Who makes, or similar shifter mount
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
I saw this in a classified ad recently, it even said who made them. But I have forgotten... And now, may be useful...
Sr Member on Sr bikes
Not quite sure what I'm looking at there. It looks like a standard downtube shifter attached to something and is it wrapped into the bar tape? Where is the other shifter?
Dan
Dan
Quoted: 284 Post(s)
Liked 385 Times
It was on an early 90s Trek 1200. Had been used for triathlons. The mounts fits standard downtube shifters and yes, mounts under the tape. They do come in pairs, but this bike only had 1. I looked them up a couple months ago, but just can't recall the name. If the bike had been just a size bigger, I might have gone to look at it...
I've been doing triathlons since the early 1980s. I've never seen that particular attachment. It almost looks like a DIY contraption. It just seems kind of clunky and inconvenient. I'm trying to imagine my thumb reaching down to that lever to shift...or even reach to pull it back. And how in the world does the bar tape hold it in position tight enough to push/pull on the shift lever? It just looks like that isn't where it is actually meant to be mounted.I'd rather have the shifter on the down tube than that setup. Dan
elcraft
Bad example
Quoted: 823 Post(s)
Liked 204 Times
Quoted: 284 Post(s)
Liked 385 Times
Quoted: 284 Post(s)
Liked 385 Times
Yes. I tried them, but they did not work very well for my use. I mounted Suntour shift levers on them and founded that the cable pathway on the take-off did not line up with the pathway on the lever. I suspect they were designed for Shimano levers, but I did not try that out (I just will not use Shimano stuff).
Thanks all!
