Possible to replace rear derailleur bracket plate?
Old 11-17-23, 12:54 PM
Paradox77
Quoted: 32 Post(s)
Liked 7 Times in 4 Posts
Hi folks,
I am currently using this bracket plate that came with the bike but the "sleeve nut" or whatever it is called has a 1.75mm pitch thread. I am unable to find a suitable thru axle that fits perfectly especially because of that thread pitch. I am looking for a quick release 12x142 1.5mm. (actual thru axle length is 160mm).
I have attached a picture of what mine looks like now and wonder if I can just replace the "sleeve nut" (is it machined pressed in?) or do I have to buy a new bracket plate?
Paradox77 is offline
Old 11-17-23, 01:23 PM
Eric F
Habitual User
Eric F's Avatar
Quoted: 4957 Post(s)
Liked 8,099 Times in 3,833 Posts
The "bracket plate" part you're talking about is called a "derailleur hanger." They tend to be specific to the bicycle, and probably won't be available with a different thread pitch.
A better solution would be to use the correct size thru axle. Try here... https://robertaxleproject.com/axle-f...hoCar8QAvD_BwE
Eric F is offline
Likes For Eric F:
Old 11-17-23, 01:25 PM
Bald Paul
Bald Paul's Avatar
Quoted: 825 Post(s)
Liked 1,659 Times in 784 Posts
Bicycle Thru Axle Finder 100% Guaranteed! - The Robert Axle Project
Whoops, beat me to it.
Bald Paul is offline
Old 11-17-23, 01:26 PM
Paradox77
Quoted: 32 Post(s)
Yeah I contacted The Robert Axle Project already and they don't have the size I am looking for.
Old 11-17-23, 01:43 PM
Eric F
Habitual User
Eric F's Avatar
Wow. What is the bike? Contacting a dealer (or the manufacturer) might be your best bet, in this case.
Eric F is offline
Old 11-17-23, 01:46 PM
Paradox77
Quoted: 32 Post(s)
Its a Canyon and their customer support is horrible so I rather source it myself. Canyon just seems to put parts that are ODD sizes on the bike which you can't find replacements for. Same thing with my wife's Canyon bike, can't find parts for it as it is odd size.
Old 11-17-23, 01:50 PM
Eric F
Habitual User
Eric F's Avatar
Damn. I wish I had some other help I could offer. I'm running into the same dead ends you probably did.
Eric F is offline
Likes For Eric F:
Old 11-18-23, 06:46 AM
MattTheHat
MattTheHat's Avatar
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times in 1,430 Posts
I’m not sure of the quality or even how the adapters work but this might work. Edited to add that the threaded portion is held on with a machine screw. I’m not sure how strong that’s going to be.
https://www.amazon.com/RapiLock-Road...DGH&th=1&psc=1
MattTheHat is offline
Old 11-18-23, 06:49 AM
MattTheHat
MattTheHat's Avatar
Quoted: 762 Post(s)
Many more options here. https://www.modernbike.com/1.75-thru-axles
Old 11-18-23, 07:37 AM
Paradox77
Quoted: 32 Post(s)
Originally Posted by MattTheHat
Thanks for listing them. I also went to modernbike.com before however I didn't find 160mm length shafts. I will keep looking though.
Old 11-18-23, 08:05 AM
MattTheHat
MattTheHat's Avatar
Quoted: 762 Post(s)
They show a few at 166 or 167. If that’s all I could find I think I’d shorten it with a file. Or if you know anyone with a lathe, it would be really easy. Course, you’d have to blacken the machined end. Either aluminum black or even paint would work.
Likes For MattTheHat:
Old 11-18-23, 08:09 AM
Bald Paul
Bald Paul's Avatar
Quoted: 825 Post(s)
Remind me never to buy a Canyon.
Oh, you just did!
Likes For Bald Paul:
Old 11-18-23, 12:28 PM
Zaskar
Quoted: 479 Post(s)
Liked 277 Times in 156 Posts
The Canyons I have and have worked on all have M12 x 1.0 thru bolts. Which Canyon are you working on?
Zaskar is offline
Old 11-18-23, 02:01 PM
MattTheHat
MattTheHat's Avatar
Quoted: 762 Post(s)
My Endurace had DT Swiss axles in 1.0 IIRC. The pic even looks more like a 1.0 pitch, but phots can be deceiving.
Old 11-18-23, 02:13 PM
Paradox77
Quoted: 32 Post(s)
Specs are in OP.
Old 11-18-23, 02:15 PM
MattTheHat
MattTheHat's Avatar
Quoted: 762 Post(s)
Just coming to back to say this probably is more involved than just shortening. You’d almost certainly need a matching tap to extend the threads further back down the axle too. Not impossible to do but without the original axle to compare, it would require a lot of trial and error.
Old 11-18-23, 08:07 PM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 271 Post(s)
Liked 447 Times in 266 Posts
Did you try and enter your bikes serial number On the Canyon parts finder site.?
https://www.canyon.com/en-us/gear/co...re-wear-parts/
There is also a chat function for help. Also an option is to find a die to chase the threads on the axle. Or get a thread repair file. For my first thru axle bike I messed up the rear axle threads. They are aluminum so were easy to clean up. I did buy a new axle from Trek. And put some grease on the threads. The fixed axle is now my spare.
Last what Canyon bike do you have. Model build level and year. May be someone here that could help if more information provided.
biker128pedal is offline
Likes For biker128pedal:
Old 11-18-23, 09:44 PM
Kontact
Kontact's Avatar
Quoted: 4412 Post(s)
Liked 1,566 Times in 1,028 Posts
They do that on purpose to discourage bike shops from providing service and parts.
Which is weird.
Kontact is offline
Likes For Kontact:
Old 11-18-23, 09:47 PM
jadmt
jadmt's Avatar
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times in 849 Posts
what canyon model? I agree Canyon does not have normal replacement parts. I would never recommend them cs is terrible trying to locate spare parts.
jadmt is offline
Old 11-18-23, 10:13 PM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,026 Times in 723 Posts
The very first one in the link might not need any real effort. At 167mm its only 7mm too long but that still leaves 13mm or a smidge over a half inch of threads before the axle bottoms out on the frame. None of the frames I have are a 1/2" thick at the dropouts, especially when you realize its recessed slightly to help hold the axle in place.
Russ Roth is offline
Old 11-19-23, 07:56 AM
biker128pedal
Quoted: 271 Post(s)
Wolf Tooth makes a 166mm and 167 mm. Saw them on Jenson. Odd only 1 mm difference. I’d by the 166 and see how it fits. May just stick out a little. Sh but a reduced aero efficiency. But if annoying. Find a friend with a lathe to turn it down. Then paint or use gun bluing to darken.
https://www.jensonusa.com/Wolf-Tooth-Rear-Axle
OP. Odd that a search shows Canyon using a 1.0 pitch rear axle. I’d think they’d use one pitch.
https://www.canyon.com/en-us/canyon-rear-thru-axle/169265.html
Old 11-19-23, 08:05 AM
biker128pedal
Quoted: 271 Post(s)
Hi folks,
I think you are measure axle incorrectly. The length is overall not under the bolt head.
Also all the Canyon thru axles appear to have 1.0 pitch.
I think you are measuring correctly but the sellers use overall length.
https://www.thruaxle.com/how-to-measure.php
Old 11-19-23, 08:22 AM
jadmt
jadmt's Avatar
Quoted: 904 Post(s)
https://www.canyon.com/en-us/canyon-...le/169265.html
I looked up the hanger part number he is showing and that is the same as is on my Endurace CF8 and my thru axle shows M12X1 printed on the axle. the part number on the thru axle is GP0235-01
jadmt is offline
Likes For jadmt:
Old 11-19-23, 08:49 AM
Paradox77
Quoted: 32 Post(s)
This is my original axle.
Likes For Paradox77:
Old 11-19-23, 09:22 AM
biker128pedal
Quoted: 271 Post(s)
Might be this one from DT Swiss for Canyon. If their picture was better one could read the marking.
https://www.canyon.com/en-co/gear/bi.../10011749.html
I could zoom in and the part numbers don't match.
