Breaking chain link on some random place
My chain was so dirty that I haven't noticed that there is the master link so I used the old tool I had to remove one pin. After cleaning it, I returned the same pin back in.
The chain is KMC x11 placed on the e-bike and now after some YT videos, I realized that I shouldn't use an old pin.
What are the experiences here regarding this? Should I remove that part and put one more master link?
Quoted: 242 Post(s)
Liked 456 Times
You're fine and so is the chain.
Some don't want you reusing the "master" link because it doesn't hold as securely when removing/reattaching it.
Using a standard link to remove and reattach has no impact on the strength and safety of the chain at that given link. The only problem that can occur is the pin is not seated quite correctly resulting in a stiff link. If this happens just manipulate the link laterally and vertically until the pin seats and pivots easily/smoothly.
Before the "quick" links this is how everyone removed/installed a chain.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
IMO, the above post is not accurate. It might or might not hold. Do not be surprised if the chain comes off during a ride, reused pins usually do not seat properly. If/when that happens, a lot of other bad things can happen. I have had that happen, but fortunately, I was at slow speed and nothing more was damaged. Get a new chain and a couple of extra quick links for it, then clean and lube it regularly.
Likes For delbiker1:
I will probably buy quick link for it and replace the one I opened.. The chain is still ok so I will wait with replacing it.
Since I have marked the pin which I reused I can see that the link is a bit stiffer than others but it looks like there is no way the pin could fall out
Likes For xperiap:
Quoted: 581 Post(s)
Liked 921 Times
Kai Winters is 100% Incorrect - modern chains (anything intended for more than 6 speeds) have the pin peened when assembled at the factory and removing a pin and reinserting will leave the joint too weak and it WILL eventually fail - maybe in two rides, maybe in two years, but it is absolutely compromised.
Modern multi-speed chains have a special pin (Shimano) or quick link (all others) included when you buy them because you aren't supposed to reuse a pin that's been pushed out.
OP's plan to buy a quick link and use it to replace the link that would have been weakened by reassembly is a good plan.
Likes For ClydeClydeson:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I agree, the 11 speed chain is scrap now. I tried to repair the first peened chain I ever encountered, on a friend's bike. We were 50 miles away from a shop when it failed, and it failed twice more before we got there.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
Quoted: 839 Post(s)
Liked 1,064 Times
You cannot tell by looking at it. That is kind of like looking at an inner tube that does not hold air, but it likely does not have a hole because I cannot see one. Once you start putting friction on it, it is likely to work it's way out. It is your bike, do with it as you wish.
Likes For xperiap:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 3514 Post(s)
Liked 2,927 Times
I'm actually surprised he was able to insert a pin after having removed it. Deformed side plates, anyone?
Quoted: 6197 Post(s)
Liked 4,814 Times
While everyone says it's terrible to re-use pins on a 11 speed chain, I did and I never had any issues. I got to ride my bike on a day when the bike shops weren't open so I could get another quick link or break-away pin.
Even if I did have an issue, what's it going to do? I've walked my bike home or called for a ride for other issues. Why not for my chain falling off?
Though if you can avoid doing it, I would. It is a tiny and tedious thing to get lined up correctly and not do any damage to the chain. But once done, why not just find out if the nay-sayers were correct. In my case they were wrong. I got four years on that chain with that re-used pin.
Liked 2,927 Times
People do all kinds of things with their bikes to varying degrees of success. But just because something can be done, doesn't mean it should be done as a matter of course.
As an aside, I've only been a member of this group for a short time, but I have noticed a trend: People seem all-consumed about saving money in the weirdest places, and on some of the cheapest things! Grease, oil, cable end caps(!), handlebar tape, chains.
Why are people obsessing about things that are relatively cheap to replace, instead of trying to figure out shortcuts that could cost them more in the long run, and are possibly dangerous to boot?
Quoted: 1944 Post(s)
Liked 2,164 Times
Thanks!
John
Quoted: 242 Post(s)
Liked 456 Times
^This is TERRIBLE advice^ Narrow (10, 11, and 12 speed) should NEVER have pins pushed out and then back in to join the chain. There is not one manufacturer that recommends this. The outer plates are so thin now and the the pins are flush, it's not possible to safely replace a pin. I've said this before and I'll say it again...if you don't know for sure that your advice is sound, don't post it. It doesn't sound like you're a professional mechanic...if you are maybe you should consider sales.
Gotta love "interweb experts"...meh...I really don't care what anyone does. I'm not riding the bike or working on it...
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
Cobra Kai can give bad advice since they are not riding the bike or working on it. I would not recommend to anyone on modern chains to re-use pins and links unless the manufacturer says you should especially on an e-bike unless in some emergency situation. I would also recommend cleaning your chain more often and making sure it is properly lubed and take care of the bike. On the E-bike you are more likely to run through chains and cassettes more often especially with poor maintenance and usage.
Expired Member
Quoted: 3677 Post(s)
Liked 5,441 Times
LOL I've been a wrench since the mid '80's. I've used "fixed" pins on 10-11 speed chains when I had to without a single problem. You do have to know what your doing and use the correct tools.
Likes For shelbyfv:
Quoted: 1110 Post(s)
Liked 1,204 Times
With modern chains (anything higher than 8 speed?), pushing the pin back in to reconnect the chain is not a good idea. OP did read up on it so I won't repeat why, but don't do it. Remove a link so a new master link can be used for that connection.
Likes For Camilo:
Liked 2,927 Times
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
As others have said, just pushing the pin back in is a bad idea on any modern chain. All modern chains have peened pins which are meant to keep the plates on the pin during the side force that shifting derailment puts on the chain. Without the peened pin, the side plates will likely slip off the pin. The “snap” you hear when removing a modern pin is the peened head breaking off. Often you’ll see little metal rings on chain tools. That the peen that has broken off. See red arrow below.
Stuart Black
Stuart Black
Liked 2,927 Times
Cyc, what brand chain breaker is that? Looks awesome.
Likes For smd4:
Clark W. Griswold
Liked 4,001 Times
Liked 2,927 Times
Likes For smd4:
Clark W. Griswold
Liked 4,001 Times
