26" MTB rim brake rims
I bought a Shimano dynamo hub, 3N72 32 hole, and I'm having trouble finding any selection of 26" rim brake rims too build it with. The only rim generally available is the Mavic XM317, which isn't a bad rim I suppose. But with all the choices of disc rims I thought I would have some kind of selection. Any ideas on where to find rims? This is going onto my 1990 Trek 7000 bike that I use as a commuter.
Bikes: ...
Quoted: 6591 Post(s)
Liked 383 Times
Bikes: ...
Liked 383 Times
My bad. I just noticed that the rims I have are XM717. That said, I've been really happy with them.
This wouldn't be a bad deal if you didn't already have hubs. Perhaps you could make an offer?
https://www.ebay.com/itm/BLACK-26-MAV...item233376406a
Thanks, but I really only need a single rim. I'll shop around the usual online stores again and see what they have, but so far not much.
Quoted: 184 Post(s)
Liked 67 Times
Here's 5 models to look for: https://www.mavic.com/rims/mountainbi...akes%2B3017_26
I bought a pair of XM317 rims on ebay for $52. I checked my rear hub and it too is 32h like my new dynamo hub so I'll use the second rim to replace the dented rear. It'll be like a new set of wheels. I already replaced the bearings in the old rear hub. I'm still surprised at the lack of choice, but I guess with 29ers and disc brakes, the 26" rim brake rim is no longer in much demand.
A single XM717 costs more than what I paid for the pair of XM317s. They may be nicer but still only 20 grams lighter. We're talking about what started as a beater bike here.
The Rabbi
Quoted: 16 Post(s)
We offer the Synergy, Aeroheat (Dyad), Atlas, NoBS, Cliffhanger Chukker & A23 in 559/26" rim brake configurations. Personally, I commute on 559 Aeroheats and Cliffhangers.
NOBS would be a good durable rim for a beater... https://store.velocityusa.com/p/nobs-26-nonmsw
It's not such a beater bike anymore. I've silenced all the squeaks, clicks and clunks, smoothed out all of the crappy shifting, tightened all the spokes, repacked the hubs and BB, and made it all around nicer. I only wish the frame were in better cosmetic shape now.
Location: southeastern PA - a mile west of Philadelphia
For my two 26” mountain bikes––which I use for commuting and long distance rides––I purchased two Rhyno Lite wheelsets with Deore hubs.
The first wheelset was with Deore 32-spoke M530 hubs (allows rim brake usage only). I paid just $90 for the new wheelset from www.BlueSkyCycling.com roughly 2 years ago via the Internet.
The second wheelset was with Deore 32-spoke M525 hubs (allows rim brake & 6-bolt disc brake usage). I paid $125.00 for the new wheelset at a Performance Bikes shop located 14 miles from my house. This latter wheelset was purchased in early summer of 2013. This same wheelset is currently available at www.blueskycycling.com for $109.98 via the link (date of the link being 12-20-2013):
https://www.blueskycycling.com/produc...-Lite-Rims.htm
These Rhyno Lite rims are double-walled and incredibly strong. You’ll also need to purchase a roll of Velox rim tape for each rim.
Additionally, both wheelsets came with valve stem holes drilled for Presta valves.
Initially, I wasn’t into Presta valves, but they have some positive attributes that have grown on me. While I could have drilled the holes to allow Schrader valves, the rim remains stronger via the smaller Presta valve stem hole.
I run Bontrager H2 26” x 2.0 street tires on these wheelsets (my favorite 26” street tires), inflated to 70 PSI for optimized rolling efficiency. To my friend and cousin’s surprise (who also love these tires), these tires provide a surprisingly smooth ride even when inflated to 70 PSI which allows them to roll efficiently hence, fast for your effort.
Bikes: ...
Liked 383 Times
I totally forgot about the Rhyno Lites. They are a good choice. I stopped drilling out my rims, too. But then again, they finally started making oversized tubes in Presta. Otherwise, I'd have no problem with it...especially on a RL.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
You must not be looking very hard. I see all manner of Alex rims online, as well as Sun Ringle' ranging from lowly CR-18s to the ever-trusty Rhyno-Lites - - both pinned and welded-and-machined.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Bikes: 2013 GT Karakoram 3.0 29er Hardtail
Oh, and schraeder valves? I went to change a flat yesterday and my spare had a schraeder valve but the rim is drilled for presta. I will now check every tube and tire a bike shop sells me. 3 times in the last few years they handed me something other than what I asked for. 26" tube? I got home and it was a 24. 700c tire? After paying as I put it into my jersey pocket I see they gave me a 650. This was an expensive Conti GP4000 also. I had to wait for a manager to appear to give me a refund as store policy was exchanges only, and they didn't have a 700c. (it wasn't that they didn't want to give me a refund, the worker just didn't have the ability to do it.)
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
I always have one of those in my toolkit. I should have thought to use it.
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
^^ Point is you're home now, yet still bemoaning the fact that you have a Presta-drilled rim. Obvious solutions to simple dilemmas seem to elude you.
I should modify a bike to something that I never would otherwise use just because some bike shop clerk handed me the wrong type of tube? I stopped using schraeder tubes 35 years ago.
