2019 giant revolt advanced 2 vs advanced 1
Quoted: 14 Post(s)
Looking for some advice
I am looking at the 2019 Giant Revolt Advanced 1 and 2 . I have never used a the SRAM Apex 1x11 , only the Shimano 105, 2x11.
My only concern with the 2 is the Giant Conduct SL, hydraulic , I haven't heard alot of good things about this.
I will use the bike 50% on the road and 50% on gravel . Based on this usage which would be a better option
Thanks
Thanks
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Thanks
Thanks
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
As mentioned the '20 Revolt 2 is full 105 hydraulic now, but they changed the colors. I really wanted the metallic orange, so I grabbed a '19, should be in this week. I test rode one with the Conduct brake system and it seemed to work well enough. That being said, my shop has some 105 hyd takeoffs that they're going to put on for me when the bike comes in.
Quoted: 733 Post(s)
Liked 815 Times
Picked her up last night, she weighed 21.8lbs with XT trail pedals and the full 105 hyd setup. I've read that the Advanced 2 is usually around 24lbs, so def some decent weight savings by ditching the Conduct system.
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
For sure. And the tires are also pretty heavy. If you wanted to get a lighter set of road wheels, you could cut quite a bit of weight off of this.
My Medium Advanced 2 weighs in at 9.6kg (just over 21 lbs) with the stock Conduct system but no pedals.
The conduct system is ugly but it works plenty well enough, much better than my previous cable Spyres - although full 105 hydro would be better. I do prefer the shape of the cable 105 shifters though and they are cheaper to replace if you wreck one.
Other points to note is the 2020 model shows SX2 wheelset rather than PX2, which is a lower model (although I’m not sure of the differences) and 38mm tyres instead of 40mm. Doesn’t list them as supplied tubeless either, but I would imagine they are on a bike at this price point.
Oh, and the $200 price increase. You guys in the US get a choice of colours too - the 2020 grey beige is rather nice!
I have the 2019 Revolt Advanced 2 with 105 shifters. Can you guys tell me "which" 105 this is? i.e. 5700, R7000, etc... I need to order new hood covers...
Thanks
Thanks
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
The model will be listed on the plastic body underneath the rubber hood.
