How embarrassing
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
How embarrassing
My Canyon had exhibited this strange rattle when going over poor pavement ever since I got it. But only sporadically; it would be quiet for weeks and then have this super annoying loud rattle all of sudden. Like a handful of loose bolts inside the seat tube or something. I had checked everything I could think of - brake pads, water bottle mount, headset spacers, peered inside the seat tube and steerer, even checked the brake rotors - nice and snug. It wasn't the derailleurs, and it wasn't chain slap. Then it would go away and I'd forget about it.
Today it was back in force. On a hunch I checked the cassette - loose and all wiggly!!! Checked the lock ring, which at least was finger tight, so felt I could finish my ride. Of course, after that I noticed the weird clunky shifting sounds, and somewhat slow shifts. How didn't I ever notice that before?
After the ride, after showering and eating something, I pulled the wheel off the bike and put it on the bench. The entire cassette was loosey-goosey, and I could make it rattle by just moving the wheel around. But the lock ring was tight... Removed the lock ring and then the 11t - and noticed the 11t was misaligned! Put it back on right and tightened down the lock ring, and the cassette is now all nice and snug. How could this possibly have escaped me for months now? Or worked reliably? Or even silently, most of the time? It's actually kind of embarrassing since I'm the one who installed that cassette myself!
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Likes For datlas:
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
(I also once tried giving a push to a buddy and nearly flung myself off the road).
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I happened upon a loose cassette when swapping to a new wheel set. I didn't realize I needed to install a spacer for my set up. But I noticed the looseness within a mile on the first ride and turned around. I'm glad you got yours figured out before causing any damage.
Likes For Germanrazor:
Expired Member
Quoted: 3657 Post(s)
Liked 5,394 Times
Likes For shelbyfv:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
No one to point fingers at here other than myself. I pulled off the original cassette when I got the bike to put it on a Kickr Core trainer and when I got a second cassette put that on the bike. Obviously I wasn't giving it much attention...
Likes For sfrider:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Another buffoon here. I too have made the bar end plug mistake. What is worse, I have made the same mistake more than once, each time convinced that my new, improved technique will prevail. Fail, total fail each and every time. Little doubt in my mind, the next time a plug wiggles loose, I’ll make the mistake again. Something, something about repeated actions and insanity.
Likes For zatopek:
Quoted: 1067 Post(s)
Liked 259 Times
Lock ring worked loose some time after initial install.
Got loose enough for the 11t to partially come off, rotate on the spline and bind up on the lock ring.
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,861 Times
Yeah, I made the bar plug mistake. Twice. Didn't fall either time, but wobbled like a drunk.
Years apart, though. And immediately after doing it the second time I remembered doing it the first time and felt REALLY stupid.
Likes For genejockey:
