S-Works vs Standard Specialized
Quoted: 800 Post(s)
Liked 512 Times
I did some searching on the forums and didn't come across any existing threads so...
What are people's thoughts on S-Works bikes vs regular Specialized bikes? Are the S-Works bikes worth the difference in price? Or am I pretty much asking what the length a piece of string is?
Quoted: 20791 Post(s)
Liked 9,436 Times
My thoughts are that they're doing the same thing as most manufacturers but they're putting a different label on their highest-spec frames for the purposes of marketing.
Likes For WhyFi:
Quoted: 1851 Post(s)
Liked 675 Times
Specialized uses a different blend of carbon for its S-Works frames (11r) versus non S-Works Frames (From 6r to 10r). There are weight and stiffness advantages to the higher level carbons.
And the differences can be measured. An 11r frame will weigh about 150g less than a 10r frame. (So it is not a question of how long is a string.)
As for stiffness, I don't know that actual measurements exist, but having ridden several versions, I personally would not buy anything less than 10r.
Likes For colnago62:
Likes For akirapuff:
Quoted: 18883 Post(s)
Liked 10,645 Times
This is for your wife, right? I'm going to go out on a limb here and assume she could not be competitive as a sumo wrestler, based on the fact that she's a female roadie. If my assumption is correct, she's doesn't need a crazy stiff frame. More stiff doesn't mean more fast, about 99% of the power you make goes to the rear wheel on any modern bike, if stiffer frames really were faster they'd be marketed with their watt savings. Stiff frames handle predictably, and stiff is relative to the stress the frame will see, tightly correlated to rider weight.
So take the weight savings and the cost, and decide whether it's worth it to you.
Liked 10,645 Times
Now, same question about S-Lab.
I think S Works used to be their race stuff.
I sort of remember, especially in MTB, that the S Works stuff was race only and slowly the tech trickled down to stuff mere mortals could purchase.
Then in road, there was a top of the line Tarmac, then the S Works. Again, S Works stuff (carbon, design, etc.) trickled down to the regular Tarmac line.
Almost bought an S Works frame but the geo was way too aggressive.
I think S Works is a play on semi factory sponsored privateer race teams.
From motorcycle racing: you got the full on Honda Team using full factory sponsored equipment and personnel, then a privateer Honda Works team using factory provided/purchased equipment.
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
The S-Works is inferior to the Sagan edition
Liked 9,436 Times
And C'dale has their Hi-Mod, Giant their SL grade, Jamis their Dyad Elite, etc, etc. Spec just slaps a sub-brand on there to evoke the skunk works labs of old and to give their highest-paying customers more glance-able coffee shop cachet.
Quoted: 800 Post(s)
Liked 512 Times
Liked 675 Times
There is not going to be much stiffness difference between the S-Works and the Pro frame options. The real difference there is weight, which as I said is about 150g on average, though it can vary depending on size and paint scheme.
Quoted: 1814 Post(s)
Liked 923 Times
I've heard it described as non S-works being roughly equivalent to the previous model S-works,
so SL3 Tarmac about the same as my S-works SL2.
Don't think the weight savings part holds as my 2008 frame may be lighter than new ones,
but the high end bike will definitely be lighter than the lower spec'd one.
Quoted: 871 Post(s)
Liked 725 Times
Beware, the S-Works trim of a Spec bike may have a press-fit BB instead of threaded and a narrower cassette ratio. Both of those are arguably worse choices for the non-racer.
Quoted: 871 Post(s)
Liked 725 Times
Wrong and wrong. They went back to threaded for the 2017 trims below S-Works, and it takes a minute to check that chainrings are either smaller and/or cassettes are larger on non-S-Works trims too.
Liked 10,645 Times
Correct! The bike is for Mrs. NoWhammies. And you are indeed correct. She does not need a crazy stiff frame. I have been trying to steer her away from the S-Works but she likes the look of them. So who knows where we'll end up. There is no rush for a new bike, and it is still early days. Plus I'm fortunate in that she still loves her current bike and is in no rush for a new one. I am trying to gather as much info so when the time comes, I'm ready.
And will she keep it or will the new bike replace it?
Liked 675 Times
OSBB (Pressfit)
https://www.specialized.com/us/en/ta...=271669-171349
https://www.specialized.com/us/en/me...=227241-154558
Threaded:
https://www.specialized.com/us/en/me...=227242-154557
https://www.specialized.com/us/en/me...=227230-154556
As for the chainrings and cassettes, they can be swapped out if someone needs something different. I'm not sure I see what your complaint is?
Personally, I don’t like the name S-Works. It just sounds childish and cheesy. Same with their SWAT line of accessories. Very odd. It’s like they are marketing to kids , but kids probably aren’t buying $1I,000 bikes. I really wish they’d drop the silly marketing monikers and just use model distinguishers like others. Now, having said that I would snap up an S-Works road bike in a second if someone gave it to me! Great bikes and gear. Corny name. You can’t always have everything.
So what, that most of us aren’t expert enough to tell the ride difference between good and great frames or top line and lower level wheel sets. If cost of ownership is not a consideration, might as well get the Works! Otherwise shop for deals on leftover older years stock. Remember how you drooled over that stuff when it was first announced!?! They are still great bikes, too! And, those lower modulus carbon frames have always been good enough to take pros to the podium. You can ride any bike as well as you can ride. Just gets down to what you want to ride.
Best of luck! I suspect she’ll love her new bike whatever and whenever it happens!
Quoted: 871 Post(s)
Liked 725 Times
Looks like we're both wrong.
OSBB (Pressfit)
Threaded:
OSBB (Pressfit)
Threaded:
I find it silly to buy the more expensive trim only to spend even more to ride it as comfortably as the less expensive options. Shows that someone has more money than bike sense.
Quoted: 4196 Post(s)
Liked 2,912 Times
I always thought S-works was a play on the Specialized name and Skunk Works, which is a name often used by companies for their super-advanced, secret, R&D divisions. Lockheed Martin claims to have been the first to use that name, but I thought I'd seen something older in europe. Could be mistaken.
Quoted: 800 Post(s)
Liked 512 Times
Plus BH just released their G8. Maybe I'll try to steer to that way...
Liked 10,645 Times
That looks like a super road bike. Consider a gravel road bike, as a complement to what she has now?
