Can this seat be fixed?
Quoted: 6972 Post(s)
Liked 10,971 Times
The duct tape is a bad sign.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
I would likely just get a new saddle, the bike was not a high end bike back in the day, the saddle looks pretty toasty and you can find modern vintage saddles. Here is a great source for them: https://www.somafab.com/parts/saddles
You can also get a saddle that may even work better for your rear end that is a newer design.
Likes For veganbikes:
That's a bad accident waiting to happen, the seat comes off and the rails jab you in the butt or worse. Seriously. Get a new saddle. If you want traditional leather and durable, get a Brooks or similar, I don't recall if you can still get an Ideal. Brooks also has synthetic material that is impervious to water.
Likes For Duragrouch:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
Easily fixed with a new saddle. Broken human body not so easily fixed. I have numerous spares, I will send you one for the cost of shipping, $12-15. It is an Oval, I believe that is Fuji's brand, and is very comfortable and in great shape. I have been using it, but I just acquired one of my favorite saddles, so the Oval is being replaced. It came on a barely used bike that I bought. PM me if interested.
Likes For delbiker1:
Quoted: 92 Post(s)
Liked 20 Times
When I read last night it probably cannot be fixed I ordered this one: https://www.ebay.com/itm/173850659085
I'm pretty cautious, rode about 10 miles yesterday with it shifting underneath; 250#, 6'6". 68cm bike.
Likes For TLit:
Quoted: 5793 Post(s)
Liked 2,585 Times
Why would you want to bother?
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 92 Post(s)
Liked 20 Times
Because I'm frugal and don't throw out things that are not broken.
It looks like it worked its way out of the plastic frame; one opening to hold the "U" end and the other opening holds the two prongs; it's flexible so I'm thinking that it may be possible to get it back together.
Liked 2,585 Times
OK, that's a reason, so here's a hint.
It's like stringing a bow.
During manufacture, the frame is fixtured and flexed upward, which shortens the nose to back rail distance, allowing the top to be fitted. In use, your weight pushing down lengthens the rails, keeping the top secured.
So, your job is to improvise a way to flex (not bend) the rails up the same way so the nose can clear.
Note that if the rails are bend down where they are clamped, fitting it back together will be that much harder.
Likes For FBinNY:
Quoted: 92 Post(s)
Liked 20 Times
I've known hoarders and that is not a problem I have. "Waste not want not" is a good saying from Franklin; if things are broken and beyond repair that's another issue. In many ways our society is a throw away society, things and people....I'll go with frugal for now. I'm reluctant to get sucked into the hyper civilized society with zero tolerance for things that are not perfect or up to spec.. Appreciate the inputs.
Liked 2,585 Times
Likes For 13ollocks:
Quoted: 969 Post(s)
Liked 1,631 Times
Quoted: 514 Post(s)
Liked 450 Times
Most bike shops have a box of swap-out saddles underneath the workbench. You could ask.
Cantilever believer
Quoted: 536 Post(s)
Liked 1,841 Times
As someone who rehabilitates dozens upon dozens of saddles a year, I will say that any saddle where the rails won't stay securely attached to the pan (such as the one here) is truly and sincerely broken, and should be sent to a well-deserved retirement.
Likes For RCMoeur:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Quoted: 92 Post(s)
Liked 20 Times
The question I'd have is that these bike seats are put together in the factory with the semi-flexible plastic molded and melded together with the metal frame. Once the metal frame comes apart from it, it can't be reassembled? What happened with mine is that it came apart a while ago and there is such a disparity between the span of the mounting prongs to the metal that there does not seem to be any way to reassemble it even if had been nearly new.
Quoted: 601 Post(s)
Liked 781 Times
pastorbobnlnh
Quoted: 3514 Post(s)
Liked 2,927 Times
Quoted: 503 Post(s)
Liked 436 Times
Another possible cause is that the rails have been bent, in which case you need to bend them back before refitting the top. It can be hard to check this, although any bend in the straight parallel part of the rails is a sure sign. Also the plastic may have deformed through age, not much you can do about that..
To get the top back on I used to use my biggest flat screwdriver as a lever, and clamp a rail in the bench vise if it reaches, otherwise put a vise-grip on the rail and hold that in the vice (in either case beware of tubular or alloy rails which can be crushed or chewed up). This leaves a hand free to wrestle the top. Having checked the sockets are clear, put the front in first, then lever the individual rails into place.
If you get it well seated and it comes apart again you might as well give up and get a new one.
Likes For grumpus:
Quoted: 503 Post(s)
Liked 436 Times
I have duct tape on the nose of the saddle on my utility bike - it's still a perfectly good saddle, albeit possibly 50 years old. I could strip the leather off and use it like that, or re-cover it, but until I do duct tape protects those little ragged edges where the leather has worn through.
