Packing for the airplane, with the assistance of whiskey!
Old 04-15-12, 01:27 PM
charbucks
After reading all sorts of horror stories, my fears started to centre over the idea of my bike going on the bottom of a pile of other luggage. I'm borrowing a soft case with a hefty amount of padding, but I worry about rear triangle crushing potential. I looked around the house for something lightweight (I'm dangerously close to the 50 lb limit) but strong... fortunately, we seem to acquire a lot of whiskey bottles in nice cardboard tubes!
The result seems significantly more likely to withstand a crushing load.
Here's Little Miss Surly all disassembled and ready to go in the bag. The rear derailleur is wrapped in newspaper and tucked in to the rear triangle, and the wheels are in separate padded bags. I've decided against the pipe insulation thing, as I don't really have the weight to spare and the bag itself is just as well padded.
charbucks is offline
Old 04-15-12, 02:33 PM
RaleighBikeGuy
Quoted: 12 Post(s)
Liked 7 Times in 2 Posts
Why not find a long bolt with 4 nuts and washers and install it as though it were the rear axle?
RaleighBikeGuy is offline
Old 04-15-12, 03:18 PM
LeeG
Quoted: 137 Post(s)
Liked 81 Times in 64 Posts
same with front fork
LeeG is offline
Old 04-15-12, 03:39 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 282 Post(s)
Liked 38 Times in 36 Posts
OP - they make a plastic gizmo expressly for the purpose of protecting dropouts, they weigh very little. Your LBS has some, he probably throws them in the trash every day after unboxing the latest bike.
https://www.youtube.com/watch?v=fiw6EV_8adg
Save some of the whisky for the aiport/flight, you'll need it.
seeker333 is offline
Old 04-15-12, 03:45 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times in 329 Posts
+1
We've got several of them around the house.
Machka is offline
Old 04-15-12, 06:18 PM
charbucks
I actually checked that first, but they only had front ones kicking around. I wasn't sure if it was necessary since the front fork is rotated 90 degrees and thus has much less crushage risk, but I've put one in just in case.
Noted . The best part about international flights is the "free" booze!
As to the long bolt idea, that might work if I wasn't as concerned about weight. It would also require a trip to the hardware store, and I'm lazy.
Old 04-15-12, 08:46 PM
Doug64
Doug64's Avatar
Quoted: 1182 Post(s)
Liked 833 Times in 435 Posts
You have more confidence in airport baggage handlers than I do.
Almost ready to go into a heavy duty cardboard bike box.
Doug64 is offline
Old 04-15-12, 08:59 PM
Cyclebum
Cyclebum's Avatar
Bikes: Tour Easy, Linear USS, Lightening Thunderbolt, custom DF, Raleigh hybrid, Felt time trial
PVC pipe works too. But that also requires a trip to the hardware store.
I take the rear dérailleur off.
Cyclebum is offline
Old 04-15-12, 09:47 PM
charbucks
I don't necessarily have more confidence, but I think I've got more padding and puncture-resistancy than a cardboard box. Not shown in my picture are the padded wheel bags that go between the bike and the edges of the padded case. I don't think there's much chance of the steel of the frame getting dented - my main concern is for more drastic damage that I don't think pipe insulation will protect against anyways.
My hypothesis, which is completely unfounded, is that the soft and somewhat lumpy bag won't be as attractive to stack things on top of as a cardboard bike box. It's unfortunate that hard shell cases (the only ones that Air Canada will "guarantee") add so much weight that I couldn't come close to the weight limit!
Cyclebum - when you say you take the rear derailleur off, do you mean you detach the cabling entirely? I've unbolted mine and taped it to the inside of the rear triangle, but the cables are still connected.
Old 04-16-12, 03:22 AM
Cyclebum
Cyclebum's Avatar
What you do.
Cyclebum is offline
Old 04-16-12, 04:33 AM
JimF22003
JimF22003's Avatar
Bikes: 2008 Trek Madone 5.5, 2009 Cervelo R3SL tdf edition, Cervelo R5 with Di2
The last time I flew with my bike, it was in a heavy duty hardshell Thule case. I used the plastic spacer on the rear dropouts. It came out of the box bent into a "V" shape. Fortunately the bike was OK.
JimF22003 is offline
gauvins
Touring
12
10-15-15 02:28 PM
Tandem Tom
Touring
32
05-30-15 07:46 AM
saddlesores
Touring
24
08-21-14 03:22 PM
howellhandmade
Road Cycling
9
07-01-14 10:06 AM
WalksOn2Wheels
Touring
54
01-14-11 04:12 PM
