Disposable latex gloves
On top of your biking gloves?
Did someone try it to make it windproof/waterproof? Thinking on some cheap solution for the cold temps in the early morning
Quoted: 1221 Post(s)
Liked 629 Times
Sweat is the enemy of warmth imo. If your trying to minimize air flow I'd suggest bar mitts. Those latex gloves will just cause moisture to accumulate quickly, giving heat a rapid path away from your hands. Layering gloves that breathe is the best solution.
Quoted: 5224 Post(s)
Liked 3,581 Times
I can barely get those things on w bare hands, never mind over a glove
this used to be my inexpensive go-to cold-weather solution. the trick is finding another pair of gloves big enough to fit over your regular gloves
The Crab Trap Handlers off the Alaska Coast Use heavy neoprene gloves, 2 pair ,
seawater there is cold.
For just cold, not wet, get pogies ..
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,034 Times
I can tell you that at 10 degrees F, at 70 MPH on a motorcycle, they seem to have no effect at all.
-Matt
-Matt
At the right temperature/wind doesn't sound like a bad idea. You have to experiment with those ratios and let us know the results.
Other concepts
Is Vapor barrier, Perspiration is a way to lose excess heat, by evaporation,
Blocking that perspiration with a vapor barrier stops the cooling evaporation
and also blocks the insulation from holding the wet condensed perspiration vapor,
so when really cold your insulating layer retains it's loft.
an aluminized vapor barrier also reflects heat back in... your space blanket function..
Quoted: 507 Post(s)
Liked 237 Times
There's an explanation of VBL and a lengthy discussion from Andrew Skurka himself here:
https://andrewskurka.com/2011/vapor-...y-application/
Last week I actually saw a cyclist with ziplock bags sticking out of his shoes. It wasn't even in the 30s that morning - low 40s.
Sweat is the enemy. I have a pair of Specialized cold weather gloves from around 2008. They are a two layer system with the outer glove water and wind proof. Can only use the inner glove because my hands freeze with the outer glove on due to sweat buildup. Bar Mitts are a superior solution. You can easily make them yourself out of any waterproof material, too.
Bikes: CO-OP Cycles ADV 1.1, CO-OP Cycles ADV 3.1, CO-OP Cycles ARD 1.3
I found it was much warmer to wear the disposable gloves underneath your gloves. I learned about it a few years ago and since I have "sweaty hands", it helps me keep them much warmer. However, they get very wet inside the disposable glove after an hour........
I got ammex nitrile L size ones from a->z to try out.
On low 40F early morning ride, after some 20 min, it gets sweaty, then I just remove on my traffic stop and move on.
On last Sunday, I was riding under some rain, so had it on top of my bike gloves - after rain passed I just remove them and put into side of my socks.
Then when cleaning and lubing the bike I just used the same gloves and didn't get my hands dirty
So, 100 gloves for below 10 bucks seems a great cheap thing to have around and they are strong enough I can use multiple times without disposing after each use.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I've worn them under other gloves a few times for cool weather downpour conditions.
Something with a waterproof and breathable membrane (like Gore Tex) is likely a better long term solution. Not as cheap initially, but worth it if you're doing lots of cool/cold weather riding!
I work in an operating room and occasionally take sterile gloves home for just this purpose. We have lots of sizes available so I go for size 9 (for those people with huge hands).....I wear them over a pair of those coated freezer gloves when its cold and there is heavy rainfall on my 10 mile commute. My hands are pretty much dry when I get home, much, much dryer than with bike specific ‘waterproof ‘ gloves.
RandomTroll
General Cycling Discussion
7
06-29-16 06:58 PM
WonderMonkey
23
11-06-15 07:03 AM
