Suggestions for 2013 Allez
Hi All,
I recently purchased a fairly worn 2013 Allez Compact. I'm guessing it's 2013 because it's an 8-speed and looks identical to the images I found of a 2013 Allez Compact online (which I can't post yet)
The brakes are rusted so I need to replace those and I'd like to look at some affordable options to make this bike just a little bit better. I'm not the most avid cyclist, I mainly use this bike for short rides to work and the occasional 20-mile trip, so I don't need a complete overhaul or to have an expensive bike. My local bike shop suggested I install all new Shimano 105 groupset components but at that cost, I'd be better off just buying a new bike IMO.
if anyone has some suggestions for
- Brake Calipers
- New Cassette w/ Ratio for Flat Rides (8-speed)
- any other small things to improve the ride quality
it would be an awesome help and greatly appreciated, this is my first road bike and I'm looking forward to getting into riding!
thanks!
- Brake Calipers
thanks!
You have a few ways to look at it. Have a LBS (local bike shop) make recommendations and go with it (or try to convince them for cheaper parts). Or you can look at sourcing the pieces that need to be replaced yourself and either doing the work yourself or having the LBS install the parts. They will still charge you for the installation of course but they’ll also be able to tweak and get everything right.
But this all depends on how all of the other individual components look but you don’t have to go with the latest 105 (will that even work with an 8sp cassette?) rather you can look into the older 5700/5800 series. Or you can go down a level and use Tiagra parts instead. Tektro brakes would suffice for what you're looking to do which may be cheaper but then you’d have to pick and choose as mentioned above.
Its not necessarily cheaper to fix up an older bike but if it’s still a good frame and wheels are good then you can’t go wrong by going that route.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4392 Post(s)
Liked 3,016 Times
Hi All,
- Brake Calipers
thanks!
- Brake Calipers
thanks!
I hope you didn't pay too much for the bike. A new basic Allez is probably around $850. The brakes, cassette, and chain will probably run you $150, assuming you install them yourself. But then probably you'll need new tires and assorted other things.
Good luck and enjoy the riding.
It's not necessarily cheaper to fix up an older bike but if it’s still a good frame and wheels are good then you can’t go wrong by going that route.
I think for now I'm mainly focused on getting this bike in good working condition and throw in some small upgrades where I can. My gears were slipping so I just ordered a Shimano HG-50 8-spd cassette, an easy $25 spent. Now I'm looking at brakes, you said Tektro are fine but if I wanted to go Tiagra or Ultegra could those also fit, there are so many brake options i'm just not sure what will fit without having to drill new holes into my frame
Quoted: 643 Post(s)
Liked 1,526 Times
Out of curiosity, did the shop say why they thought you should get a complete new groupset? Was there something other than bad brakes and cassette? If the bike has problems shifting, or other drivetrain issues, changing the brakes and cassette isn't going to make it a decent bike to ride.
I guess I'd just caution that you really know what you need before you start buying parts.
right, 105 is 10-speed so its an intensive conversion. I don't blame my bike shop for trying to sell me on it .
$25 cassette, $20 chain, brakes that work.
After that, buy the best tires your budget will allow, and call it a day. Ride it until if and when you think the bike isnt doing the job anymore.
Edit: If the brakes really do work fine but just have some surface rust in spots, thats easily solvable. Naval Jelly, or some vinegar and aluminum foil will clean it up quickly.
Likes For Abe_Froman:
Liked 3,016 Times
The OP mentioned Ultegra brakes - that's not worth the expense on a 6 y.o entry-level bike, IMHO.
Likes For MinnMan:
thanks for the tip, these are Tektro Dual-Pivot I think. Do the Tiagra mount the same?
ttps://ibb.co/02VXTqZ
ttps://ibb.co/3mfb5Dz
ttps://www.amazon.com/SHIMANO-BR-4700-Tiagra-Caliper-Bicycle/dp/B01AU1D0M8
I see others have chimed in as well and I would certainly echo their sentiments here. Pretty standard setup IMO and the Tektro should work for you. You may consider posting in the Bike Mechanics sub-forum if you decide to try and tackle this yourself.
checking in a few months later and to thank everyone for their help!
happy to say since buying the bike it's finally in great mechanical condition (IMO) and rides amazing, the best part is I was able to do all of it myself with some cheap tools purchased on Amazon. Here's what I ended up doing
- Shimano Sora 8-spd Cassette
- Shimano Chain
- Tiagra front and rear brakes
- New brake and shift cables w/ housing
- New handlebar wrap
- Shimano SPD pedals
- Shoes and Cleats
- Brooks C15 Saddle
all-in-all, including the cost of the bike I spent about $800+, but $150 of that being tools and shoes. I probably could have gotten a decent brand new bike for that money but this bike now feels like my own and I learned somethings along the way.
there are a few things I'd like to do but it's purely aesthetic at this point so I'll wait a bit, but a big thing is replacing the shift levers since mine are visibly worn in appearance (but still work fine). Can I use any 8-speed shifters or do they have to be original to my groupset? which would be the Shimano RD-2300. any good recs for nice looking and affordable shifters?
thanks and once I get my new saddle delivered i'll post some pics!
- Shimano Chain
- Shoes and Cleats
- Brooks C15 Saddle
