Old Age And Stability
Quoted: 139 Post(s)
Liked 43 Times
At 74 I am just now getting back into riding after a couple of years away due to medical issues. I need to be particularly careful about falling as I am on serious blood thinners for a good while. When I last did a lot of biking it was on a Trek Marlin 7 MTB, though I had stopped riding off road and was using it mostly on MUP's with pavement or concrete surfaces. I am enjoying the Marlin again, doing just under 100 miles a week, but at a very slow pace. As I get conditioned, I am eager to increase my speed but not to the point of going back on a true road bike. I am not talking about racing or even setting personal goals on Strava, just the fun and enjoyment of a little speed and more nimble handling. I am looking at fitness hybrid bikes, but it occurs to me that among the other attributes of a MTB, they are very stable, and falls are less likely. But I could be wrong about that. I would appreciate any comments on how much less stable a hybrid, say like the Trek FX, would be. I took a Giant hybrid for a short test ride at the LBS and it seemed very stable, but it wasn't much of a test.
Quoted: 2604 Post(s)
Liked 1,934 Times
You may not like this idea, but I think you're barking up the wrong tree. Except for a few special types of bikes, they're all about equally stable (or unstable). You, the rider, have to keep the bike (and yourself) upright. So pay attention to your riding all the time, including watching the path ahead of you, any other people, pets, and bikes or cars, and drive the bike to stay out of trouble.
You might want to look at a mixte style bike so you can dismount quickly if you're getting trapped between two strollers, a dog leash stretched across the path, and a young family learning how to ride bikes. If you can slam on the brakes, stop, and step down without falling over from your current bike, that's about as good as it's going to get.
Likes For pdlamb:
Quoted: 8287 Post(s)
Liked 9,066 Times
What would you gain by switching to a hybrid? If you like your Marlin maybe you could try some lightweight slicks or even spring for some light wheels and tires?
Likes For big john:
just another gosling
Quoted: 3895 Post(s)
Liked 1,944 Times
Yes, definitely try slicks. Big difference. And also yes, bikes are all about the same in terms of stability. If you want to improve your stability and bike handing, like seriously, get a set of rollers with front guards or wheels so you won't fall off while you're learning. Something like these: https://www.amazon.com/Minoura-Foldi...dp/B00CSIYLUC/
Minoura also makes an add-on resistance unit for these...
Results matter
Results matter
Quoted: 601 Post(s)
Liked 781 Times
Use some wide pedals that provide good foot contact like old school "bear trip" version.
If you use clipped or clippless pedals and your feet/foot get stuck when losing balance then there is a much better chance of falling. Wider tires also help provide stability and better road contact to prevent slipping.
Quoted: 811 Post(s)
Liked 1,024 Times
I think you are plenty stable because we don't loose our sense of balance (unless we have a specific problem). There is always a chance of falling either because of other riders, walkers, skaters, dogs or some other thing popping up. I wear gloves anytime I ride a bike because I fell once without gloves and gloves would have helped.
You will have to weigh out the risk. I think if you stick to trails and multi-use paths you should be ok.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I cant speak for the OP, but I suspect that they may have more concerns about bike control/handling than stability and perhaps used the wrong wording. And if that is not accurate, I think handing may be a bit more important in this case.
He is already slowing down and has changed his environment he rides in which is a good start. I would visit a local bike shop if possible to see what other bike options there are or as suggested what tire options might help. A good bike fit may be in order as well.
Quoted: 139 Post(s)
Liked 43 Times
Thanks for the input guys, much appreciated. My question was not well phrased. I am not concerned about my handling skills or balance. It has been a long time since I rode a bike with skinny wheels and tires. I am thinking of a new bike for the same reasons everyone likes less weight on their bike. But until I get off blood thinners, I need to be careful about impacts and I simply can't recall how thinner tires felt with regard to close calls and sudden maneuvers. I don't think I ever thought about it before. But, thinking about a new lighter, skinnier bike got me thinking it might be a little safer to stay on the MTB. I think the tie breaker will turn out to be how great a new shiny bike looks. No sense being totally rational.
Liked 9,066 Times
I ride a skinny tire road bike most of the time. I used 23s until recently switching to 25mm tires. It has a short wheelbase, steep head angle, and stiff chassis which makes it turn quickly. I enjoy riding it a lot but when I switch to my mountain bike it's a different world. Cracks in the road, bumps, uneven surfaces can be ignored. It's actually a longer travel enduro bike but even a lighter hardtail with slicks will be calmer and require less attention.
My question in my first post was to point out that while a hybrid may be fine for your needs, your hardtail might actually be better for stability and shrugging off problems with the surface.
Likes For big john:
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 509 Times
Im 71 and have had similar concerns. But I am doing well by thinking that if things are going wrong I can always put both feet down and just stop. Like this morning on my favorite path I came across a couple with two little kids in strollers in an awkward situation. I had seen this in advance so it wasnt a surprise. I just stopped and smiled and made a nice comment. Then we all went on our way. Hope you can have similar encounters.
Likes For Joe Bikerider:
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,448 Times
If you have a date/date range for getting off or cutting back on the blood thinners how about walking until then. I had a nasty vertigo incident last year and found it easier to walk a few miles while recovering than trying to ride a bicycle. if you've got a hill nearby try walking to it, then doing a few up-and-down (or down and up!) repetitions to get a little extra workout boost. When you feel comfortable enough to get back on the bicycle you'll have a good base level of fitness. From there use your existing bicycle for a while to get used to riding, THEN move to another bicycle if you feel like it.
Liked 1,944 Times
My engineering analysis suggests that tire width is totally immaterial to one's ability to control a bicycle on the road or MUP. I mean, it's ridiculous. Tires are not rigid and even if they were, it wouldn't make a noticeable difference. The big deal with wider tires is that they are at a much lower pressure so that one does not notice small road irregularities as much. Of course that feels more comfortable. One can have both worlds, 28mm tires on wide rims on a road bike is totally a good choice - as long as they'll fit the frame. Of course this is true only on hard surfaces. On soft surfaces, more tire surface area makes a big difference in controllability and comfort..
I agree that walking is a very good choice for rehab and/or returning to the world of movement. I do a fair bit of walking, hiking, skiing, etc. I use a GPS watch which shows me minutes/mile as I go, sort of a coach, making sure I do the work.
I've been skiing Nordic this winter, partly because of the greater emphasis on balance necessary to float long on one narrow ski which is trapped in a groove. I'm a geezer, so I ski Classic Nordic.
Results matter
Results matter
Liked 1,934 Times
I think the best advice I can offer is to hit up the bike shops and test ride a few bikes of different flavors.
Likes For pdlamb:
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1254 Post(s)
Liked 1,292 Times
(I suspect a good deal of that has more to do with the types of terrain and routes one is riding on rather than any inherant balance/stability differences between the two frame types.)
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
Get yourself a good Yang-style Tai Chi video. Practice the single-legged stances and you'll never fall again.
It is my opinion that the hybrids are the least-stable of all. They try to do the job of a road bike and a mountain bike, and can be used moderately for either, but do neither well, and there is a price to pay for such dispersion. i have never ridden a bicycle in the woods, so can not speak to that.
Unless you climb the rungs strategically, youre not going to build the muscle you need to stay at the top.
The more I ride the more stable I become as a rider. As a teenager I would go up the creeks around my house and in the spring I could leap from rock to rock but the first few days after the winter I needed to go slower until I got my skills back to where they needed to be. After a hiatus with my bikes I feel the need to go slower down hills.
What counts for me is the amount of fork rake on a bike with more rake equally greater stability.
If taking any medications that can affect blood pressure or balance I would experiment to find the minimum dosage you can take without problems. I take a blood pressure medication in the evening so as to minimize any impact during the day.
Staying hydrated is also important to keep the blood flowing smoothly through the body.
Quoted: 1402 Post(s)
Liked 1,892 Times
It's been nearly 30 years since I owned a mountain bike, but I have a number of aquaintances my age and older who are still very into mountain biking...and they all tell me that falls are far more likely on MTBs than on road bikes.
but generally speaking - an MTB will be a slower and more forgiving handling bike (compared to a road bike)
Liked 1,892 Times
skinny tire road bike might be a great choice if you plan to return to spirited / fast paced road rides and similar
but it appears a fitness hybrid could be a good if not ideal choice for the type of riding you are planning to do
they can be much lighter than an off road bike - and with wider tires can also be more versatile and more forgiving
(but with narrow tires you basically can have a slightly more relaxed flat bar road bike - not bad but not ideal)
(would the fitness hybrid w / wider tires be as forgiving as the Trek Marlin MTB ? not familiar with the Trek Marlin - and it would also depend on the hybrid - but typically the MTB will be among the most forgiving types of bikes )
another option is a ‘gravel bike’ - sorta / kinda a more relaxed road bike with wider tires (and lower gearing etc)
the fitness hybrid - flat bar ... gravel bike - drop bar
Likes For t2p:
Quoted: 828 Post(s)
Liked 1,660 Times
By 'more stable' do you mean a 'less twitchy' bike?
Years ago I had a custom built Romic touring bike (I still kick myself for selling it) with lots of trail in the geometry. Even fully loaded with front and rear panniers, handlebar bag, set bag, and my tent and sleeping bag strapped to the top of the rear rack, I could easily ride no handed for miles.
With my current road bike, with very little trail, I really have to think about what I'm doing, and why I'm doing it, if I have to take my hands off the bars.
Quoted: 137 Post(s)
Liked 81 Times
My $.02 is to go test ride some bikes. There’s nothing about high bb mtn bikes that lends to confidence in low speed handling. Are you simply looking for lighter weight or a handling change? 1.75 or 42 mm tires can be light enough.
Likes For Fredo76:
Quoted: 1069 Post(s)
Liked 788 Times
3 wheel racing or off road TADPOLE or DELTA -- stability and comfort
https://www.rad-innovations.com/compare-trikes.html
Likes For OldTryGuy:
Liked 9,066 Times
Why are you posting a medical diagnosis? Did the OP ask for a diagnosis of something?
Liked 9,066 Times
Did you even read the OP? Did you read the subsequent post where he tries to clarify for those who think he has a balance problem?
He's not asking for medical advice, He does not have a balance problem. You are not a doctor yet you pull some random diagnosis out of your ass, as if you had any idea.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
He could use a trip to a couple a real doctors though. A proctologist and a brain surgeon. They could team to remove his head from his ass.
Likes For Chuck M:
