Phil Wood First Gen
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Liked 108 Times
Phil Wood First Gen Hub Dimensions
Does anyone know where I can find hub measurements for a first generation set of Phil Wood hubs? They are 1976 issue, 100/120, and I'm finding conflicting dimensions online. My measurements with a 3x, 612 erd rim came out to DS 293 / NDS 296 which seem too long by a fair bit. Just looking to verify and get these wheels built so I can get the old bird on the road! Thanks in advance.
jr1244
jr1244
If you have the hubs in hand, can't you just measure them yourself?
Likes For nlerner:
aged to perfection
Liked 1,345 Times
for the early 3 piece Phil hubs I have used these dimensions with good result
special note: Some Phil rear hubs were spaced to customer request. Measure twice, cut once, as Phil himself told me in 1971
/markp
/markp
Liked 108 Times
Hahaha.... That's how I ended up here! The DS spokes at 293 seem too long as I'm lacing this wheel. I've done many sets of wheels, but never had so many problems with one set of hubs. Maybe they're cursed!
aged to perfection
Liked 1,345 Times
help us help you
/markp
Liked 108 Times
Awesome. Thank you. I will compare with mine and see where things have gone awry.
Liked 108 Times
Thank you for the offer! I'm using Sun Rhyno Lite 700c which I'm less than thrilled about, but it's all I could find in stock for both 40h and 36h drillings. The rims are 612 ERD. My rear hub is 40h and I am wanting to build it 3x to match front lacing, for which my measurements seemed spot on. Any guidance is appreciated.
aged to perfection
Liked 1,345 Times
on the rear assuming 126 OLD and 40 spokes 3 cross to 612 ERD I'm getting
293.6 for the NDS (round up to 294)
291.8 for the DS (round up to 292)
for the front 295.4 or round up to 296
Suggest you confirm the ERD - Always measure ! Do you know how to do that ? use 2 spokes 180 degrees apart
/markp
/markp
