140 Ultegra disc on the front?
Bikes: Canyon Ultimate
Hello!
i was wondering if one of you here in the forum can help me. I want to install a 140 Ultegra disc on the front instead of the standard 160mm.
i have heard some rumors that it is supposedly very easy and I just need to rotate a part of the caliper??
any ideas?
cheers
Tyll
any ideas?
cheers
Tyll
Quoted: 6193 Post(s)
Liked 4,809 Times
Welcome to BF....
Read the description of each sub-forum and post in the right one. Surprisingly, many of those that can answer your question don't frequent this sub-forum as this is about fitting YOU to the bike.
Maybe a moderator will move this for you. You want this forum....
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Hello!
any ideas?
cheers
Tyll
any ideas?
cheers
Tyll
Why would you want to swap to a smaller rotor though? Is it just to match the rear? My understanding is that larger rotors = better braking. It might not be the best idea to mess with that.
the set up is universally 160 front 140 rear , or maybe 2 x 160.
front is where the effective braking is.. that why the 140 is on the back it just is not needing to be so powerful because it's being unweighted..
Quoted: 876 Post(s)
Liked 726 Times
You already asked this in the right forum and I already answered.
https://www.bikeforums.net/bicycle-m...0-caliper.html
