Broken Ball Bearing
Broken Ball Bearing
Anyone ever break one in their hub? Bought an old Peugeot with a broken bb in front hub, you would think least loaded of the two. I mean sheared right in half broken! Left a couple indentations in the cup. Of course original owner was still riding it around, looked like it had never been maintained, original grease I think! Between that, stuck seat post, stem and fixed side of bottom bracket, its been a real effort to resurrect this thing. Hope it will be worth it!
Mechanic/Tourist
I don't understand these "did anyone ever" posts, especially when they refer to random events that could have a multitude of causes. I'm not being critical, more like confused. How does it help to know if it's ever happened before, other than perhaps misery loves company? To answer directly - yes, other people have had broken bearings in their hubs. But I wonder if you and others perhaps mean to ask a different question, such as what could be the cause, how to avoid in the future, how common is it.
Sr Member on Sr bikes
Wow! Tough crowd (or couple) here. WTF is wrong with having a conversation about bike-related maintenance issues?
Dan
Dan
Quoted: 897 Post(s)
Liked 9 Times
Some people object to the form of the question, as if that matters much.
I just wonder what the board is if it's not a chat board. Are we some sort of professional scientific technical journal? Should we start adding footnotes to our posts, to indicate where our information can be checked and corroborated? And include a bibliography at the end of each post? And a summary at the beginning?
Good luck with getting anyone to follow that format.
Bikes: Bike Friday NWT, Rans Stratus, Cannondale R500, trek 720 multitrack, Rockhopper
Quoted: 35 Post(s)
Liked 36 Times
I am pretty interested in this, I’ve never had or seen a broken steel bearing on a bike. The causes would be very interesting, possible corrosion? A picture of the bearing would be nice.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
I've seen cleanly split BBs, in old bikes being rebuilt. I think an impact would be a more likely cause than wear, corrosion or age. Maybe a flaw. But I'm not a metallurgist.
Was the BB originally in a retainer cage? Seems I most often see split BBs with the twisted remains of cages. Maybe that makes it more susceptible to impact, more load on one ball.
I have seen worn and corroded BBs, too, with good sized chunks eaten away.
Was that an aluminum seat post in a steel frame, and were you able to free it? I try to remember to check that first when one of those comes in.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1233 Post(s)
Liked 318 Times
Well I have experience with that. LOL
My SA XL-FDD dyno hub, with 17,000 miles, ATE 4 bearing in a sealed unit. This hub took a some hits on a tour 7 months before and I went for a 90 mile ride on the highway just a couple days before I noticed something wrong. It was feeling strange leaning in a curve and had an intermittent side to side looseness when I was stopped and trying to wiggle it. I was then riding slowly on a 12 mile ride when I finally decided it was seriously bad. But I still rode it home slowly keeping it straight up.
So the next day I took it apart. The crumbs were all stuck on the magnet, 4 of the 11 balls were gone. LOL Everything else had NO lube whatsoever and had no discernable pits or marks.
So I got out the vacuum cleaner to help suck the chips off. I then couldn't find any other scratches or damage. So I went to the industrial bearing warehouse and got some new sealed bearings. I had to unsolder the wire to get it apart. I didn't need a keeper for the magnet that I could tell., still powers fine. Oh, but first I had to make a 33.5 mm hexagon tool with 1/8" a steel plate, to open the soft Alu shell. This hub just did another tour, now 24,000 miles. Sturmey Archer stuff is TOUGH. ha I'm not sure how the hell 4 balls could make all those little bits.
Mechanic/Tourist
Some people object to the form of the question, as if that matters much. I just wonder what the board is if it's not a chat board. Are we some sort of professional scientific technical journal? Should we start adding footnotes to our posts, to indicate where our information can be checked and corroborated? And include a bibliography at the end of each post? And a summary at the beginning?
Your suggestion that this is either a chat board or an absurd alternative is of course a false dichotomy. It's pretty clear above what the function is "If you're having problems with your bicycle, or just need help...drop in here..." However, there is absolutely no rule or prejudice against just having a conversation. It was simply not clear whether the OP just wanted to swap war stories or acquire knowledge.
Mechanic/Tourist
Mechanic/Tourist
Serious question - What would you do with such information? Would you overhaul a hub more often specifically to avoid a broken bearing from corrosion? If it's due to a manufacturing defect would you have each bearing tested for faults? Would you be more careful with hub adjustment because that was suggested as a factor in a broken bearing? Is there any reason for focusing on a broken bearing if it's something you've never seen (and probably never heard about)?
Personally, I repeatedly test every individual bearing for strength and quality with a hydraulic press before allowing it anywhere near my bike...
Quoted: 35 Post(s)
Liked 36 Times
I don’t know why you think I owe you an explanation as to my interest, but obviously you do.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I buy loose bearing balls for about 2 cents each. So I always replace them. The time taken to tear down, clean and regrease a hub or bottom bracket, spending under 50 cents on replacement bearings is trivial.
I’ve seen a wide variety of things when opening old hubs and bottom brackets. Not knowing the bikes histories I don’t know the causes.
+100 caged bearings tend to fair the worst. When the cage ass-plodes it tends to do other damage.
Mechanic/Tourist
Quoted: 7345 Post(s)
Liked 2,452 Times
Yes, I have seen broken-in-half bearing balls in bicycles.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
If it's of any use, I've seen broken (split) bearing balls in hubs more than once. On every occasion, the hub was with practically no grease (very old, completely dried grease, and little left of it, even dry as it was).
Quoted: 4790 Post(s)
Liked 3,918 Times
I"m guessing that the cones came new too tight (very common). If the bike is a UO-8, bearing quality is not especially good so there may well have been tighter places within the rotation of the axle. The balls may not have come from the same batch and one was slightly larger. Now add rider weight. That large ball gets regularly "squashed". After enough of these, it breaks. (It's also done some damage to the cone.)
I'd buy some new bearings, put them in fresh grease, tighten just until play is gone with the wheel on the bike and the QR tight and ride it. (Note that this means the axle will have a touch of play out of the bike.)
Ben
Ben
