Un-bending a rear derailler
If you look at the photo below, you may not be surprised to learn that the derailleur cage rubs against the spokes when it is on the largest cog.
From what I've read, it sounds like the way to fix this situation, in general, is to bend the hanger. Is that the right approach here? It is a Suntour GT in case that matters at all.
Quoted: 932 Post(s)
Liked 1,319 Times
Usually it is the hanger that is bent, not the derailleur, so yes, removing the derailleur and bending the hanger is generally the correct remedy. Park even makes a special $80 alignment tool that threads into the hanger and helps you get the hanger perfectly aligned. Every bike shop worth its salt will have that tool. Either pay the mechanic to straighten it for you (should be a minimum charge) or go it alone with a big crescent wrench and eyeball it. For 5-speed friction shifting like you have it doesn't have to be perfect.
Likes For davester:
Quoted: 4722 Post(s)
Liked 3,039 Times
In this case, the the mounting claw is not parallel to the cogs. It's hard to tell if the bend is completely in the claw but it appears to be the major contributor. The claw can be removed from the derailleur to be straightened. Once re-assembled, that will tell you if there is additional bend to look for elsewhere A lot of cyclists would just grab the derailleur and bend it back into position, which may fix the issue but still cause problems if installed on another bicycle, as you're not necessarily addressing the root cause.
Likes For T-Mar:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
If you don't want to fix it "properly" with an alignment tool directly on the rear derailleur mount, you could bodge it by using the correct sized allen key in the rear derailleur mounting bolt and *carefully* torque it (bend it) so it effectively straightens the rear derailleur hanger and the whole assembly lines up more correctly. There's probably a YouTube video...
I think I will give straightening it a go myself. It actually runs pretty well now (except in the largest cog of course) - it can only get better
Quoted: 1088 Post(s)
Liked 1,205 Times
Yes, that's the hanger claw. But recall Astronaut Chris Hadfield -- "There is no problem so bad you can't make it worse."
Quoted: 796 Post(s)
Liked 522 Times
Or you can buy a whole new vintage looking RD from Amazon for about $10 or get one from a bike co-op
Quoted: 887 Post(s)
Liked 335 Times
Just remove the wheel and chain, and then fix the claw or buy a new one. What @T-Mar said about everything else. A dropout with no integrated hanger is not too hard to align - if it needs aligning at all. I may have a Suntour hanger in my stash if you need one.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
A tip I picked up from @Andy_K:
Most rear QR hubs are M10 x 1mm pitch.
Most derailleur hangers are the same thread.
Remove QR, thread in your wheel, carefully bend. It's easy to see if the rear wheel on your bike is parallel with the "tool" wheel.
Quoted: 932 Post(s)
Liked 1,319 Times
Likes For mmcc73:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
If you're not confident bending the hanger back, just replace the existing one: https://www.ebay.com/itm/Sunrace-Der...wAAOSw8Dxc3sNB
-Kurt
-Kurt
Bad example
Quoted: 828 Post(s)
Liked 215 Times
I am a fan of using a Crescent wrench to straighten hangers. I have been pretty successful with indexed derailleur hangers as well, although the Park tool is definitely a better choice for that.
Quoted: 472 Post(s)
Liked 1,045 Times
Keep in mind that the hanger or claw needs to be parallel to the wheel, all the way around. Best to start with a nicely true wheel. Otherwise always check at the valve stem. Check it both top to bottom and back to front. You can check more spots but diminishing returns. I find that getting it to within 1/8"at the rim, back to front and top to bottom is sufficient. Yes, less fussy with friction shifting but is very nice when friction shifting is so smooth and predictable.
I find that around half of the bikes that come into the shop have bent hangers, even right out of the box. Some top to bottom, some back to front, some both. All my own bikes get checked and adjusted.
Likes For Prowler:
Quoted: 605 Post(s)
Liked 480 Times
I agree on the frequency of bent hangers, it made me go buy the proper Park alignment tool. Expensive, but I've gotten great mileage out of it. If you have multiple bikes and/or like to tune & build up your own, it's very useful to have on hand.
Quoted: 932 Post(s)
Liked 1,319 Times
-Kurt
-Kurt
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I resemble that remark.
Commence to jigglin’ huh?!?!
Liked 4,396 Times
OP's pic most definitely shows a bent hanger though. I'm giving the dropout the benefit of the doubt. The stamped Raleigh dropouts tend to get chewed down by the axle cone nuts - if the dropout is bent. I don't see that here.
-Kurt
