Fluid Film Inside Frame?
Team:
Any reason I shouldn't spray Fluid Film inside the frame of my 86 Peugeot Triathlon? I'm treating a few spots of rust on the toptube from sweat and am concerned about the inside. I don't want to disassemble the bike but could spray into the seat post and any other opening I could find.
Also - For the exterior rust spots. Do you guys sand first then use Fluid Film? Or just fluid film and call it a day? Not sure if I'll paint over yet or not. They're small. Read about some folks using nail polish to touch up. Might work.
Quoted: 964 Post(s)
Liked 1,451 Times
I'd just do it. And maybe hearing you've done it will inspire me to do it to my frame.
Quoted: 1136 Post(s)
Liked 650 Times
Yes, fine to spray into the frame.
Regarding external rust spots - spray first, then sand, then clean the sanded area with a clean rag. Once clean, touch up with paint or nail polish. If it is small enough that you don't care about touching it up, I would use some auto wax on it periodically to protect from future rusting.
Regarding disassembling the bike - you should at least clean and repack with grease the bearings, meaning the bottom bracket, headset, and hubs. If you don't want to do this have the LBS do it. When the fork and bottom bracket are out, either you or the LBS can spray inside the frame.
Rustproofing the interior of the tubes is just not needed. Seal off the factory breather holes and squirt motor oil inside the tubes if you want, and you are all set. I built a frame in 2001, commuted year round on it for 10 years in the Rust Belt of the Midwest, with lots and lots of salt on the roads, and have had zero issues of rusting out from the inside. I still ride the bike today.
Pulled off the rear end of the frame to rebuild it after an accident, and although the BB was fairly rusty inside, the chain stays had little to no rust at all. Looking up the seat tube and down tube there is only a mild surface rust, more like a patina. This frame will never rust out from the inside, as will most steel frames. It simply is over kill to rust proof, however if you feel better, go ahead and do it.
I use Fluid Film on the door panels of my car. Needs to be renewed annually.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,793 Times
This. If you want to do it, I don't see any real harm.
I live in Florida on the Atlantic Ocean coast. I ride up and down the beach at low tide. Stuff oxidizes & rusts like crazy around here. Put a big piece of scrap cardboard (large pizza box is good) on the floor of the garage. Take the bike wheels off. Hang the bike from ceiling over the cardboard. Spray inside of bike frame with LPS 3. Rotate frame a few times. Wait a day or so. Let the excess drip out of all the holes. Put the wheels back on and ride. (Yes. Spray the inside of your tubes).
Will pencil sand the spots tomorrow. Spray again and then clean before wax or paint over.
Sound good or does it need to sit longer?
Appreciate the insight here. I live in Memphis. Very humid but no salt to worry about.
I haven't tried Fluid Film but I like to use Rust Check. It's a "creeping" oil that wicks into crevasses / folds.
Quoted: 2362 Post(s)
Liked 1,749 Times
+1 10GB; even after wiping, what's left of the FF on the rust will have neutralized it by now, and it will sand away much easier. Do NOT apply FF after sanding, as it would interfere with paint contact. Don't wax either. Once you're sanded down to clean metal you're ready to paint, but start with a clean dry surface, free of chemicals.
Hate to scratch up this old frame. Ugh. But better ugly than rusty. Thinking about options for cover up.
Could nail polish or mask off everything but the top tube and head tube. Wrap string around and Spray.Paint something on top. Then remove the string to have the original color way lines underneath.
Could be cool.
Or FUNKY. HA!
Could be cool.
Or FUNKY. HA!
