3 needle-nose tool? for 6400/01? freehub
Old 03-25-24, 07:00 AM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 91 Times in 75 Posts
Attempting to break down the freehub.
After removing the axle and looking down the freehub, I can see the large ten ball bearings.
On the outside of here and slightly higher there is a ring shape with three small pinhole size holes spread like three points of a triangle.
RJ The Bike Guy has a freehub overhaul vid where he uses a homemade 2-hole tool to unwind a similar position ring.
Mine is definitely a 3-point/hole.
Any ideas what tool would be used for removal?
tangerineowl is offline
Old 03-25-24, 07:09 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
Are you looking at the dust cover? I think you just use a hex key and remove the fixing bolt. Then pull on the free hub body and it should be off.
Shimano FH-6400 or FH-6401? Or is this some other brand since you said it was 6400/01?
A pic will help us know what you are seeing.
Found the SI's..
FH-6401 https://si.shimano.com/en/pdfs/si/T-...000-00-ENG.pdf
FH-6400 -7 and -6 https://si.shimano.com/en/pdfs/si/R-...000-00-ENG.pdf
Iride01 is offline
Likes For Iride01:
Old 03-25-24, 08:20 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
If you're really inclined to disassemble the freehub you could make a tool like RJ but with 3 prongs.
dedhed is offline
