Be careful with those adjustable stems ...
I just had one fail. The teeth that bind them together some how came loose under minimum pressure. A stem failure is really a bad thing, fortunately it was low speed.
Likes For UsedToBeFaster:
Not just the failure but the type of failure ...
I haven't torqued the stem in 1 month and its been solid till now.
Quoted: 4717 Post(s)
Liked 1,882 Times
What's very disturbing is the type of failure. The stem was in the Honeymooner's D$#K position (i.e. +45 degrees) nice and tightly screwed in. It failed by dropping to the Retiree's position (i.e. -45 degrees) and is STILL tightly screwed in! Go figure how that happened.
I really hate those stems.
Quoted: 33 Post(s)
Liked 21 Times
what brand of stem
lots of em on ebay and some are really cheap. the latest one from Ritchey seems bullet proof. two locking bolts; one on each side:
https://us.ritcheylogic.com/us_en/bi...djustable-stem
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
Quoted: 850 Post(s)
Liked 344 Times
Had a buddy take his first spill because of one of these on his old fuji road bike. I would never trust one of those for spirited riding, forget about 50mph descents. Stems are too cheap for me to take that kind of risk. Agree that they might be ok for short term experimentation.
Likes For colnago62:
Adjustable stems are the result of about three decades of bike manufacturers and bike retailers selling bikes to recreational cyclists with handlebars much lower than than the bike seats. I don't know how they managed to pull it off, selling bikes that did not fit their customers, but they did.
Liked 1,882 Times
Likes For Rides4Beer:
bike whisperer
Quoted: 1527 Post(s)
Liked 718 Times
+1.
I always word folks up about the dodginess and ridiculous weight, and tell them to use it to figure out what angle fixed stem they want and ditch it.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Being scared of an adjustable stem is like being scared the wheels fall off or the seat post sliding into the frame for no reason, or whatever. Im sure lots of garbage is available, but there is nothing inherently wrong with the concept, outside of possible bad engineering and manufacturing. Obviously a one piece stem is lighter and stiffer and cheaper, but its only better if it fits.
Reminds me that no one seem to care, or even praise, most wheels come with all sorts of adapters to make them fit several types of frames. Imo the same principle apply. Simple is better. A hub that is designed to fit one system, is likely to have fewer parts and have the rotor, flanges and free wheel in the most optimal place.
bike whisperer
Liked 718 Times
Disgust is more apt than fear.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
But once they know their position, why not switch to a fixed stem? Their positions can't be changing that often, and you don't usually get into track cycling with no idea of your position anyway.
