Frame size preference.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
If you had to have one or the other would you rather have a frame one size too large or one size too small? You could do anything after to the bike to adjust it except alter the frame.
Still a very limited supply of bike sizes not to mention models. I have a bike, two actually but the wrong sizes, and I should just wait it out until supply catches up to the wait lists but I am not getting any younger.
Thanks in advance, Frank.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Quoted: 722 Post(s)
Liked 353 Times
Likes For thehammerdog:
Quoted: 569 Post(s)
Liked 585 Times
The above is my experience as well. Now in my 70s with old man shrinking disease smaller frames get the time and my 58s do not get any time at all.
Likes For easyupbug:
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Likes For Helderberg:
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Quoted: 569 Post(s)
Liked 585 Times
This seems to be my issue. I have, in the past, been able to take a size larger frame and make it work with stem and seat post. That has changed now that I am 73, pushing 74, I have found that I am not comfortable on the frames I have. I believe I need to got get a good test ride on a smaller size and possibly a more upright seated position on the bike. My drop-bar days seem to be over, unfortunately.
Frank.
Frank.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
If your arm span is longer than average, you will probably feel more inclined to go a size up. Or vice versa.
Likes For Moisture:
climber has-been
Liked 3,567 Times
Long arms do tend to like a larger bar drop, though, which is also easier to accommodate on a smaller frame.
I had the opportunity to test this out just the other day. I built up a 48 frame for my daughter, while I ride a 51. When I took her new bike out for a shake out ride I was perfectly comfortable on it with the saddle height adjusted for me and could've ridden it the whole day that way. Next week I'm going to visit my son in Seattle and he has my old Davidson which was sized the old way with a horizontal top tube vs. the current sloping ones. After I had my current bike built I felt that this bike was slightly too big even though the frame was custom built for me. I'll see how it feels.
As an aside, I'll have to visit Davidson's shop with my '81 bike. The last time he saw it, he looked at it completely puzzled because the graphics were a mix of his old style and newer ones but that was already over 20 years ago. After he built the frame, Charles Hadrann from Wright Bros. Cycles added all the components. His shop is now just down the street from Davidson's. And these guys must be old! I'm 67 and they were older than me when I had this made. But maybe not that much older since I was just 26 and anybody that was 30 seemed old at the time. Now we're just a bunch of old farts.
Likes For zacster:
Drip, Drip.
Liked 193 Times
I am 190cm, with an 88cm inseam, and very long arms. I like to ride with a bar drop on all my bikes these days. I tend to opt for longer than stock stems on my XL bikes.
So you are right, that generally speaking long armed people probably have relatively short torsos. But i still have a preference for long top tubes and stems. For reference, my E bike which came stock with a 105mm stem, has been fitted with a 150mm stem last night. I'm using swept back bars on it -
Likes For Moisture:
Quoted: 249 Post(s)
Liked 306 Times
I read on a sizing chart somewhere - I believe it was canyon? Can't remember. But they said if you are between sizes, and your arm span is longer than your height, go a size up.
Frank.
Drip, Drip.
Liked 193 Times
Rolla The way I am holding the bar now, my grip is swept back about 2.5-3cm behind the stem clamp line, at the very most. It is equivalent to having a 120mm or so stem with regular bars.
Likes For Moisture:
If you make the bicycle fit, then the frame was not a size too small or a size too large. Too large and too small are sizes where the stem, handlebars, and seatpost that you want to use do not result in a good fit. However, there are a lot of frame size finding methods out there with a purpose to help buyers find the "right" size frame to buy. If a person determines their "correct" frame size using one of these methods, what will result from buying and trying to fit a frame a size smaller or larger than the method specifies?
Buying a smaller size frame on a modern road bike (last 25 years perhaps) will probably result in a lower bar position. These bikes tend to have a low stack-to-reach ratio. Even the small sizes are long-reach compared to vintage bikes. So the most consequential result is that you'll have a low bar position, which in some cases may be desirable. It can be counter-acted with a taller steerer or stem which can become problematic at extremes but should be fine if the change is only the 1cm or so between sizes. If the frame is small enough, the seat-tube angle can also be steeper to avoid toe-overlap. This often becomes a factor with sizes below 54cm, like 51cm or 48cm and so on. It may not be a big deal, but it is a difference.
Buying a larger frame, traditionally, with the level top-tube, the problem was excessive stand-over height. The rider might have to lean the bike over to dismount the saddle or risk the top tube impacting their groin. At some point, it also becomes impossible to lower the seat sufficiently as the seat cannot be pushed below the joint with the top tube. With modern road geometry, an excessively large frame may have too much reach. If we're talking one or two frame sizes, this can be counter-acted with a shorter stem or by pushing the seat forward on the post. These actions have some consequence in the steering and effective seat tube angle.
My road bike is a size smaller than the sizing methods suggest. The result is the bars are well-below the seat and a very aggressive riding position. I read that some pros ride a size or two small intentionally. I did it only because of a good deal on a used Bianchi. I did for a while bring the bars up to seat-height with a riser stem. That worked very effectively and I was able to ride 12 hours on it without discomfort. I've gone back to the original stem to sell the bike. It's probably better this way for shorter, aggressive rides, but I ride my touring bike more.
My (vintage) touring bike frame is two sizes larger than a road-bike sizing method would suggest. Again, I got it primarily because it was available and I liked it better than other available bikes. The stand-over height isn't excessive. I can straddle it with clearance. There is not a lot of seat post showing, but the seat is at the correct height and could be adjusted lower still. Since I am using touring bars (it came with north road and I put on albatross), the reach is not excessive at all because my bars come the completely opposite direction that drop bars do from the head. So in fact, unless I was using drop, bull or tri-bars, the sizing methods would suggest a frame with too little reach.
The frame-size finding methods are useful, but they are just a starting point. You can make many adjustments, though some will cost additional parts. Knowing what you want to do to the bike and with the bike in advance of selecting the size will help.
Likes For greatbasin:
Quoted: 722 Post(s)
Liked 353 Times
my flexibility or lack there of is an issue as lifting leg over bike can be difficult on a not so flexy day...on smaller frames it is easier.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
Having relatively short legs and being long-waisted, but preferring a more-upright riding posture, I've generally found a bike that's a couple of sizes smaller (based on ST and TT measurements) works better, and can be made to fit better. But, that's me.
I'd be a stellar candidate for a custom geometry. Much shorter reach, greater stack, an appropriate orientation (of course) of saddle position to cranks.
Current bike: a 15" Trek 970 MTB, with riser stem, swept/riser bars, 165mm crank arms (probably should be 160mm) ... yet I'm ~5'9" with a longer torso and shorter-than-usual inseam. Most typical bikes have me stretched out like a 2x12, yet that's never been how I've ridden. So long as I get the saddle to crank position about right, on such a seemingly-puny bike (for my stature) I can fiddle with stem+bars to get it comfortable; whereas I can't achieve this on a typical larger, "right-sized" frame.
Of course, everyone's limb lengths, riding posture and fitness differs. But the above works well enough for me.
Quoted: 4236 Post(s)
Liked 2,949 Times
This, unless it has an unusually short top tube (or similar top tube length across sizes) and your goal is to raise the bars higher than the shorter head tube of the smaller size will allow (without all sorts of extenders).
Likes For himespau:
Quoted: 1743 Post(s)
Liked 1,281 Times
40 yrs ago when I began cycling I was 5' 10 1/2" with a 32.5" inseam. At age 76 I am 5' 8 1/2" but with the same inseam. Back then a 54/55 was perfect for me. And, that is also true today. If I had to choose between a frame too big or too small I'd go with smaller to save weight. Otherwise Pagacar will start dropping me.
Likes For bruce19:
Quoted: 249 Post(s)
Liked 306 Times
Respectfully, Frank.
Quoted: 614 Post(s)
Liked 565 Times
In a normal world, might seem absurd to imagine someone would be required to choose. From the viewpoint of "the land of plenty" and uninterrupted supply chains, it's hard to appreciate. Though, I suspect in many countries (and "backwaters") it's not altogether rare to find that only certain models and sizes are available. Effectively forcing a person to choose between having a ride and not having one. One could wait a year or two, sure, but ...
Likes For Clyde1820:
Quoted: 249 Post(s)
Liked 306 Times
I've always tended to feel more comfortable and be capable of riding in the saddle longer on a frame that (according to conventional wisdom) is deemed "too small."
Do you feel the shorter wheelbase is an issue? I have always gone up a size frame if there was a significant difference in wheelbase. I like the stability of a longer wheelbase but now, as I am shrinking with old age, the larger frame seems to cause too many other issues with my back and shoulders. I am probably between two different styles/sizes of frames and need to look into a custom frame. That said I question how much time I have left on a bike as the back surgery I had in 2001 seems to be catching up to me at 73. I might just take up walking for exercise and sell the bikes. Very frustrating. Thanks again to all that have tried to post a positive response and know I do appreciate you taking the time to respond.
Frank.
Quoted: 614 Post(s)
Liked 565 Times
Frank.
Frank.
Old injuries from running, myself. So, I'm in much the same boat with respect to how long I might have left for cycling. But a smaller frame with fairly upright posture seems to work; and a rower seems to work. Assuming the fit is "right."
I've also been considering custom geometry. Haven't yet sprung for that. But I'm sure R&E Cycles (Rodriguez) will be getting a call from me, at some point. I hear they have one with my name on it ... once we get past the custom specs, step-through frame and other doo-dads.
Quoted: 4806 Post(s)
Liked 3,932 Times
There's another aspect to this I haven't seen mentioned. (Granted, I haven't read every post.) Weight balance between the wheels. I started my adult life at 6'1/2" with long legs and very long arms. I come far forward (if the bike allows) when I stand. I also sit forward on the seat both going hard on the flat and on hairy descents. So, bikes with either short front ends or long rear ends (again, for me) will be light on the rear wheel. Any dirt on the road and I skid the wheel climbing standing. Bumpy corners on descents are scary. But a bike with a long front end and short chainstays solves both these problems for me. (Well, bumpy cornering takes some other things being right also.
So, just getting the fit right does not necessarily get me a "good" bike. I take this seriously. Before buying a bike, I measure up the frame, draw it up on my CAD program overlaid with my other frames, see what I need for stem and seatpost to get the fit AND locate my center of gravity between the wheels. For me, very few frames pass both criteria. For most it is a matter off how much "not quite right" I am willing to accept.
I'd wanted a titanium bike since I did a quick ride on a Merlin in 1990. Early auts I created a program that calculated the needed stem and seatpos plus weight balance from the specs in brochures simply to quickly see what titanium bikes were worth investigating further now that Lightspeed, Merlin and others has several models and I was in a place where I could afford a $4000 dream bike. Eye opening. $4000 wasn't going to get me a dream bike, just a "B" fit or handling. So I now own two ti bikes that do it all but I had to pay the extra k for custom.
And all this has taken me (well, one bike) down a rabbit hole. Long top tube and front end, steep-ish to get the handling I love, short chainstays all seem to add up to high speed shimmy; not a major problem 14 years ago but now in my late 60s, I'm not as strong or fearless and have become part of the problem. (I thought I was doing myself a favor by getting a bike long enough that I could ride it with a 120 stem for perfect fit. Easy to find plus every racer of my generation knows Eddy Merckx and God both rode 120s. Now I know my ridiculously long stems on my other bikes are reliable wobble dampers.)
Oh, I could solve some of the weight balance issues by simply sitting further back on the saddle. Yes. And have a bike where I have to watch how I'm riding and force myself out of the sweet comfortable place my body loves to keep the bike happy. So instead of it being "my bike", I am the bike's "rider" and I am supposed to do what it wants. No thanks. I raced a bike long ago that worked perfectly without me making any compromises. I want and expect that.
All that said, I just purchased a 40yo frame from a forumite, Japanese race bike. I know a couple of measurements, no angles. Rust and $75 so not a lot to lose. I'll measure it up when I get it, stem and post accordingly, throw some parts and wheels on, ride it and see if it's a keeper. What I do know is that I have owned two Japanese race bikes of that era that were sublime fits. Maybe this Pro Miyata will share some DNA with my old Fuji Pro. If it does, I might be riding this rusty mess a long time!
Likes For 79pmooney:
Quoted: 249 Post(s)
Liked 306 Times
Thanks again all, Frank.
Frank.
Quoted: 614 Post(s)
Liked 565 Times
... to move to a hybrid/fitness style to get a more upright position without going to a cruiser, straight up seating, as that is the worst as it stacks my spine and the bumps are brutal. I am thinking that walking is my next best idea and biking is going to be an around-the-block occasionally type of thing.
Such as:
Brooks B67 Aged saddle
Cirrus Kinekt Active Suspension seatpost
Definitely helps take the edge off bumps and judders from the road surface.
