What kind of tubes for a 27" X 1 1/4" Tire?
Old 08-18-19, 03:26 PM
peugeotclub
I recently had a flat on my vintage Peugeot. The tire states that it is a 27' x 1 1/4' tire. I'm kind of confused as to which tube I should get. From what I've been reading, the tube needs to be a 700 x 28C but I couldn't find it in the local bike store. Should I go for a 700 x 23-28C or a 700 x 35-43C?
peugeotclub is offline
Old 08-18-19, 03:42 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
1 1/4" is nominally pretty much the same as 32mm.
The wheel diameter for 700c is almost the same as 27" (only 8mm different), so 700c tubes and 27" tubes are basically the same thing.
Tubes are stretchy, so it's not a big deal to err a little small. If you can't get a 700c tube that includes 32mm within its range, I'd go with the next width down. A 700x28 tube should work fine.
It's also possible to err a bit large, but it makes tube installation more difficult. Between the 23-28 tube and the 35-43 tube, I'd go with the 23-28.
HTupolev is offline
Old 08-18-19, 03:45 PM
Cougrrcj
Cougrrcj's Avatar
Bikes: A few...
Quoted: 620 Post(s)
Liked 372 Times in 258 Posts
^^^ What he said...
Cougrrcj is offline
Old 08-18-19, 04:18 PM
Salamandrine
Quoted: 2317 Post(s)
Liked 597 Times in 430 Posts
Ideally a 25-32...
Really either way. A fatter tube like 32-43 used in a 32 can be more difficult to install without pinching it. Conversely, a smaller tube will stretch and it's not problem within reason, but you may get a few more flats from thorns and stuff like that.
Salamandrine is offline
Old 08-18-19, 04:52 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
There are 700x28-32C tubes that are also marked for use with 27"x1-1/4" tires. Here's one I found with 3 seconds of Googling: https://www.amazon.com/2-Pack-Kenda-.../dp/B017BUV1TU
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-18-19, 08:58 PM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times in 39 Posts
Your local WalMart is your friend. I get my 27x1 1/4 tubes there.
Jon
Jon T is offline
Old 08-18-19, 09:12 PM
riverdrifter
riverdrifter's Avatar
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times in 108 Posts
I use these.
riverdrifter is offline
alarsen77
Road Cycling
9
01-24-18 10:05 AM
NachosGrande
Bicycle Mechanics
24
01-22-15 12:51 PM
CuriousCurator
General Cycling Discussion
4
01-08-13 02:41 PM
Giant14
Classic & Vintage
11
11-04-11 11:32 PM
Simko
Road Cycling
5
01-17-10 09:14 PM
