Home Depot substitute for brake cable end crimps?
Quoted: 206 Post(s)
Liked 38 Times
If I want a few end crimps for brake/shifter cables, what's a good hardware store-available substitute rather than having to get a package of proper bicycle cable crimp ends off ebay etc?
Thanks.
Thanks.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
You could solder the end of the cable to keep it from fraying.
Or just get some on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$7
$7
Quoted: 2604 Post(s)
Liked 1,933 Times
My friends at my LBS often gave me a few before I bought my own bottle.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
$7
$7
Likes For hokiefyd:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Heat shrink tubing?
Likes For Rolla:
Quoted: 2338 Post(s)
Liked 2,827 Times
there is no good substitute and I have had no luck with soldering stainless even with flux
some things are not worth mucking around with
Likes For squirtdad:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
But personally I use crimp ends. Too much bother
Liked 3,443 Times
I am worse at soldering than I am at bar taping.
100 of those thingies for $7 is a lifetime supply for me (especially since the primary ride is Di2).
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Liked 2,979 Times
https://www.basspro.com/shop/en/bass...t-shot-weights
1/50oz is about the smallest I've seen at a local sports store.
-Oh Hey!
-Oh Hey!
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 6196 Post(s)
Liked 4,811 Times
I've gotten crimp ends from every bike shop in my area at one time or another. Some gave me a couple free since I was buying other things at the time. Another charged me a dollar for four. Probably not worth the time or cost of the paper to print the receipt. But it sure beat having a container of them lost somewhere in my shop and having to go to the bike shop to get some till I can find my seldom used and lost container of them.
Likes For Iride01:
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
I used to ride with a guy who crimped old spoke nipples to the end of his cables.
Having said that, a drop of super glue can also hold the cut end together well.
However, I use the right part for the job - cable end caps crimped on. Why mess around with anything else when the simplest solution is right at the LBS?
I like cats.
I welded a cable end once just to see how easy it was. My welder is lift-arc and it was annoying difficult to get my arc started because, you know, it's a flexible cable. I think I used the lowest possible amperage for the shortest possible time and it worked a treat. Obviously not in any way worth the trouble.
Likes For ericoseveins:
Likes For Jean_TX:
Guest
Liked 3,270 Times
Likes For Rolla:
Sr Member on Sr bikes
I use 3/32” heat shrink tubing for cable ends.
Dan
Dan
Likes For Camilo:
Quoted: 1109 Post(s)
Liked 1,200 Times
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times
Pop rivets
Since I have a supply of these in aluminum, I’ve used them. The solid actuating pin slides off. IIRC 3/32 but measure, my memory is fading fast.
Likes For SkinGriz:
Bikes: Litespeed, O'Brien, Specialized, Fuji
Quoted: 18 Post(s)
Liked 15 Times
I'm in the heat shrink camp. I've even been able to keep the heat shrink on the cable after pulling it through the housing. A Bic lighter to shrink it.
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Maybe just go down to your local shop and they might just give you a couple. No need to faff about trying to find alternatives to something that does not need it and wouldn't benefit from something different.
Likes For veganbikes:
