How many folks only use the middle chainring?
Old 07-14-12, 07:16 AM
Bakammer
I hadn't owned a bike since I was a kid until a month ago when I bough a Trek 7.2 to pull around my 1 year old and get some exercise. I have been out and about almost every day since, really enjoying the hobby/sport.
The roads and paths are flat as a pancake where I live, I have found no need to use the big or little rings. In fact, I rarely get to the high or low gear in the back either, probabally 99% of my riding is done in 5 gears. will this be beneficial in extending the life of the drive train?
Bakammer is offline
Old 07-14-12, 07:18 AM
jbchybridrider
jbchybridrider's Avatar
Quoted: 227 Post(s)
Liked 390 Times in 149 Posts
I'm two speed up front and spend most time on the big ring 50T.
jbchybridrider is offline
Old 07-14-12, 07:25 AM
krobinson103
Bikes: Nothing amazing... cheap old 21 speed mtb
44-12 to 44-15 most of the time for me. Climbing a steeper grade I sometimes use the middle and the smallest for offroad only.
a
krobinson103 is offline
Old 07-14-12, 09:40 AM
lee kenney
Bikes: ritcheys{2** rm blizzard Geo elrick drop frame and acollection of parts bikes in waiting
Rpm
By keeping up the r.p.m. , spinning, you will be extending the life of your personal drive train, your body . You are the engine and have your own tachometer, So enjoy the ride !Teach your children well !
lee kenney is offline
Old 07-14-12, 10:42 AM
David Bierbaum
David Bierbaum's Avatar
Bikes: 1992 Specialized Crossroads (red)
Quoted: 26 Post(s)
Liked 35 Times in 19 Posts
While I don't only use the middle chainring, the occasions for me to use the large one are almost infinitesimal. My granny-gear only gets a workout when I'm going up a hill that is steep or when I go up a mild hill while I'm tired. I think I spend about 95% of my riding life in the middle chainring though. And this isn't a "flat as a pancake" area of the Country, near the bluffs of the Mississippi.
David Bierbaum is offline
Old 07-14-12, 11:42 AM
corwin1968
corwin1968's Avatar
Quoted: 55 Post(s)
Liked 32 Times in 18 Posts
I spend more than 99% of my time in the middle ring and I've chosen my drivetrain configuration with that as a goal. I would guess that using the same gears most of the time would reduce the life of the drivetrain because those specific chainring(s) and cogs will wear out faster. My crankset doesn't have replaceable rings so when the middle ring is shot, I will have a perfect opportunity to upgrade to something stiffer and lighter! Cassettes are easy to replace so no worries there.
corwin1968 is offline
Old 07-14-12, 12:18 PM
mtrinc
99% middle
1% small
mtrinc is offline
Old 07-14-12, 01:24 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
I'm assuming you have an 11-32 cassette on the back?
Consider a different cassette without the extremely large & small cogs, such as a-
https://www.loosescrews.com/index.cgi...d=356470811124
Just Google -
8 speed cassette
Bill Kapaun is offline
Old 07-14-12, 01:26 PM
8086bruce
Bikes: Felt FC
I also have a 7.2 and I would say 85% on the middle ring.
8086bruce is offline
Old 07-14-12, 02:22 PM
AdelaaR
AdelaaR's Avatar
Liked 3 Times in 3 Posts
You said it yourself: "flat as a pancake".
It would indeed be weird to use many different gears on such paths.
You'll learn to appreciate the lower gearing when your kid gets heavier and the hills get tougher.
AdelaaR is offline
Old 07-14-12, 02:40 PM
dbshabo
dbshabo's Avatar
Bikes: Giant Roam 1
I use all three of my chainrings. I use a different one each time I ride. Between the three rings I use gears 2 - 7, 3 gears per ring per ride. I figured it would spread out the wear on my chain, rings, and rear gear sprockets. I may be wrong about that I don't know. I will say the middle ring is the most comfortable for me.
Shabo
dbshabo is offline
Old 07-14-12, 05:01 PM
jsdavis
Quoted: 70 Post(s)
Liked 13 Times in 9 Posts
I use the middle one mostly and the small one for hills. I wouldn't miss the big one if I were to take it off.
I have 28/38/48 rings with an 8 speed 11-34 cassette.
Something like this is a typical ride for me though:
jsdavis is offline
Old 07-14-12, 06:47 PM
009jim
009jim's Avatar
Bikes: Giant CRX3, Trek 7100
Liked 3 Times in 2 Posts
I almost never use my big chainring. It's way too scary at those speeds.
009jim is offline
Old 07-14-12, 08:58 PM
no1mad
Thunder Whisperer
no1mad's Avatar
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times in 2 Posts
Looks like I'm gonna be the oddball. I spend most of my time on the large chain ring, but's a 42t.
Community guidelines
no1mad is offline
Old 07-14-12, 11:16 PM
a1penguin
a1penguin's Avatar
Quoted: 139 Post(s)
Liked 33 Times in 20 Posts
I have a triple road bike and I spend most of my time in the middle ring, 42, with rear cassette 12-25. I can't stand the 11-34 cassette on the hybrid. The spacing between the gears is HUGE. Not sure if I want to sell the hybrid or change the cassette. I'm not happy with wide flag bars. And I don't like the thumb shifters; they are unnatural hand position. If Trek hadn't discontinued the Portland, it would have been a great commuter bike.
a1penguin is offline
Old 07-15-12, 01:39 AM
krobinson103
Just took my new 11-32 cassette on its first real ride today. I have to say I like it. It gives a little better top speed than a 12-xx and with the smallish 44t large front chain ring I have on my mtb the 11 really makes a difference for me. I do agree that when you start climbing the 3 tooth differences in the cogs makes it a little annoying, but for something that needs to be able to ride on both the road and the trail I find a wide range rear cassette to be just the ticket.
Old 07-15-12, 02:48 AM
c23
I work on cadence. Smooth and quick pedaling at the same rate at any speed(or try to). 99.9% flat here, there is one small section with a grade I only found while riding a bike at a perfect cadence since the grade is so small. Middle and large chainring, and 2-4th gear on the rear can keep a constant steady cadence.
Mashing pedals is not good for knees and makes you tired. Spinning a constant speed at a constant pressure can keep you biking for miles.
c23 is offline
Old 07-15-12, 09:11 AM
corwin1968
corwin1968's Avatar
Quoted: 55 Post(s)
I have a similar dislike for large range cassettes. My bike had an 11-28 7-speed cassette and the largest gap just happened to be where I do most of my riding. I got a new wheel and upgraded to an 11-28 9-speed cassette (stayed with the 11-28 for the sake of having a decent granny gear) but as my riding legs come back, I plan to move to a much tighter cassette, either a 12-25 or even a 12-23. I like small, subtle jumps that allow me to maintain a smooth cadence.
Old 07-15-12, 01:18 PM
AdelaaR
AdelaaR's Avatar
That's my middle ring
AdelaaR is offline
Old 07-15-12, 04:41 PM
mac61
Bikes: Trek 7.3 FX
I have a 7.3fx and ride most of the time in the middle gear, easier for stop and go at stop signs and general riding. When i can get a long run without having to stop i shift up to the big gear. No hills where i live so no need to shift down to the small gear. Today i was in big gear front, 6th gear rear and crusing at a comfortable 18-19 mph.
mac61 is offline
Old 07-15-12, 06:45 PM
fcarpio
Bikes: Trek 7.3
I also have a 7.3 and South Florida is also as flat as a pancake. I spend most of my riding time on the largest gear upfront and the fifth or sixth on the rear.
fcarpio is offline
Old 07-15-12, 07:17 PM
2travelers
Bikes: Raleigh Detour 3.5,
Originally Posted by lee kenney
By keeping up the r.p.m. , spinning, you will be extending the life of your personal drive train, your bodyll !
After my hip replacement a friend who at one time was a racer gave me this advise and has been very helpful this year helping with the other hip & knees.
2travelers is offline
Old 07-16-12, 06:01 AM
jolly_ross
All the time I'm changing shark-toothed middle rings for customers. Granny or big-rings - much rarer.
jolly_ross is offline
Old 07-16-12, 07:50 AM
ForFun
Bikes: schwinn midmoor and looking
middle ring 80 to 90 % of the time ... pretty sure my wife has never used the big ring on her coda sport, she does use the small one on occasion
ForFun is offline
Old 07-16-12, 08:45 AM
Evgeny
7% big (48)
90% middle (38)
3% small (28)
Evgeny is offline
