Stripped Crank Arm
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 58 Post(s)
Liked 31 Times
Stripped Crank Arm
An unnamed knucklehead stripped the threads on my Alivio crank arm (square bottom bracket).
Does anyone know any good tricks for getting it off, or am I going to have to resort to a bandsaw?
TIA, Mike
TIA, Mike
Cantilever believer
Quoted: 536 Post(s)
Liked 1,844 Times
I feel for you. I've lost a crank or two that way, even after stopping and using lots of penetrant after the pulling got hard. Sometimes the crank threads lose the battle - even sadder when it's a rare and valuable old crank you wanted to save.
I've tried a jaw puller, but with 0% success. What has worked is multiple cuts with an angle grinder, working carefully in case you want to salvage the bottom bracket.
Likes For RCMoeur:
Really Old Senior Member
https://www.harborfreight.com/16-in-...iABEgIRmvD_BwE
Of the appropriate size-
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Often, removing the mounting bolt and riding around the block a few times is enough to work the arm loose. Don't go too far from home/shop, as once it gets loose you'll want to stop riding and walk back, or risk ruining the crank arm. There are kits to cut new threads into stripped arms; too costly for a one-off job, but perhaps a local shop has one.
Likes For JohnDThompson:
Quoted: 4211 Post(s)
Liked 3,880 Times
One trick is to go ride the bike with a crank arm retaining bolt only finger tight. In time the crank will come loose and the bolt will keep it from falling off the bike while you limp home. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 5793 Post(s)
Liked 2,590 Times
Back the bolt off half turn from tight, and do sprint intervals near home. The arm will come free with an audible pop.
If that fails, leave the bolt off and join some friends on a century in the Poconos. (based on experience)
Otherwise, buy a pair of #6 Jacob's Chuck wedges for a few dollars.
Likes For FBinNY:
Quoted: 506 Post(s)
Liked 639 Times
Liked 2,590 Times
Likewise, tapping new threads, would mean a larger size for which you'd need to seek a non-existent remover.
HOWEVER - if one ops to use Jacob's Chuck wedges, the crank can be reused and removed the same way as often as needed. Likewise, with the ride till it comes loose approach, though that would be less convenient.
In summary, I see no need to "fix" or trash the otherwise good crank arm.
FB
Chain-L site
FB
Chain-L site
Quoted: 839 Post(s)
Liked 1,064 Times
One trick I used once was to loosen the bolt a turn or two, get yourself an assistant to hold the bike a few inches off and parallel to the floor by holding onto the crankarm or chainrings and then you use a drift to give a decent smack to the head of the crank bolt. This should move the crank just enough to come loose from the BB axle. Don't get too carried away with the hammer and may take a few hits. Heat to the crank first may help a little but to be safe pour some boiling water over it rather than a flame.
Liked 3,880 Times
JA Stein made (makes currently?) a crank extractor thread repair kit It has an oversized thread tap (pilot too IIRC) and the now oversized extractor/puller.
Bicycle Research and BR offered an extractor thread chaser w/ pilot. here's a shot of it. Andy
AndrewRStewart
AndrewRStewart
Old fart
Liked 3,401 Times
Old fart
Liked 3,401 Times
That's how the VAR kit I mentioned above works. It cuts new, 24mm x 1.5mm threads, and then sell the customer the 24 x 1.5 thread self-extractors for subsequent crank removals.
Liked 2,590 Times
Yes, and BITD we also sometimes retapped cranks to use Stronglight removers. But, IMO, we need to self impose cost limits for saving anything short of a true collectible.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
One time the outer few threads on a crank arm were buggered up and I just couldn't get the crank puller started. I machined a steel rod to both fit closely into the bolt hole of the bottom bracket axle (so the rod was square) and a close fit on the hole in the crank puller. Once the crank puller was all lined up I was able to get it started. Carefully working it in, I eventually got it all the way seated and had enough threads into the crank arm to allow the puller to work. This is not very helpful advice if you don't have access to a lathe, however. Sorry if this therefore doesn't help!
Likes For joeruge:
Friendship is Magic
Bikes: old ones
Quoted: 26426 Post(s)
Liked 10,382 Times
https://steintool.com/portfolio-item...-system/...175 bucks (ouch).
For the OP, I would just either find a pickle fork, or an angle grinder, destroy that Alivio crank removing it, and replace with something better. But I have stuff that is better.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Andy, this tool looks essentially like what was trying to describe. I'm guess that the smaller threaded 'stud' screws into the axle of the bottom bracket and it aligns the thread cutting portion. I didn't know they made such a thing. Very cool!
Quoted: 58 Post(s)
Liked 31 Times
Thanks everyone!
Riding it with the crank bolt loose sounds promising.
Old fart
Liked 3,401 Times
Liked 3,880 Times
Quoted: 503 Post(s)
Liked 436 Times
Is it worth the effort for a few uses? Just cut the two threads in some cold rolled round bar - done; you could knurl it or mill flats for easier use. And you'd have to mount the crank on an axle (or mount it on a face plate) and thread that too. People do this stuff for fun, you just have to find them.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
EDIT: Guess it was already mentioned, but I will say +1 to those that say it works well.
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
just loosen the bolt and ride around the block a couple times.
/markp
/markp
