Why is it such a sin to use the rear brake
Bikes: 2007 Schwinn Le Tour
Yes, I understand that it is more efficient to use the front brake as it has (presumedly) more power, but I stop just fine using the rear brake and avoid the chance of getting an endo.
95% of stops in commuting are planned coasting slow downs/stops anyway so I don't need to stop on the dime. If it is a panic stop I will use both brakes anyway.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
I wasn't aware it was taboo to just use the rear brake...
Community guidelines
Bikes: Yes
Quoted: 3235 Post(s)
Liked 3,882 Times
If you aren't used to using the front brake, doing so in a panic increases your chances of doing an endo. I learned that one the hard way.
If you are used to using the front brake, you have almost no chance of doing an endo.
My Bikes
My Bikes
Using JUST the rear brake for a CONTROLLED stop is OK, if it works for you.
Using JUST the front brake for a CONTROLLED stop is OK, if it works for you.
Using JUST the rear brake for a PANIC STOP will likely not end well, i.e., across the hood of a car. (Happened to me.....)
Using JUST the front brake for a PANIC STOP will likely not end well, i.e., "dead sailor". (Happened to me.......)
Using BOTH brakes for ANY stop will almost always result in a superior stopping experience.
It's your bike and your ride; you make the call. But if you crash into me, the failed stop will be the least of your problems.
Bike addict, dreamer
It's sin because it goes against St. Sheldon's teachings (ironically, he was an atheist...)
https://sheldonbrown.com/brakturn.html
Bikes: surly cross-check; motiv triad
i think andy_k has it right. you develop muscle memory with brake control when you use the front brake. so if you never use it, then all of a sudden use it, you risk doing it wrong. i got used to using my front brake as my first brake pretty quickly and it's habit now. I still also use them in combination of course, but front brake first.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Still spinnin'.....
Bikes: Fisher Opie freeride/urban assault MTB, Redline Monocog 29er MTB, Serrota T-Max Commuter, Klein Rascal SS, Salsa Campion Road bike, Pake Rum Runner FG/SS Road bike, Cannondale Synapse Road bike, Santana Arriva Road Tandem, and others....
I generally use both brakes whenever I am stopping or slowing down, regardless of my speed and whether its from coasting or in a panic stop. The front brake actually checks my speed and the rear allow me to control of the bikes attitude. I often apply the rear slightly ahead of the front, especially in slick conditions or when in a turn, but even then I will use some front brake to reduce speed. In fact the only time I don't use the rear brake is when I am doing a stoppie (nose wheelie to you motorcycle types), and even then I will often apply just a bit of rear so that I can better feel when the rear wheel lifts off the ground.
To be honest I've never known anyone to use only the front or only the rear brake except for noobs.
Also, "panties in a bunch" is a rather sexist phrase in my opinion and couldn't possibly be interpreted as respectful for either sex.
I look it this issue with the same curiosity as issues like why it's such a faux pas (or fashion "sin") to wear sandals with socks, etc... So, I'm merely trying to pick the brains of others here to get more perspective on the issue.
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
I saw a couple of posts on here that referred to him as St. Sheldon so I just play along that theme for entertainment purpose.
I too use both front and rear breaks. Most of the time it is planned light breaking and use both or alternate. When need to stop fast, use both and even hard breaking, I do not go over the bars.
Think I have only done that once, ever. First time using a bike with hand breaks. First and only time have made that mistake. Learned the hard way, that hurt like hell.
Liked 2,571 Times
Probably why it's so popular a retort. My apologies for offending -- it just seems like there's been a lot of front versus rear brake debate (and trolling) lately. Sheldon himself acknowledged that there were times when the rear brake was the one to prefer.
I am a caffine girl
Bikes: 2012 Stumpjumper FSR Comp...2010 Scott CR1 CF...2007 Novara FS Float2.0...2009 Specialized Hardrock Disc...2009 Schwinn Le Tour GSr
It's only becomes a Sin when not using both front and rear brakes in rainy weather and non Kool Stop Salmon pads.
I'm finding it harder than ever these days to tell when people are trolling.
If i think about it, i use both brakes, but mostly I'm just covering the rear brake, i.e. hardly putting any effort into the rear brake. Mostly when just riding instinctively, I use the front exclusively. This can get you in trouble, if you don't have the learned skill of modulating the front brake.
If you do, you have better control over your stopping.
Coldfeet. If there is a topic that has been debated over and over, or asking a question that is meant to resurrect a very pulverized horse, or something in line of politics/religion in a forum where it doesn't belong, then it would considered trolling.
I have been following this forum for almost 5 years now and I have never seen any discussion in that. And my cousin who recently has got back into biking asked me the same question so I decided to "pick the brains" here.
Treating trolls online is the same as treat trolls we mean in the physical realm. If you actually answer their trolling questions well, then that would defeat their purpose of trolling. And usually their respond would be something even more outrageous in order incite new "responses". Then you can know for sure it's a troll.
I hope I have not exhibit any of the above behavior.
born again cyclist
i brake with both brakes because i find it works best for me.
i don't care what St. Sheldon has to say on the matter.
i'm an agnostic fundamentalist; religion in any form has never appealed to me.
Quoted: 18883 Post(s)
Liked 10,646 Times
* In commuting, you almost never have to stop without planning it in advance.
* In commuting, bike fit is unimportant, and might even throw you off.
* In commuting, it doesn't matter to anyone how fast you go, and you aren't allowed to care because you're commuting.
* In commuting, bike weight doesn't matter. That isn't exactly true, the heavier the better.
This could go on and on and on...
Bikes: Tons
