Bike Pump Recommendation
Please advise on bike pumps that you use. Looking for easy to use for Schrader. Electric, Foot, or whatever style that works well and is not hard to release. I've gotten rid of the nice looking, but PITA Wally World pump and need to get a good one for the bike.
Thanks!
Thanks!
Quoted: 18424 Post(s)
Liked 15,580 Times
Transportable as well?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I've got a $60 Blackburn floor pump that's been reliable for years. Buying now, I'd get one with a chamber for seating tubeless tires, but you might not need that feature.
Likes For Rolla:
Quoted: 6196 Post(s)
Liked 4,811 Times
I bought a cheapo $10 Zefal floor pump at Walmart circa 2005 - 2009. It's still pumping up my tires every other ride. I did replace the air chuck and hose about 2017 for another 4 bucks.
Quoted: 1034 Post(s)
Liked 1,292 Times
I use a Specialized floor pump. I bought it in 2011 and use it for everything, including the cars and motorcycles. It works well. It can be used for Schrader and Presta valves.
Likes For phughes:
Quoted: 314 Post(s)
Liked 683 Times
I've got a Topeak track pump, not sure on the exact model name but it was around the middle of their price range of pumps. Does the job, but the pump head could be improved.
Also got a USB rechargeable FUMPA electric pump.
It's totally and utterly unnecessary but does a fantastic job. Digital gauge is nice. I mostly use it for travel when taking a larger/heavier track pump isn't always the best option.
I had a Park shop pump for many years. Unfortunately I left it behind when I moved to Japan. An LBS here was selling Park floor pumps, I bought one and it broke in a week (it was made in China). A good Blackburn or Topeak pump would be great.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I bought a Bell pump five years ago at Academy Sports, and it's always worked well for me. Inexpensive, and does the job.
Liked 15,580 Times
Likes For indyfabz:
Quoted: 506 Post(s)
Liked 639 Times
Silca Super Pista. Mine is well over 30 years old. It has a reputation for an accurate gauge, good stroke volume, and easy to find replacement parts. You would have to get a Schraeder head because it is designed with a Presta head.
Likes For KerryIrons:
Quoted: 1944 Post(s)
Liked 2,164 Times
I’ve got an SKS Rennkompressor for higher pressures. And I have a Spin Doctor Essential that is no longer available.
I’m not sure who made the Spin Doctor pump, (Performance made none of their house branded products) but the head is a great design. Instead of a top clamp lever, it has a side clamp lever. This is a nicer approach than flipping a top lever to remove.
I also like pump heads with multiple fill ports.
John
John
Have been utilizing the same two Lezyne floor pumps for probably 20 years now,
one is a regular floor drive, the other a compact travel drive [often keep this in the car].
These have worked well....
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I'm sad that I didn't learn about the SKS Twentyniner in time to buy one before they got discontinued. Since I don't use high pressures, it would have been perfect for my needs.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Quoted: 236 Post(s)
Liked 196 Times
I use this Ryobi model, it works well. Pull the trigger until the pressure is just above your target.
I already had other Ryobi tools using same battery. If you don't, then it might be a little pricey.
https://www.homedepot.com/p/RYOBI-ON...737D/307627867
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 395 Times
I bought a Planet Bike floor pump back in 2001. It still works as great today as the day I bought it. The model is Verse Air. I pushes air in both in the down and up strokes. It also has both Presta and Shraeder fittings.
Quoted: 421 Post(s)
Liked 379 Times
Ha! I came here intending to ask this same thing, and you beat me to it. I suspect my pump is dead (either that, or *both* my tires are). It was a cheap-ish pump, no-name brand, so I'm guessing not fixable (though I'll certainly have a look to try. I'm thinking it's possibly the head... I was having clamping issues when trying it.). Are there pumps that are repairable? I hate having to throw things out for a minor part that's gone bad, so it'd be great if my next pump isn't kaput when it stops working. Are there any good pumps around $50 or below, or am I going to have to shell out more?
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 191 Post(s)
Liked 603 Times
I've been using the Lezyne steel floor drive pretty daily for about 9 years. Only had to replace the chuck once a couple years ago. One caveat, you have to be okay threading the chuck onto the valve stem, as it has no spring loaded lever to attach.
I went with a higher-pressure model from them, and have been positively impressed by the design/fit/finish.
Likes For John Valuk:
Lezyne also sells a "Dual Valve" lever-lock chuck with connections for both Presta and Schrader. I bought one, and it worked as expected, but I decided that I preferred the thread-on ABS-1 Pro chuck.
Liked 2,568 Times
I don't own one myself, but when I was shopping for a floor pump a while back, I noticed that Lezyne has some "gravel" pumps (larger barrel; nominal 100 psi max).
RUSA #7498
Originally Posted by noglider
I like my Topeak D2 SmartGauge for measuring pressure and adjusting with the bleed valve, but I thought that I might prefer to be looking at an analog gauge while pumping up a tire, as it's so easy to see what's going on.
For the high pressure pumps, Lezyne makes decisions a little bit complicated by offering a lot of variations - which can be as subtle as whether the hose has a braided cover or not, or if the couplings on the hose are metal or plastic. I haven't seen a comparison matrix for them, but it would be nice!
For their gravel pumps, there are only three - so less choice. If you want the metal base, for example, then you have to get one with an aluminum barrel and a digital gauge.
