First big dose of reality after installing computer.
I'll assume this comes up a lot.
Current setup is a stripped down Vilano aluminum roadbike (first bike, got it on craigslist for $25 - so I can't really complain). I've removed as much useless junk as possible. Specs are:
- Shimano Tourney 21-speed setup.
- 50t/xx/xx chainring
- Highest rear cog is a 14t
- 700c/25 front and rear tires (cheap tires and stock wheels)
- Steel front fork
- Aluminum seat post
- Steel crank arms (pressed-on square pattern)
- Weighs approx 27 lbs.
- No water bottles, nor water bottle brackets
So I've been riding this thing for a couple weeks now, and yesterday I finally put a computer on it to see where I'm at. Well, on flat'ish roadways, tucked on the down bars, I can put a lot of oompf into it and managed to only push like 25.4 mph (50t/14t), but don't have cadence numbers on that (felt like a lot lol). I can approximate it using math, but I have no factual data. I'll double check the calibration of the computer for the speed reading, but I'm assuming it's accurate the way the instructions suggest I set it up. Without detailing cadence I doubt that's useful info. But I was surprised at the numbers. I've watched and noted people maintaining 26 and 27 mph over lengthy rides, yet they may be chugging a 53t front ring and 11t rear cog for gearing. I'm in pretty decent shape, and have been distance running for years (middle distance strength training), and I'll also humbly admit that high intensity cycling isn't exactly easy. I'm willing to accept that I need to condition more towards cycling, yes.
The only other rear cog I can get for this setup is a 13t, which isn't much, but is worth a couple mph assuming equal cadence. I can actually get as gianormous as a 58t front ring lol. Lastly, I'm willing to lighten my beast up some, also - but I feel this benefits acceleration more than anything. I mean, I've got less than $100 in it so far, so i'm not complaining. Eventually I'd like to do some local races, but otherwise would like to ride faster bc speed is kinda fun.
With all this, what can I do to get more speed ? Cheers!
- Steel front fork
Quoted: 551 Post(s)
Liked 277 Times
How long have you been riding/training?
There is a big difference comparing a solo vs group effort. Cutting through the air is much bigger factor and force at those speeds than the bikes weight. On the hills and slower speeds, the overall weight is a bigger difference. A quick fix on the equipment side maybe some better rolling efficient tires. There are no quick fixes for the "engine" side unless your fit and comfort is not right. You were not running at 25mph, you are already going a lot faster than you were before.
Just under a few weeks, now.
Lol I'm about to get squashed - I see it coming!!
Fwiw, I'm in decent distance running shape, yet it may not really compare equally for cycling, unfortunately. I love going fast - so topping out at 25.4 mph won't cut it.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
15 MPH to 18 MPH average speed is more likely for most riders on solo rides more than 20 miles.
-Tim-
Only very strong riders and likely not solo efforts.
Many cyclists and runners are surprised at the level of difficulty encountered when they take up the other discipline for the first time. Fitness in one discipline does not correlate well to fitness in the other. I think you are seeing this so give it time and keep riding.
-Tim-
-Tim-
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
- Steel front fork
- Steel front fork
If you are seeing people maintain 26-27mph over for lengthy rides, then you are seeing high amateurs or pros. Why on earth would you ever compare yourself to them?
To get to where you want- buy new wheels that will accept a cassette and that will get you a cog that is 11t or 12t small.
A 50t-12t gearing ratio will get you 30mph at 90rpm. Then go ride that for 50mi and you will reach your goal of riding as fast as the exception you reference in your post.
...or just buy the freewheel that has a 13t cog and learn how to ride better. You are clearly held back by inexperience and conditioning(cycling specific) and the only way to improve is from experience.
a 13t cog on the freewheel will get you to 27.5mph at 90rpm. Unless you can hold that for a 50mph ride, why spend more $? It wont make you faster. Learn how to climb hills(and steady inclines) faster- that will increase your average more than buying a bunch of stuff.
I've been following some of the pro riders on the Tour de France in Strava and that's roughly their pace. For the world's top pros. Riding in a massive peloton.
Most mortals doing that pace are likely doing a TT with aero bars, or riding on a flat course, or in a paceline. Holding that speed over long distances takes a strong rider. Don't hold yourself to that, you'll get frustrated. Starting out, a 15mph average (or even less if you're in a hilly area) is probably good and build from there.
With your 50x14 gearing and 700x25c tires, 25.4mph looks to be about 91rpm cadence. That is a good average cadence for the entire ride, so if it felt really fast you could probably develop your form more to spin better. You should be able to spin up well above 100rpm although I still find my power falling off above about 110 rpm when pushing max speed.
If you are in search of top speed (I can relate) then you will want a 53x11 gear eventually. For now, just continue to develop your form and cycling fitness. When you can spin your current gearing over 30mph then I'd start worrying about a new rear cassette.
Quoted: 20810 Post(s)
Liked 9,456 Times
Your gearing isn't holding you back so much as air is holding you back - the faster you move through the air, the harder it is to move through the air.
For example, even though there's the same 3 mph increase, the difference in power required for 14 vs 17 mph isn't a heck of a lot, but the difference between 22 vs 25 mph is significant. I mention this because, all other things equal, simply going to taller gearing isn't going to make you faster - the power requirements at a given speed are (more or less) the same regardless of gearing, but the gearing gives you freedom to find an optimal cadence for your effort.
With your 50/14, you're looking at ~90 rpm for your 25mph effort - that shouldn't be spinning-out; for a lot of people, that's an average cadence.
Likes For WhyFi:
So from what you guys are saying, I just need more time with the gearing I have and work into it. And the better I get at riding, the closer I'll be to optimizing my average speed with the bike the way it currently is set up. Makes sense, and is simple enough to understand.
At the very least, it seems like I'm right in line for my level of experience. For the most part I was between 16 and 19.5 mph where I was riding.
Plus, I'm not completely comfortable on the bike yet, either - I need a new seat or something, because this one sucks donkey balls.
Quoted: 741 Post(s)
Liked 412 Times
Micheal Woods is former runner. I think he had a sub 4 minute mile pace. Tejay is a former runner also, I think. They both are now World Tour riders, but it doesn’t happen overnight.
Quoted: 551 Post(s)
Liked 277 Times
Non omnino gravis
I have personally never seen anyone, at any time, post a road ride with a 26-27mph average speed-- including Zwift. Even pro races seem to average around 25mph, and that's a peleton of 150+ of the world's best cyclists. Closed course time trial by a pro? Absolutely. Closed course criterium? Sure.
But for a recreational road rider, a ride averaging +19mph is in the top 1% of people out there.
Likes For DrIsotope:
Quoted: 18419 Post(s)
Liked 15,559 Times
Quoted: 4806 Post(s)
Liked 3,929 Times
And more perspective - use this time on your current bike to observe your position on the bike. Watch others,. If you have a chance to ride with racers or other good riders, ask for their opinions on your position on the bike. Listen - to them, to your body. Getting your body in condition to ride fast and putting it in a position to do so is by far the most important thing. The bike is just a tool. Good tools are better but good tools don't make a carpenter.
I did my first year of racing on a biketha tfit me poorly. I didn't know. That year of being fast, I worked in a bike shop. The mechanic encouraged me to buy last year's best bike, still boxed up in the basement. I did. It fit. And my riding times plummeted and kept falling all that summer. But without the riding I did over the previous years on that poor fitting bike, I would not have been there. (And those times fell and speed increased riding the same gears, wheels and tires of my older bike. It wasn't that the bike was "faster". It was that it fit.
Oh, and just to show what race incentive and race conditions (a field of 120 riders) can do: that summer of the 5 hour 100 miler, I rode a 105 mile much hillier race with a very competitive field. First 30 of us averaged 26.6 mph! Race speeds are a different animal.
Ben
Likes For 79pmooney:
Likes For nomadmax:
Quoted: 942 Post(s)
Liked 527 Times
You just started riding a few weeks ago. You need to cut yourself a break. Doesn’t matter how fit you are in other disciplines. The fact that you are fit just means the gains will come quicker as long as you stick with it. Your 25mph top end is probably about right. Average speeds solo are very different than group/bunch riding where you are in a paceline and benefiting from the draft. You’ve heard of the Richter Scale? Once you start averaging over 20mph solo, each mph above that is just what that’s like effort wise.
Likes For jadocs:
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
If you want to get faster on solo efforts, there is not a good substitute for training. Putting in a lot of hours and miles will raise your speed, to a point. After that, structured training is beneficial.
Riding with a group will also generally result in faster average speeds. I've had some crazy fast (for me) runs with strong groups as small as three, and with a larger group with strong riders at the front, you'll literally get sucked in and pulled along. Learn to draft and ride safely in a paceline (if you do not already), join a group, and try not to get dropped.
If you just want max speed, go bomb down some hills Some of the 5'2" wonder women I ride with have hit 50 MPH this way...
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Very true. The only people pushing 27 mph solo for 20+ miles are pros or very quick amateurs who are training for time trials and using their TT bikes/all the associated gear, or people riding in very fast road races. Or maybe they're just riding with a massive tailwind and not turning around.
Quoted: 5224 Post(s)
Liked 3,582 Times
seeing a max speed on your computer for a stretch of road isn't an average speed for the entire ride. I don't think the OP was saying that
Quoted: 1067 Post(s)
Liked 259 Times
The bike isn't worth upgrading in any way.
Just do what is required to get it working properly and ride it.
The 50-14 high gear is not a problem and won't hold you back.
After a few months if you are still into it, and can afford it, look for another bike.
Likes For woodcraft:
Not sure of your budget but if your bike still has stock rims look to upgrade them . That should add a couple mph increase to your speed .also when u get another bike u can switch the rims. But in general keep at it and try to increase the miles by 10 percent each week and in about 20 weeks or less you should be able to reach 30 mph not mantaining that speed but hitting it and holding it for a min or 2 is a good start.
Quoted: 18883 Post(s)
Liked 10,646 Times
