old Robin Hood, what is the braze on/hole in right chain stay for?
I bought an old Robin Hood frame because it had Campagnolo shifters, derailleurs, headset and cable clips. The frame appears to be a 3spd,
that was set up like a road bike. It has a large braze on, with an unthreaded hole, on the right chain stay near the bottom bracket. Does anyone know what this hole is for? I hope your guys can help- Thanks- Don
Power steering flud resevoir.
Likes For Weresquatch:
It might have been an attachment point for a rod brake set up. The oil port on top of the BB points to an early frame. Hope you get this one rolling!
Bad example
Quoted: 828 Post(s)
Liked 215 Times
I wonder if it would hold a pulley for the cable to the rear three speed hub?
Quoted: 4806 Post(s)
Liked 3,933 Times
Along the lines of being for a shift cable pulley, could it be the "pulley" itself? Ie, the cable running under the cylinder like it was a pulley. If so, the "pulley" would just be a washerlike cylinder curved on the left side for the chainstay. Hole would not run through and the inside wold be painted. The location looks right for a clean lead form a downtube shifter.
Edit: the oilport can be seen on the BB shell.
Ben
Ben
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
My guess is an attachment bolt for a chain guard.
Quoted: 887 Post(s)
Liked 335 Times
Possibly a hole to receive a peg that would stabilize a chainguard?
Count Orlok Member
That hole could be tapped for mounting a chaincase. They were just part of the frame for many years. I had a Popular Special frame that had that lug as well as the oil port on the bottom bracket. I'm guessing it was from about 1960. They stopped putting that lug on frames a few years later.
Seńor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
This is pure speculation, but it seems to be in a location where it might keep a chain that gets dropped from wedging between the frame and the chainring.
Quoted: 12 Post(s)
It is a mounting point for a full chaincase. I have the same on a 1956 Rudge and a 1952 Humber, both three speeds. Raleigh's three speed frames back then had the mount whether they shipped with a full case or just the hockey stick guard. You'll likely find that it is tapped for a 26tpi bolt if you clean off all the paint on it. My Rudge is tapped even though it was shipped with a hockey stick guard.
-Carl
-Carl
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
-Carl
-Carl
Thank all you guys for the input. It looks like the consensus is that it is for a full chaincase. I'll go with that. I thought it might be for a chain guard, but assumed it would be threaded. I though the quiver comment was great! Thank you all again- Don
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Chaincase mounting boss.
Likes For cudak888:
since6
Classic & Vintage
19
09-18-18 08:21 PM
migrantwing
Bicycle Mechanics
10
01-17-17 12:41 PM
PatrickGSR94
Bicycle Mechanics
12
12-15-15 12:28 PM
