Will GRX handle a 11-46 cassette?
Old 10-08-19, 08:29 PM
BigPoser
BigPoser's Avatar
Bikes: BAHL Giro, BAHL Uno, BAHL GVL, Cuevas
Quoted: 250 Post(s)
Liked 13 Times in 9 Posts
Getting GRX for my gravel build and want to put an 11-46 cassette on it. Thinking that an adjustment of the B screw would allow it.
I can't find anything that shows if it's possible.
Anyone know first hand if it will work? My other option would be to use an XT rear mech.
Thanks in advance.
Brandon
BigPoser is offline
Old 10-09-19, 03:46 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
GRX and mtb parts are not compatible. GRX is road spec.
Racing Dan is offline
Old 10-09-19, 06:33 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Thanks in advance.
Brandon
Nope, per official numbers The 1X11 GRX RDs top at at 11-42, officially. The 2x11 top out at 11-34.
https://www.coloradocyclist.com/shim...ear-derailleur
Features
  • For use with single ring crankset, 11-speed
  • Weight: 264 grams
  • Adjustable chain stabilizer prevents chain slapping and drops
  • Toggle clutch ON/OFF to match the terrain
  • Switch stabilizer ON/OFF to match the terrain
  • Gravel-tuned clutch tension
  • Total capacity: 31T
  • Low sprocket: Maximum 42T/Minimum 40T
  • Top sprocket: Maximum 11T/Minimum 11T
  • Cassette Size: 11-40t to 11-42t
Marcus_Ti is offline
Old 10-09-19, 07:56 AM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
Liked 145 Times in 78 Posts
Thanks in advance.
Brandon
Features
  • Weight: 264 grams
The gravel/cyclocross forum may he a better place to ask this. Someone there may already be running the same thing.
But, it's well known that Shimano is conservative with its max cog capacity of their rear derailleurs. Most likely it will work fine with some b-screw adjustment.
I'm contemplating a similar set up for my gravel bike. Please report back with how it works out for you.
Bryan C. is offline
Old 10-09-19, 08:57 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10964 Post(s)
Liked 7,490 Times in 4,189 Posts
Are you looking at 1x or 2x? Either way an 11-46 is too large to officially work. But if its 1x, then there is at least a chance since its 4t larger than the stated max.
For what its worth, a 30/34 bailout is the same as a 40/46 bailout in terms of gear inches. So a simple 46/30 crank mated to an 11-34 cassette will give you the same bailout gearing as a 40/46 while also giving tighter shift jumps and more overall gear range.
But hey, you do save a whopping 50g by going 1x, so if that is the driving motivation, it makes sense(2068g vs 2108g).
mstateglfr is offline
Old 10-09-19, 02:41 PM
BigPoser
BigPoser's Avatar
Quoted: 250 Post(s)
Thanks all. I'm going Di2 and 1x. Mtn Di2 rear derailleurs will most certainly work with road Di2 shifters. Common actually.
I ended up finding a 38t chainring from Wolftooth so I'll go that route with a 11-42 in the back. Should be good enough for just about everything out there.
BigPoser is offline
Likes For BigPoser:
Old 10-09-19, 05:32 PM
john.b
john.b's Avatar
Quoted: 11 Post(s)
Unfortunately, Shimano killed Di2 for 12-speed MTB. Otherwise, that new 10-45 MTB cassette plus a 12-speed Di2 RD and the new GRX Di2 brifters would’ve been perfect for 1x gravel.
Honestly, for all the fuss Shimano made this past spring about their big “gravel listening tour”, I still don’t think they get it.
john.b is offline
Likes For john.b:
Old 10-10-19, 01:04 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
How many people riding gravel need lower than 31×34 really?
redlude97 is offline
Old 10-10-19, 01:33 AM
HTupolev
Quoted: 1978 Post(s)
Liked 1,298 Times in 630 Posts
Probably a large majority of people who ride any kind of mountainous stuff. In my area, we've got plenty of gravel climbs that average 12% or more over a mile at a time. And check out this gorgeous road that one of my friends recently found:
I suppose "need" is a strong word, but if it's a question of what's optimal, I actually think that most road bikes in hilly areas should come with ratios of 1:1 or lower, whether intended for gravel or otherwise. Even in the paved lowlands around here, I see tons of people badly bottomed out on their gearing during climbs, and people avoiding very fun roads simply because the gradients get steep. That's awful.
Ideally, common chainring combinations would span a much wider range than they currently do. From what I can tell, a majority of people on road bikes have very little use for the top-end on modern road bikes. For the weaker riders, a 42-26 or even 40-24 would offer adequate top-end in a 1x-plus-granny scheme, while permitting a comfortably tight-spaced cassette.
HTupolev is offline
Likes For HTupolev:
Old 10-10-19, 06:29 AM
Marcus_Ti
Marcus_Ti's Avatar
Depends on the surface, and how big your tires are.
I have a 30/32 bailout and with 700Cx42mm tires I've needed it if not a bit lower. Could not stand for more power without just spinning the wheel. 15% farm MMR with pea gravel are mean.
Likes For Marcus_Ti:
Old 10-10-19, 07:32 AM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
I run a 1x system with a 34x46 low gear on my diverge. Works well as most of the gravel around me is regularly accompanied by 10% + grades for extended periods.
Bryan C. is offline
Likes For Bryan C.:
Old 10-10-19, 10:48 AM
redlude97
My experience with mtbers and other gravel riders is that a very small fraction will want to ride that type of terrain whatever their gearing. You still need to be able to put out a lot of power to able to get up something like that. All the hard gravel rides have like 5-10% of the participation numbers compared to the easier less hilly rides, and we have lots of mounatains here in the PNW. To me shimano is targeting the 90%+ of the market, the other 5-10% of us have to make do with some tinkering, for example I use an rx800 rd with a 50/34 11-40 with no modification at all for gravel. Could easily go to 46/30 11-42, but still only round up 1-2 other racers to go somewhere that type of gearing is even needed
Old 10-10-19, 11:54 AM
HTupolev
That particular hill is an extreme case, but...
This is partly a chicken-and-egg issue. By and large, you don't need to be able to put out a lot of power to get up steep hills, if you've got appropriate gearing. I've seen very few people fail to have a blast on foothills gravel rides out here, but it's hard to get people to do it if their bike isn't suitable for the job.
This is true even for the lower paved hills in the populated areas. There's zero technicality to paved climbing; if someone says that a paved hill is "hard to get up", that's a problem with their bike.
HTupolev is offline
Old 10-10-19, 01:45 PM
redlude97
Sure, I mostly agree with this. I just don't think gearing is what is holding back the majority of people in the gravel scene. There's been an explosion in that area even before shimano made lower gearing feasible, and certainly Sram and campy haven't taken over in that regard with lower gearing, so as a whole the market doesn't really see it as necessary yet to appease the market
Old 10-10-19, 02:10 PM
HTupolev
This issue doesn't have anything specifically to do with gravel, gravel just puts a bit of additional pressure on it. Insufficient low gearing has been a blind spot in road cycling fashion since the dawn of time. Rivendell Reader 34 is fourteen years old but still very interesting, look at page 26 here: Kozo Shimano admits that 53-39 was standard on recreational bikes mostly because the perception from the company leaders was that cyclists would want cranks that didn't look like Lance's cranks, and also admits that he had a better experience on smaller rings. In other words, he knew that gearing was a problem, but assumed that fixing the problem could be a marketability issue.
I don't know what the solution is, but I don't find the lack of standard options for smaller rings to be good evidence that gearing isn't a significant hindrance here.
HTupolev is offline
Likes For HTupolev:
Old 10-10-19, 02:53 PM
redlude97
I guess I don't see the gravel market as being something that caters towards racers or that persona, which is different from the road side of things in a lot of ways. They picked gearing range choices based on where they think the majority of the marketplace would be interested in. Its not like they don't have the capability to do otherwise since they essentially just changed the pull ratio and cage lengths of their MTB designs to work with road shifters. They have the cassettes already, if they thought there was a huge market and people would be happier with 46-30 11-42 they could have put that out instead
Old 10-10-19, 03:28 PM
HTupolev
Perhaps not, but the "gravel" equipment is still making only incremental changes from current road arrangements. 50-34 to 46-30 is 1-2 shifts out back.
A lot of people don't need anywhere close to a 115" top gear even for paved riding, and could be more comfortable on tighter spacing than an 11-40 offers. What I'd like to see is more practical crank options that support tiny chainrings (smaller than 46-30) and a road q-factor.
I'm not saying that there is a market. I'm saying that there probably should be, and that it's frustrating that the big brands have been so hesitant to even test the waters. Pretty much every mainstream attempt to reduce standard chainring road chainring sizes over the last half-century has succeeded, but it's been baby steps the whole way. That's silly, like watching a programmer script a linear search when a binary search would be far more appropriate.
HTupolev is offline
Likes For HTupolev:
Old 10-10-19, 09:19 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
...for example I use an rx800 rd with a 50/34 11-40 with no modification at all for gravel. Could easily go to 46/30 11-42, but still only round up 1-2 other racers to go somewhere that type of gearing is even needed
You think a rx800 can clear a 42T? I have read a lot of reports of it clearing 40T, but very few regarding 42T.
Been thinking about a RX800 GS or M8000 with a tanpan.
katsup is offline
Old 10-10-19, 10:37 PM
redlude97
Probably with a 46/30 or a 48/31. 50/34 11-40 required a full length uncut chain and the b-screw maxed out on my CAADX. You could flip the b-screw or use a road link easily
Old 10-10-19, 10:48 PM
katsup
katsup's Avatar
Quoted: 607 Post(s)
Chain rings are 48/36 currently so I should be OK there, was just curious if the rx800 cage can clear a 42T with the b-screw alone. I guess one way to know for sure is try it, then buy a roadlink if it fails.
katsup is offline
Old 10-11-19, 10:12 AM
redlude97
Would probably work by why not throw a 34t on there and use the closer spaced 11-40 cassette?
Old 10-11-19, 11:33 AM
katsup
katsup's Avatar
Quoted: 607 Post(s)
Just trying to use the parts I have first, only missing a rear derailleur currently. I may end up going that route eventually.
katsup is offline
Old 10-11-19, 12:18 PM
redlude97
got it, wouldn't hurt to get an inner chainring even if you go with the 11-42. They are usually under $20
Old 10-11-19, 12:32 PM
katsup
katsup's Avatar
Quoted: 607 Post(s)
I was wrong, it does have 48/34T chain rings currently. I'll probably go to a 11-40 cassette once I wear out my 11-42.
katsup is offline
Old 10-11-19, 01:34 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Do I misunderstand what power means? Isn't it true that for a given hill, you need the same amount of power to get up that hill, regardless of what gearing you have? I suppose the limiting factor is speed you're going and if you can keep the bike upright at eg. sub 3mph speeds or whatnot.
Sy Reene is offline
