Crank Arm Bolt Torque Setting
Old 03-24-24, 10:35 PM
muysal
Urban Cyclist
Bikes: Guerciotti SLX - 84', Tide-Ace 11sp carbon frame & misc. Shimano parts
Quoted: 8 Post(s)
I couldn't find any documentation on torque specs for vintage Shimano from the 80's. Do you tighten the crank arm bolt by feel or a specific value?
muysal is offline
Old 03-26-24, 01:42 PM
cb400bill
Forum Moderator
cb400bill's Avatar
Quoted: 3091 Post(s)
Liked 6,601 Times in 3,785 Posts
Post moved from Sales thread to its own thread in Mechanics.
cb400bill is offline
Old 03-26-24, 03:25 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4210 Post(s)
Liked 3,878 Times in 2,315 Posts
That era usually had crank arm retaining bolts torqued to around 30ft/lb. Did you check out the Park torque spec chart? Andy
AndrewRStewart
Andrew R Stewart is offline
Old 03-26-24, 03:31 PM
FBinNY
Quoted: 5793 Post(s)
Liked 2,585 Times in 1,433 Posts
Back when those cranks were made, nobody spoke torque spec.
Do it the old fashioned way, tightening until the torque ramps up toward the wall.
FB
Chain-L site
FBinNY is offline
Likes For FBinNY:
Old 03-26-24, 03:50 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
IF you have a torque wrench, 30-35 Ft-Lb.
Else, good & tight.
BTW, the first time I torqued one, it was more force than I expected. Possibly from a more awkward position?
Bill Kapaun is offline
Old 03-26-24, 06:57 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
By feel. Check tightness again after first ride
dedhed is online now
Old 03-26-24, 07:39 PM
FBinNY
One guide to proper torque is the length of the tool used.
BITD cranks were tightened with the "peanut butter" wrench. This was about 7" long, just clearing the pedal. Tighten with something shy of the max force you can muster.
FBinNY is offline
Old 03-27-24, 07:55 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
You couldn't find any documentation? You must not have gone to Shimano's Technical Document Site.
They still have the old SI's that were used back then. All you need to know is the part number. Which you can use the cranks PN which is around the hole for the pedal on the inboard side.
Here is the SI for a early 80's Deore crank FC-M730... https://si.shimano.com/en/pdfs/si/T-...000-00-ENG.pdf
I usually go by feel for all the bolts and nuts on my bike. Very occasionally, I'll double check myself with a torque wrench to see if I'm in the ball park.
Iride01 is offline
Old 03-27-24, 09:40 AM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 839 Post(s)
Liked 1,258 Times in 663 Posts
I recommend 260 - 300 in lb.
Less for classic campagnolo. Even less for Stronglight.
/markp
mpetry912 is offline
Old 03-28-24, 05:41 AM
sd5782
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times in 394 Posts
/markp
I’m with Mark here or even slightly less. I’ve not done loads, but when my beam type torque wrench starts getting to 250 inch/lbs it just seems tight. Things almost feel like the aluminum is going to split going more. I used to just torque pretty darn tight with a 1/2” socket wrench. Putting on the torque wrench was a surprise as I needed a lot more to even get to 250. It scares me going higher, but I am not a strong rider. I do recheck just once with the ratchet after a couple rides.
sd5782 is offline
Likes For sd5782:
