First Time Chain Waxer Calling on Chain Waxing Gurus
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,472 Times
I waxed my chain for the first time yesterday and installed it today, and had to re-index my rear derailleur because the chain would not shift from the 3rd to the 4th physically largest cog. I am hoping that this is a one time event and not something I would have to do every time I install a freshly waxed chain.
The chain is a Shimano Ultegra 11 speed chain, with around 300 miles on the factory grease, then mild cleaning with Dawn dish detergent and a Sonicare toothbrush, then rinsed, dried, lubed with Rock N Roll Extreme, and ridden for about 100 miles, all in absolutely dry conditions. The chain (including the quick link) was then cleaned by immersion and shaking in acetone 4 times, including an immersion overnight, and dipped into melted Gulf paraffin wax at 210 *F in a covered Crock Pot on low setting, swished a few times during the first 30 minutes to release all air bubbles. The chain stayed in the Crock Pot for over 2 hours, and chain was measured at 210 *F to confirm that it has reached the equilibrium temperature. The chain was swished a couple more times, then the Crock Pot was turned off and the chain was removed after about 10 minutes and hung to drip; I did not wipe the chain as I was removing it from the wax. The chain was stiff with wax so I ran it around a breaker bar to loosen it and shed the biggest wax chunks prior to installing it onto the bike.
Am I doing something wrong? Thank you.
Quoted: 33 Post(s)
Liked 21 Times
sounds like you're doing it exactly right
but what a giant pain in the arse. I was into waxing for a couple of years and realized with a quick link I can remove the chain any time I want, clean it, and re-lube it without a a crock pot. I think NFS is a great lube product and I absolutely never ever miss waxing. I do love a clean chain though.
Quoted: 696 Post(s)
Liked 910 Times
I don’t know if your doing something wrong. I recently waxed a new 105 chain and put 178 miles on it so far. Hopefully the adjustment wasn’t related to changing lubrication method.
Jedi Master
I think you are leaving too much wax on the chain. I hang the chain on a hook and wipe off all the exterior wax with a rag while the chain is still hot.
Likes For kingston:
Quoted: 20810 Post(s)
Liked 9,456 Times
When was it doing this - well in to your first ride?
Even after you break the chain, after cooling, it's still going to be a little stiff and the shifting may be a little off/sluggish. This usually only lasts a few minutes. No adjustments should be made to the derailleurs.
Likes For WhyFi:
Liked 1,472 Times
Liked 1,472 Times
No, the issue happened when the bike was mounted on the work stand.
Thank you. I will keep that in mind for the next time.
Liked 1,472 Times
Liked 1,472 Times
After a first test ride of only 23 miles, the chain and drivetrain are much dirtier looking than expected, but at least nowhere as greasy as with lube. I suppose the 4x acetone wash did not clean the chain sufficiently. We will see how many miles before I have to wax the chain again.
Quoted: 768 Post(s)
Liked 1,746 Times
might I suggest Squirt lube....much, much, much easier that all of what you went through.
Liked 1,472 Times
Smoove-Advanced-Guide.pdf (zerofrictioncycling.com.au)
You are saying it is much simpler in practice?
Use a chain oil on the connecting link.
Quoted: 768 Post(s)
Liked 1,746 Times
Really? I understand Squirt is similar to Smoove, for which Zero Friction Cycling has very daunting application instructions, including similarly stringent cleaning steps:
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Likes For jaxgtr:
Quoted: 768 Post(s)
Liked 1,746 Times
Never used smoove, but that seems a little excessive based on that link.
Quoted: 4560 Post(s)
Liked 2,802 Times
The tricky bit to waxing is completely stripping the original lube. That's why some folks resort to risky stuff like gasoline as a solvent. (Please don't do that.) Others use ultrasonic cleaners with safer (read: non-combustible/flammable) solvents.
Last year I misplaced my waxing setup. Had to clear out my apartment temporarily on short notice so they could install new flooring. Never could find my waxing setup, crock pot, etc. Probably buried under a stack of boxes in the closet.
So I tried Rock 'n' Roll Absolute Dry and Gold. Reportedly both use naphtha and PTFE powder ("Teflon"), with Gold adding a bit of light oil lube. Both run very slick and reasonably clean, even the Gold despite the addition of a bit of oil. The Gold lasts longer per application and runs quieter. So I've stayed with RnR Gold for more than a year.
I don't use RnR lubes as they recommend. Instead of pouring it on liberally, I use a needle dropper and apply about a dozen drops randomly just before every ride, starting with a clean but not degreased chain. Eventually it distributes to the entire chain. So far, so good. Applying it as RnR suggests will go through a bottle very quickly and can get expensive.
My only gripe about wax was it never lasted long per applications. One or two rides and the chain would sound jangly again. While chain noise isn't necessarily a good indication of friction, it was hard to tell when the chain needed to be rewaxed. I usually rotated two or three identical chains every 200-400 miles or so, depending on weather, noise and whim.
Last year I bought some powdered PTFE (took a few weeks to ship from China). I plan to try homebrewing my own "dry" lube using PTFE in solvent. I doubt it'll be any better than RnR Absolute Dry or Gold, but might be a little cheaper.
Liked 1,472 Times
Loads simpler. You just need to make sure all the factory or oil based lube is gone, then apply this stuff. Reapply every 300 miles give or take, if you get caught in the rain, just check it to make sure if you need to reapply. Can't be any easier that. No crock pot needed. The initial cleaning was the most effort, took a few trips through the de greaser and a little scrubbing, but once I got through that, and you apply squirt, when I need to reapply, I can just wipe it down with a rag and reapply. No muss no fuss. After you do the initial cleaning a trip through some denatured alcohol is a good thing as well. Dries off very quickly.
Liked 1,472 Times
This is the part I am not accomplishing.
There is a low VOC version for California so I doubt that the solvent is naphtha, given that naphtha is not available as a solvent at any of the home improvement stores. I used Rock N Roll Extreme before and applied only a drop per chain roller, both preceded and followed by backpedaling and wiping. Within a 100 to 150 miles the chain would develop the greasing black paste, which is why I want to try waxing. If waxing does not work out I will probably switch to Rock N Roll Gold.
Quoted: 768 Post(s)
Liked 1,746 Times
Once the chain is dry, put it back on the bike, put a drop per roller, let it dry for 20 mins, repeat. Let it dry over night, you are ready to ride. When it is time to reapply after 300 miles or so, grab a clean cloth, wipe the chain, add a single application of Squirt. and you are good. There have been times where I only needed to apply around 500 miles, so it depends on the conditions, did you get caught in the rain, etc. Once you get the feel for it, you know when you need to reapply.
Liked 1,472 Times
Last time I put my bike chain in straight Purple Power degreaser, put it on top of the laundry machine to agitate, then left it overnight. The chain was pretty clean, but then it had a broken link fairly soon afterwards due to hydrogen embrittlement. So I am a little wary of using a citrus degreaser on a bike chain.
Quoted: 878 Post(s)
Liked 726 Times
I didn't have good luck with Squirt, and I have reason to believe ZFC when they say it's actually not that great unless you can work it into the chain, which takes a very long time. My experience was with a new chain that I thought I cleaned thoroughly with OMS and denatured alcohol, but with Squirt the chain gunked up after every ride and was noisy within 50 km despite repeated application (nearly the entire bottle). I have a lot less fuss using NFS, but now I'm trying Silca's new wet lube because I also have no confidence that a wax-based lube works for me without a pristine new chain.
Likes For surak:
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Quoted: 1186 Post(s)
Liked 289 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
Can't buy a gallon of Coleman Fuel in California? Now, I understand the campfire cooking on the Pacific Crest trail.
The best way to get rid of the factory lube is to first ultrasonic it with Simple green, water. Then, one or two soaks in wide mouth plastic juice bottle filled with white gas aka naptha or Coleman fuel. I shake and then let it sit. I let it dry. I start up the crockpot. Put the chain in there for an hour or two. Getting the wax into the chain links and pins is not that easy. When I remove it, I lay it flat and "blow dry" off the excessive wax pin by pin using a heat gun on a lower setting. After 200-250 miles, I will apply Smoove or Squirt, to each roller and pin. After around 5-700 miles and if the chain is not dirty, it is removed and put directly into the molten wax. I rarely strip it again.
Jedi Master
I put the chain on top of the cold hard wax when I turn the crock pot on low and come back later to fish it out. There's really no reason not to leave it in there for a while so the wax has a chance to get into all the pins and rollers. A hot chain also makes it easier to wipe off the excess wax.
Likes For kingston:
Liked 289 Times
