Need to diagnose problem
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 08-22-19, 03:46 PM
MSchott
Bikes: 2017 Specialized Roubaix Sport SL4
Quoted: 76 Post(s)
Liked 28 Times in 20 Posts
I posted this on the Bicycle Mechanics forum here but itís quickly scrolling down the page so Iíll try here:
I own a 2017 Specialized Roubaix SL4 Sport which I bought NOS earlier this year. It uses the 105 5800 11speed with 11-32t derailleurs and shifters and Praxis cranks and BB.
Iím having an issue with a sporadic clicking sound when pedaling. It doesnít seem to be related to the gear Iím in and I just had the dealer adjust the derailleurs. They shift perfectly and thereís no chain rub.
Any thoughts on where this clicking is coming from?
MSchott is offline
Old 08-22-19, 03:50 PM
tagaproject6
tagaproject6's Avatar
Quoted: 510 Post(s)
Liked 169 Times in 91 Posts
Check the end cable on your FD. Sometimes it sticks out and hits your pedal or your shoe. Tighten your seat post. Tighten your skewers. Check your bottom bracket.
tagaproject6 is offline
Likes For tagaproject6:
Old 08-22-19, 04:07 PM
LAJ
So it is
LAJ's Avatar
Bikes: Luzerne, 684, Boreas, Wheelhouse, Alize©ģ, Bayamo, Cayo
Quoted: 4693 Post(s)
Liked 121 Times in 93 Posts
Along with the above, double check pedal to crank interface. Light coat of lubricant, and tight.
LAJ is offline
Old 08-22-19, 04:18 PM
MSchott
Quoted: 76 Post(s)
Thank you. Pedals are tight, itís not the cable or seatpost. Definitely not the skewers. The sound is coming from the pedal area. How do I check the BB? If itís that, Iíd take it under warranty to the dealer. My suspicion is itís the BB.
MSchott is offline
Old 08-22-19, 05:59 PM
Pirkaus
Coffin Dodger
Pirkaus's Avatar
Quoted: 521 Post(s)
Liked 26 Times in 17 Posts
Also check your chainring and crank spider hardware, to be sure they're tight.
Pirkaus is offline
Old 08-22-19, 06:10 PM
Sapperc
Bikes: Specialized Roubaix SL4 Comp, Trek 930, Nishiki International
Quoted: 47 Post(s)
Liked 14 Times in 7 Posts
Often ďcreakingĒ noises can be difficult to isolate due to the tendency of sounds to resonate through carbon frames. However, if it is the BB, you should be able to confirm that on a maintenance stand or perhaps in a quiet corner on a shop floor. Try twisting the cranks and pulling and pushing them side to side. There should be no play at all. Any play or noises probably indicate the bearings need attention. Could be dry, corroded, dirty, loose, infiltrated by water, or a combination of issues. Itís also remotely possible that the crank arm could come loose from the axle, which would need replacing. My Praxis BB needed cleaning and repacking at about one year. Praxis recommends yearly BB maintenance anyway. You definitely should be able to get the BB fixed under warranty.
Good luck!
Sapperc is offline
Old 08-22-19, 06:16 PM
MattTheHat
MattTheHat's Avatar
Bikes: '20 Specialized Roubaix Expert, '18 Specialized Diverge Comp
Quoted: 264 Post(s)
Liked 173 Times in 120 Posts
If it’s a faint ticking noise, check that the ends of your shoelaces aren’t slapping the crank. I had that happen once.
MattTheHat is offline
Old 08-22-19, 06:52 PM
MSchott
Quoted: 76 Post(s)
Originally Posted by MattTheHat View Post
If itís a faint ticking noise, check that the ends of your shoelaces arenít slapping the crank. I had that happen once.
Thanks but no shoelaces on my cycling shoes.
MSchott is offline
Likes For MSchott:
Old 08-22-19, 06:58 PM
MonsterFat
Bikes: Fat City Monster Fat, BMC Roadmachine, Trek Emonda, Trek 2100, Specialized Rockhopper
Quoted: 18 Post(s)
If you have clipless pedals, check the cleats. Sometimes they loosen. Also, even though you think it's coming from bottom bracket area, check stem, headset and brifter bolts.
MonsterFat is offline
Old 08-22-19, 07:05 PM
MSchott
Quoted: 76 Post(s)
It doesnít happen when I coast, only when Iím pedaling. Iíve recently tightened the stem to the bars and the headset was recently repacked. Iím 90% confident itís in the crank area.
MSchott is offline
Old 08-22-19, 07:10 PM
MoAlpha
ē ó
MoAlpha's Avatar
Bikes: Occasionally
Quoted: 2022 Post(s)
Liked 304 Times in 180 Posts
Is it a single click or a series?
Is it timelocked to the pedal stroke or variable?
Is it load dependent, and if so, is it with load on one side or both?
I probably won’t have any useful ideas, but these are essential questions.
MoAlpha is offline
Old 08-22-19, 07:56 PM
MSchott
Quoted: 76 Post(s)
I probably wonít have any useful ideas, but these are essential questions.
Its a few clicks per revolution, itís not really load dependent but if I focus on a smooth stroke it seems to lessen but not go away. Itís variable to the pedal stroke.
MSchott is offline
Old 08-22-19, 09:29 PM
MattTheHat
MattTheHat's Avatar
Quoted: 264 Post(s)
Have you checked the torque on the Praxis cranks? The Praxis cranks on my Diverge weren’t tightened to spec (too loose) which also caused some creaking.
Old 08-22-19, 09:33 PM
MAK
Bikes: Yes, I have bikes.
Quoted: 156 Post(s)
Liked 12 Times in 5 Posts
Clicking drove me nuts until I realized it was the cable. What made it worse was that there was no problem on the big ring, but clicked on the little ring.
MAK is offline
Old 08-23-19, 04:26 AM
MoAlpha
ē ó
MoAlpha's Avatar
Bikes: Occasionally
Originally Posted by MSchott View Post
Its a few clicks per revolution, it’s not really load dependent but if I focus on a smooth stroke it seems to lessen but not go away. It’s variable to the pedal stroke.
Yeah, so not the FD, and probably load dependent. First thing I’d do is remove the rear wheel and lube all the dropout, hub, and skewer/axle surfaces. Then check the chainring bolts, but that won’t be it.
MoAlpha is offline
Old 08-23-19, 08:39 AM
TheGBKid
Just a random thought as it happened to me...
If you have nuts on the valve stems to hold them in place, make sure they're tight. I had a clicking noise once/twice per revolution that was coming from "somewhere" down and behind my ears. Took 15 minutes on the stand in super quiet garage to locate it. Felt like a tool once I realized how simple it was. A little blue loctite and away I quietly went.
TheGBKid is offline
Old 08-23-19, 09:04 AM
Megiddo
Megiddo's Avatar
Had the same! I do have BB crank noises I haven't resolved, but definitely my front wheel was making clicking noises. Put those nuts back on and the noise was mostly gone. I've gone tubeless so they are really quiet now. Now to solve the stupid BB noise.
Megiddo is offline
Old 08-23-19, 06:35 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 598 Post(s)
Liked 90 Times in 76 Posts
Sounds like maybe seat or seatpost. How much post is in the seat tube? If it extends far below the clamp, trimming it might do the trick.
Kimmo is offline
Old 08-23-19, 07:59 PM
big john
big john's Avatar
Quoted: 382 Post(s)
Liked 99 Times in 76 Posts
Take the cranks off and lube everything in the bb, or have someone do it for you.
big john is offline
Old 08-23-19, 08:02 PM
sheddle
Bikes: 1986 Bridgestone 300, 2008 Bianchi Eros, 1981 De Rosa Professional
Quoted: 86 Post(s)
Liked 76 Times in 47 Posts
The absolute best was when I had this and it ended up being my multitool clicking against a CO2 canister in my pocket once per pedal rev
sheddle is offline
Likes For sheddle:
Old 08-23-19, 08:16 PM
MSchott
Quoted: 76 Post(s)
Its the OEM seatpost on a frame properly sized for me. I doubt itís that.
MSchott is offline
Likes For MSchott:
Old 08-23-19, 10:11 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 598 Post(s)
Could still be that, particularly if there isn't enough grease on the post.
Kimmo is offline
Likes For Kimmo:
Old 08-24-19, 10:21 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2389 Post(s)
Liked 89 Times in 76 Posts
I typically recommend doing one leg pedaling (disconnecting one foot from the other pedal completely), then swapping legs. This might at least tell you it's a pedal/cleat vs BB thing.
Sy Reene is offline
Likes For Sy Reene:
Old 08-31-19, 09:07 PM
MSchott
Quoted: 76 Post(s)
Hereís an update. I followed most of your suggestions. Tightened the cleats, lubed and tightened the pedals, chainrings and other driveline components. Made sure the FD cable was out of the way. Checked the seatpost and more.
Problem is is still there. It doesnít show until after about 10 miles but itís still there. Itís more prominent under heavier load and relatedly up hills. The sound is between a creak and a click and is worse as the load increases like in the big ring, 13 tooth sprocket. Any more thoughts?
MSchott is offline
Old 08-31-19, 09:21 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1959 Post(s)
Liked 105 Times in 84 Posts
That's usually spoke crossings. PITA but no harm.
Results matter
Carbonfiberboy is offline
