Garmin 830 not getting texts
Liked 10 Times
For some reason I am not getting text notifications on my 830 like it is supposed to. do I need to pair it with my phone every ride if i want that to happen?
trying to figure out the fun bells and whistles..
I have one and I'm happy with it but the Bluetooth connection is finicky and perhaps that's your issue.
When I'm first about to start a ride, the Bluetooth won't connect. Opening the Garmin Connect account on my phone pairs them almost right away and they'll stay paired the rest of the ride, even if I close Garmin Connect. Perhaps that's your issue.
Randomhead
Liked 3,696 Times
Randomhead
Liked 3,696 Times
Well, that blows my theory that bluetooth problems are only on iOS
My 830 seems to upload my rides no problem, although I haven't figured out how. But it seems like it is over bluetooth through my phone. I'm thinking one of us is going to have to read the manual on how to get texts.
We're having different issues.
My 830 and phone don't always connect automatically, as they should. If I open the Connect app, it connects almost right away.
Once connected, I always get my text messages.
It seems you have a different problem. You're connected to the phone and rides are uploading but you're not getting text messages. Is that correct?
If that's the case, after your phone is connected to your 830, go to "connected features, phone then smart notifications. There you can toggle on or off the features you want to be notified about. Text, calls, social media and other. Those four can be toggled on or off. I suspect your "text" is toggled to off.
Good luck
Quoted: 3237 Post(s)
Liked 2,082 Times
Possibly the Blue Tooth Low Energy connection isn’t being made. On an iOS phone there were 2 different BT connections to the phone, from my 810, my 1000 and my 1030. The primary BT was called “Edge XXX” and dealt with the basic connection that allowed the completed track upload to the Connect Mobile app as well as Route/Course downloads to the device. The BLE connection, as far as I could determine, dealt with “live” functions such as LiveTrack and notifications as it wasn’t dependent on a button push on the device (Save) or in GCM (send to device). Garmin changed the BT connections in v8 for the 1030, they are now both called “Edge 1030”, which is just really confusing. I do see on my 1030 that almost always I have to go into the iOS BT section and do a manual connection for the 2nd BT connection in order to function. Sometimes it refuses to connect and I get no Live Track. This is the ongoing BT issue that Garmin has had going back at least 2 years with assorted devices and that DC Rainmaker called them out on and that they still have not fixed.
Likes For Steve B.:
Quoted: 18883 Post(s)
Liked 10,646 Times
This isn't an uncommon complaint about their bike computers, but everyone I know with any of their watches echos my experience that BT is 100% reliable 24/7/365. They should circle the wagons internally, figure out what's going wrong for some users, and fix it.
Well, my 1030 has recently (the time of the 1030 upgrade) not to connect well at all and, of course also not display texts which it was doing quite reliably. My phone shows the 1030 connected. The Garmin app shows it NOT connected. BTW I'm using an apple phone sofeware version 12.4.1. I'll be upgrading to ver 13 soon but Garmin has already sent an email that this upgrade is causing connection problems. In this day, with all that connects via bluetooth why Garmin has these issues. PS I also deleted and repaired the two with NO improvement.
@Jakedatc and @unterhausen any success getting your text messages?
Randomhead
Liked 3,696 Times
you're going to make me read the manual, aren't you? A friend pointed out I don't get any texts because nobody likes me. He forgot about CVS
Liked 10,646 Times
Edit: It will use Bluetooth to upload rides using your cell phone.
Good luck
Good luck
Curious if my suggestion above solved your issue.
Also, CVS doesn't like you, just your cash
Liked 2,082 Times
Well my connect problems were with GCM running. My phone showed it connected in the bluetooth settings but the GCM app showed it not connected as did the head unit. I've since upgraded the phone to ver. 13 and it seemed to connect well in the house. I've yet to ride due to a bad cold I'm trying to shake.
@Steve B. My 830 rarely connects automatically but I've learned that simply opening the Garmin Connect Mobile app will connect the phone every single time and it stays connected even if I close the GCM app. And uploads automatically too.
Having said that, take note the the new iPhone Pro with io 13.1 is having connection issues with some Garmin forum users.
Edit: There's also a beta version of 830 software available now (4.21) that says it fixes phone connection issues with iPhone 11 Here's a link
https://forums.garmin.com/sports-fit...-now-available
Expired Member
Quoted: 3665 Post(s)
Liked 5,413 Times
This is mostly beyond my comprehension but my Edge 530 instructions specifically said that the Bluetooth connection must be made via the Connect app and not through the phone BT. I left the phone (Android) BT unpaired.
For the initial pairing that is correct but you shouldn't have to open the GCM app every time for the phone to connect. It should happen automatically
Likes For tunavic:
Likes For tunavic:
Liked 2,082 Times
Note though, that even with the GCM app running, there are many reports of folks not getting notifications or having LiveTrack. The BLE connection is flaky and that’s what DCRainmaker describes in his complaint to Garmin.
Likes For Steve B.:
Liked 2,082 Times
I’m now beginning to think you need to do just that, especially if you’ve done a forced close of GCM on an iOS device. Reason I think this is I believe that notification and LiveTrack port thru the GCM app and if not running, those functions won’t work. I have to run some tests to determine this,
Randomhead
Liked 3,696 Times
so far, the requirement that the app be running checks out. I have not been running it because I find all the notifications annoying. And starting it up when I start a ride hasn't occurred to me. I did find out that my rides are not being updated through my phone. I'm not sure the app ever generates a notification that is of interest, maybe I should just turn them off.
Liked 2,082 Times
I did a quicky test. Forced close the Garmin app on an iPhone. Booted the 1030. Watched as the 1st 1030 BT was made but not the 2nd. Waited a bit, no 2nd connection. Turned off the 1030, turned On the GCM app, powered up the 1030 and watched as both BT connections were made. I mean, it seems obvious in retrospect to have the app running.
Liked 10,646 Times
This is my experience with Android and Garmin watches. It doesn't matter whether the app is running or not in terms of being able to receive notifications, or sync. There must be a background process taking care of that. Maybe iOS doesn't have/allow that?
