What type of crankset is this?
Quoted: 4512 Post(s)
Liked 6,387 Times
Nervar?
Likes For merziac:
Quoted: 3814 Post(s)
Liked 3,345 Times
NERVAR Star from the firm Etablissements Peyrard, of St. Etienne, France
this is the first generation
it received a cosmetic revision for the 1976 model year but all parts interchange between the "G1" & "G2" editions
below is the later type -
Likes For juvela:
Bikes: 1984 Fuji Touring Series V, 1973 Nishiki Competition, 1980 Raleigh Competition GS, 1983 Trek 600, 1995 Trek 730 Multi-Track, 2010 Nashbar Touring, 2017 Velo-Orange Campeur, 2018 Stanforth Skyelander 650B
Quoted: 7 Post(s)
Liked 42 Times
Could it be a Nervar Star?
Quoted: 7 Post(s)
Liked 42 Times
Whoops, jervela and merziac got there before me…
Likes For schensted:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Definitely Nervar Star. I had a set on my first "quality" bike. Paid $20 to upgrade from the cottered crank it came with.
Sorry for the fuzzy picture, bestg I could do back in 1977
Likes For gugie:
Edumacator
Quoted: 2440 Post(s)
Liked 3,132 Times
Very underrated little crankset. Light as heck and usually very non-French compliant! Normal extraction threads too.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
since OP has the dust caps (or at least one) my 2¢ is
clean the threads with alcohol and apply a drop or 2 of LocTite (Blue or Purple) and maybe you'll always have those caps!
IMO only downside to the Nervar Star is the uncommon BCD(s) the early Gen used 122 bcd and later Gen used 128 bcd (which DOES allow use of some Stronglight rings, maybe some other FR brands that made a variety like TA?)
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Funny @gugie put them on his Super Course — me too! (not hashtag me too, just regular me too). Mine is a '71. I rode it for a while with cottered steel but when I went to work in the bike shop in '71 or '72 (I forget), my first paycheck went to a Nervar Star. It came in a display box with the matching recesses in the styrofoam liner, super classy with the cups and axle all laid out in a "buy me!" pose... Mine had been water-damaged, some corrosion on part of the crank, which is the only way I could afford it even with my employee discount, but I was super-stoked anyway.
A couple years later, Raleigh made a SC that came with Nervar cotterless, but it was steel cotterless, and the spider was swaged-on, not forged integral like the Star. I pitied the fools who bought that! Even at 14 y.o. I was a bike snob.
Liked 1,064 Times
Are you sure about that? I (vaguely) remember it opposite, that they were 128 at first, with some 122 mm ones later. 128 is close enough to use 130 rings with some filing, not ideal but do-able. 122 of course is a perfect match with Stronglight 93 and similar (49, 57, 63, 104 et al.)
Not.
I recalled there being 2 BCDs for Nervar Star and checked on Velobase, where there is some contradictory info!
But then found this entry by none other than our own Chas, and he agrees with our own Bulgie, so... end of story!
"These are the earlier model Nevar Star cranks from the Bike Boom era of the early 1970s. They take proprietary 128mm BCD chainrings. The later version from the late 70's used 122mm BCD chainrings - the same as Stronglight."
Liked 2,576 Times
- Why doesn't it have "Nervar Star" stamped into the outer face, below the extractor hole? Did it have it once but it got rubbed off?
- Does the guy in the background know his pants have fallen down? I mean no disrespect, if that's a fashion statement. Ya gotta "do you".
Liked 2,576 Times
The cap in the original pic appears to not be stamped with the Nervar name. All the ones I have (about 4 caps, maybe more) have the name stamped in. Makes me wonder if this was a "private label" or house brand crank that Nervar made for another company.
Likes For bulgie:
Likes For P!N20:
Liked 3,345 Times
@bulgie have seen other machines fitted with the G1 Star OEM where the set was like the one in the OP's image with no marking
always assumed this may have been an option at the OEM level but no hard information
Liked 1,064 Times
I also generally follow the "grease all threads" rule of thumb, except when easily lost bits are concerned such as crank and pedal dustcaps or the notorious Sun Tour barcon slotted locknuts!
I find LocTite will both "glue" the threads (but not too tight for removal when it's time) plus form a moisture barrier that prevents corrosion/galling as well as grease does. Since I started using the "low strength" Purple it has become my choice for most bicycle applications. Cleaning the threads is a critical step for LocTite (any color) so it's a bit more involved than greasing.
As with so many topics:
YMMV
Liked 5,802 Times
I was 15 at the time, didn't know squat about different cranksets, I just knew a steel cottered one was "low quality", and and wanted an alloy crankset. That's what they sold me.
Liked 2,576 Times
Likes For bulgie:
Bikes: Mead Ranger '24- Armstrong 3sp '64 Follis 172 '74 Centurian Accordo 80's Mercian '85 Mark Zeh road '86 Kona Explosif '93 Merkx Ti AX '97 Santana Arriva tandem '99 Bike Friday tandem
Quoted: 39 Post(s)
Liked 31 Times
Revisiting your photo, I have a couple questions:
Liked 2,576 Times
Here's one of mine that I triplized, "Campy style", but at 86 mm BCD for a Stronglight 99 granny.
It's 175 mm too, so a bit of a unicorn. They're out there... I have another 175 mm set too, haven't decided yet what to do with it.
Likes For bulgie:
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Liked 3,345 Times
Quoted: 601 Post(s)
Liked 781 Times
I bet you have no evidence issues if your ever audited by the IRS
Liked 5,802 Times
Well, outside of my birth certificate, this is the oldest record I have, for sentimental reasons. It's in on of those things we used to call "photo albums," if you can remember that far back.
