Autumn Tuning
Autumn Tuning
Hey I'm back for another autumn of cycling to work.
As many of you know, I have a Trek FX that is going on 3 years old. Last fall, I had to get a new rear wheel because it was rubbing against the brake pads. It was quite loose.
This year, it's doing the exact same thing.
Should I bring it in to the mechanic, or is there a DIY fix that someone can suggest? DIY would definitely fit the budget.
Thanks!
Thanks!
Quoted: 4227 Post(s)
Liked 2,488 Times
I can think of few reasons why a wheel would rub on the brake pads:
1...wheel not centered in the drop outs
2...wheel axle not tight enough which allows the wheel to move
3...loose bearing locknuts in the hub which allows to wheel to move sideways
4...brake calipers out of adjustment
5...worn out bearings or bearing races
You can check these yourself before going to an LBS and shelling money out.
The rear axle is quite loose and I'm positive that's the cause.
Assume I know nothing, what tool do I need and what do I need to do to fix this?
Quoted: 5222 Post(s)
Liked 3,575 Times
cone wrench(s)? a good & friendly mech. could snug that up for you in a cpl minutes
but that sounds kinda fishy, where did you get the wheel?
Mad bike riding scientist
Quoted: 6196 Post(s)
Liked 4,193 Times
You could be experiencing a different problem, however. Depending on the model of FX you have, you might have a freewheel hub. Those can be prone to breaking axles. That's a more involved job. It's do able but involves more work.
Stuart Black
Stuart Black
Sr Member on Sr bikes
Dan
