Cannondale ceramic vs enduro?
I received my hollowgram crank set today and the seller told me that the bearings are not ceramic. However they are indeed ceramic, bearings have the red seals and the aluminum dust caps even have ceramic printed on them.
Anyways, I thought they were non ceramic so I bought enduro bearings before I even received the hollowgrams. Should I install the cannondale ceramics or enduro save the cannodnale ones for back up? Thanks
i doubt you will be able to tell that big of a difference between the two to matter. do keep a set as back up though.
well i have both so i need to figure out which one to install. i amleaning towards the enduro sine i heard stock cannondale ceramic bearings have a short life to them
why not just use the brand new ones
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
2000 litespeed Unicoi Ti, XTR,XT, Campy crank, time atac, carbon forks
Señor Member
Bikes: 2018 Lynskey R380 Ti | 2011 Hampsten Travelissimo Gran Paradiso Ti | 2001 De Rosa Neo Primato - Batik Del Monte, Genius | 1991 Eddy Merckx - Motorola, TSX
Quoted: 36 Post(s)
Liked 14 Times
I'd keep the crank as-is, why mess with it if it is working? Just switch out the bearing when the stock ones die out.
