What is the toughest tubular tire ?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 331 Post(s)
Liked 782 Times
I own a few vintage bikes with tubulars that I enjoy riding on relatively short (20 mile) rides. As changing a flat with these is of course a pain, what would be a “ Gatorskin” level tubular tire so I can hopefully avoid flats?
Quoted: 331 Post(s)
Liked 782 Times
Quoted: 1814 Post(s)
Liked 923 Times
I've found Continental Sprinters to be very flat resistant while still having OK ride quality.
They also hold air well which is handy for occasionally- ridden bikes.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Why not use Conti Gatorskin Tubulars?
Likes For veganbikes:
Quoted: 331 Post(s)
Liked 782 Times
Clark W. Griswold
Liked 3,958 Times
I had an ex-co-worker who got them for his TT bike and he said good things at the time and in my brief conversations on the bike when I see him every so often he is still happy.
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
If you don't care about the ride quality enough to want flat resistant tires, might I suggest the Vittoria Rally tubs? They're skinwall and are cheap enough that you could just replace them when you flat. There's also Tire Alert (a world wide web site). Have you learned the art of repairing tubulars? That's what I do. It's part of the fun...
Liked 923 Times
IME, those are not flat resistant, and not worth bothering with, especially for the OP, who wants to avoid changing tires.
Likes For woodcraft:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I don't find it a pain to change a tubular tire on the road.... as I use Tubasti and it doesn't really harden.
I can peel the flat tire off and mount new tire faster than putting a new tube in a clincher.
What the pain is fixing the tube inside the tubular. But I have actually done this as well on the side of the road when I got 2 flats in one day.
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
Otto
Likes For ofajen:
tcarl
Bikes: Roark, Waterford 1100, 1987 Schwinn Paramount, Nishiki Professional, Bottecchia, 2 Scattantes, 3 Cannondale touring bikes, mtn. bike, cyclocross, hybrid, 1940's era Schwinn
Quoted: 27 Post(s)
Liked 9 Times
I have some of the Gatorskin tubulars which I ride. My opinions based on use - I think they have a very thick sidewall, like three times a traditional tubular. This means that you get very little of that "tubular feel", but you do get a little of it. I have also found that unless I pump them up to a high pressure they feel like they drag on uphills - drag like the wheel's in the frame crooked and the tire is rubbing against the frame. That really annoys me and slows me down. My only guess is that that thick casing just isn't flexing under the extra load of climbing. I have found a way around this though. I pump them up to about 125 psi (they're rated to 170 psi). That pressure seems to eliminate the drag on climbs but makes the tire very hard. If you're only riding really smooth pavement, okay; but rougher pavement - you feel the bumps and jolts, and also the tires don't flex over the roughness, they bounce. You can sort of tell they aren't in solid contact with the pavement all the time. That really hasn't effected handling for me, but it really wears the tread off the rear wheel quickly - and the tubular Gatorskin's don't have as much tread as the clincher ones. I only ride these tires when I know I want the extra toughness. For example, it's "gravel season" on the chip and seal farm roads in Illinois. I'm riding them now - they handle the fine gravel fine (but are rough riding and bouncy because of my high pressure). Another situation is on the MUP trail after a good windstorm when you may be riding over twigs and small sticks. The rest of the time I'll ride Continental Sprinters. As a general thought I'd say don't consider the Continental Gatorskin tubular to be the same tire, just in a tubular format, as the Continental Gatorskin clincher.
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
Quoted: 702 Post(s)
Liked 671 Times
Quoted: 4791 Post(s)
Liked 3,918 Times
The latex tubed silks we used to race were.
+1 I commuted on Tubasti'd sew-ups for years. Loved that I could flat and do a fast change - in the dark, rain, snow, tired, inebriated and in shady neighborhoods. If I really needed to be quick, I didn't even have to put the tire on straight.
Ben
Ben
I must admit I don't get the point of buying the "toughest" tub. The joy of tubs really only comes with the higher end. Otherwise ride clinchers. As for changing, I am actually faster with tubs than clinchers. It is the repair that is a pain.
