Biking in sand(amateur)
Hey
I was wondering if someone have experience in biking in sand. Do I need an fat bike / mountain bike or is my regular street bike enough?
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
For beach sand you want wide-as-possible tires, relatively smooth tread, and low pressure.
For hard-pack sand, like on a road or trail, narrower, gnarlier, and maybe higher pressure.
It's all relative - Define "sand".........
My limited experience on soft beach sand makes me think a wide tire, perhaps a 26 x 2.3" minimum. I'm thinking a medium stud tread for control up front and traction pedaling.
I tried with a mountain bike with 26 x 2.125" tires with light studs and a smooth center line. After some practice was OK. I think if I used 26 x 2.3" medium stud tires with low pressure, perhaps 15 - 20 psi I would be fine.
I tried the loose sand with my new X-Trail bike with 26 x 1.95" semi-knoby tires too. That did not work well. It might have been OK on firmer damp sand by the water with low pressure.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
For soft sand like at the beach you need a fat bike, I suggest tires over 4.5". I tried 4.5" tires on a fat bike and then tried 2.35" on my mountain bike. The 2.35 tires were terrible. Possible over short distances only. The fat bike floated on top of the sand, it barely made tire tracks. The pedaling was easy.
Fredly Fredster
The hard packed sand near the tide is nice to ride with any mountain, hybrid or cruiser. The soft sand sucks. Even a fat bike will dig into soft sand.
Perhaps I'll try the damp sand by the water with my new bike's 1.95" tires one of these days.
Fredly Fredster
I feel better now after reading your post. I thought when people referred to beach bikes, It ment they worked well in soft beach sand too. I wondered why my mountian bike with the 2.125" tires was so tough to ride there. I thought it was just me.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
I thought this thread was going to be about my arch nemesis--sand on pavement.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Define "sand". There are many "sand" surfaces I'd have no problem riding my road bike down. There are "sand" surfaces I wouldn't attempt on my fat bike. What are the specifics of the sand?
Wet sand right by the ocean is firmer because of the water ..
... but you will have to wash the bike off promptly to get rid of the grit & salt..
Quoted: 5223 Post(s)
Liked 3,579 Times
this "back dune" sand was OK with my mountain bike, 2.25 tires front at 21 psi, rear at 25 psi. but when I hit the regular soft beach sand (at the end) I was stopped dead in my tracks
would love to try a fat bike on a favorite 2 mile stretch at Race Point to watch the whales. I usually walk it, except for years I get an oversand permit for whatever 4x4 I'm driving
Tragically Ignorant
Liked 9,095 Times
Some of the road rash was on my face. Sand tastes bad.
Likes For Lemond1985:
Quoted: 4559 Post(s)
Liked 2,802 Times
That's what the Schwalbe Big One and G-One were developed for -- sand racing, where big light balloons work best. They'll fit any frame with enough clearance. A friend used the Big Ones tubeless on his gravel bike for a few months and liked 'em -- they're fast, comfortable and stable, but wear quickly on gravel. He switched to something else after those wore out.
I kinda wish I'd bought a set a couple of years ago when Jenson USA was blowing out the then-discontinued Big Ones at around $15-$20 each. But they'd fit my bike only if I removed the front derailleur and switched to a single chainring. Instead I got the Continental Speed Rides, which are nominally 700x42 but measure closer to 700x38. They'll clear my bike and are good on gravel but not quite wide enough on soft sand. Unfortunately the agency that maintains the gravel paths on our MUP uses plain sand to fill potholes, and if you don't watch very carefully it's easy to wash out on those patches.
Bikes: 1973 Coventry Eagle, 2016 Mongoose Argus
fat tires and spring fork
Momentum becomes problematic when hitting trampled sand, which bounced enough to lose control unless lower pressure, which made pedalling too hard... I ended up with a Lauf Carbonara front fork to absorb vibrations
and rode that combination pre-dawn to scout for sea-turtle nests, texting crews to mark or relocate them before beach replenishment resumed at daybreak.
Likes For blekenbleu:
