Go Back  Bike Forums > Bike Forums > Fitting Your Bike
One leg shorter than the other
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 06-17-13, 11:09 AM
LuckySailor
LuckySailor's Avatar
Bikes: Trek 520 total custom build, Cannondale Mountain Tandem, Oryx Mountain Bike
Quoted: 61 Post(s)
Liked 6 Times in 4 Posts
Has anyone ever retooled (drilled and tapped) their crank arm to move a pedal up? My right leg is 17mm shorter than my left due to a car/pedestrian accident that left me with 2 broken legs nearly 40 years ago. All of my street shoes are altered by having a lift added to the bottom of the shoe, but getting custom cycling shoes would cost $12-1500. Not an option! I am considering a cross Canada tour next year, and wanted to be able to clip in for greater efficiency, than going with regular shoes. Thoughts? Thank you.
LuckySailor is offline
Old 06-17-13, 12:19 PM
elcruxio
elcruxio's Avatar
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Quoted: 862 Post(s)
Liked 336 Times in 223 Posts
I might be really wrong, but I thought that the way to deal with different length legs is to use a shim under the cleat which will then raise the foot. I'd say you need a 1cm block under the cleat. Since the natural average difference in leg length is about 5mm the 7mm that you would still have as difference would be tolerable. Maybe. Try it out. I don't think putting shims under the cleat will result in injury, especially if you stop before the possible pain becomes damaging.
elcruxio is offline
Old 06-17-13, 12:28 PM
prathmann
Quoted: 659 Post(s)
Liked 7 Times in 6 Posts
A shim between the right shoe and the cleat was my thought as well. That way you keep the same crank length (and leverage) for both legs whereas retapping the right crank would effectively reduce the crank length on that side.
prathmann is offline
Old 06-18-13, 10:26 AM
zandoval
zandoval's Avatar
Quoted: 966 Post(s)
Liked 1,629 Times in 1,045 Posts
Originally Posted by prathmann
...retapping the right crank would effectively reduce the crank length on that side.
Legs of equal length can be real important when walking and running - But the lever action of the leg during cycling is not as dependant on equal leg length - Especially if its in the lower leg Tib/Fib - At 1.7mm you are only 7mm off from the normal leg diferance in average people witch is 5mm to 10mm - An extra shoe insert on your short leg should solve any problems...
zandoval is offline
Old 06-19-13, 05:43 PM
sreten
Bikes: 20" Folder, Road Bike
Hi,
I'd look for a 165mm crank right side and a 175mm crank
left side for simply using standard pedals and footwear.
rgds, sreten.
sreten is offline
Old 06-22-13, 01:45 AM
Lenton58
Lenton58's Avatar
Location: Sendai, Japan: Tohoku region (Northern Honshu))
Bikes: Vitus 979, Simplon 4-Star, Woodrup, Gazelle AB, Dawes Atlantis
Quoted: 58 Post(s)
Liked 75 Times in 42 Posts
Originally Posted by sreten
Hi, I'd look for a 165mm crank right side and a 175m crank left side for simply using standard pedals and footwear.rgds, sreten.
Asymmetrical. Thanks — good suggestion if not the cheapest.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
Lenton58 is offline
Old 06-22-13, 08:47 PM
mudmouse
mudmouse's Avatar
Bikes: Trek Pilot, X-Caliber WSD, Rockhopper, Allez vita, miyata triplecross
My husband has the same issue. Ask around some LBS and see if they have an extra crank laying around that they would sell cheap. Dh tried that for a while and thought it helped, but eventually ended up having his bike shoes soles and cleats shimmed up by the same place that does his regular shoes. The cost was similar to his regular shoes.
mudmouse is offline
Old 06-22-13, 10:00 PM
1nterceptor
LET'S ROLL
1nterceptor's Avatar
Bikes: 2014 BMC Gran Fondo, 2013 Brompton S6L-X
Quoted: 306 Post(s)
Liked 44 Times in 33 Posts
Speedplay pedals with spacers on cleats.
1nterceptor is offline
bikebreak
Road Cycling
24
06-21-17 11:46 AM
Ali89
Fitting Your Bike
4
06-26-15 12:31 PM
Gordo of Texas
Bicycle Mechanics
6
07-15-14 07:09 AM
totalnewbie
Fitting Your Bike
4
06-27-13 05:37 PM
ForlornEnemy
Road Cycling
6
09-22-11 09:23 PM
