind of tacky and not real secure. I imagine I will have to reglue this one as well. Is there anything wrong with reuseing these tires there not in the best shape but seem allright? Thanks for any and all help you can offer.
Road: Quattro Assi Scandium w/ SRAM Rival and Rolf Echelon's
Mountain: 2005 Specialized Enduro Comp
2003 Gary Fisher Tassajara
#98
Señor Member
Liked 1,095 Times
Tubulars can be patched, but it is a bit more of a hassle, as you would need to find the leak, and apply the patch, preferably with minimal snipping and re-sewing.
Not sure what you mean by "wouldn't fit any tips?" You can re-use tires, but you're not going to get a normal full life out of them (same as anything else that's been used). As long as it is holding air, and staying on the rim securely, you should be fine.
#99
+1 on Zorro's comments. I, as the rider/end user, have succesfully patched & restitched many a tubular & gotten many more miles out of the tire befroe eventually disposing of it. As Zorro says, the trick is to try to locate the leak as well as you can before cutting the tire open, do a neat patch, restitch, & reapplication of the tape & tire. I suspect that this is much like mounting & streaching methods, different folk have different methods.
#100
Are there any detailed directions for this patching process anywhere online? The Wolber just didnt want to go on te rim no matter how much I tried about 15 inches didnt want to stay on.
