Go Back  Bike Forums > Bike Forums > BMX
13T Freewheel
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
13T Freewheel
Old 05-11-08, 07:56 PM
minichamp31
Yeah. I Race.
minichamp31's Avatar
Bikes: Custom Race, 2007 GT Bump, 2007 Gt Powerseries Pro, Dyno VFR
13T Freewheel
I searched and found nothing. I have a flip-flop hub and want to run a smaller gear(I'm running 44-16). I would like to run a 36-13, the rollout is a little higher and that's okay. So are the 13T freewheels durable enough for racing?
minichamp31 is offline
Old 05-11-08, 09:30 PM
ChristAir
chicken pecker
ChristAir's Avatar
Bikes: everything except a roadbike
I suppose, most GOOD 16T freewheels have 4 pawls. The highest count I a 13T I've found is 3 pawls (made by Odyssey, check Dans Comp). You're giving up durability for lighter weight, and that awesome look of a lower gearing.
ChristAir is offline
Old 05-11-08, 10:54 PM
wethepeople
Long haired freak.
wethepeople's Avatar
Bikes: 2011 SE Old Man Flyer.
It would be higher gearing, not lower you knob.
High gearing:
Low gearing:
I lost all of my photo's of that bike, now I'm stuck with crappy pink**** ones...
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
wethepeople is offline
Old 05-11-08, 11:02 PM
ChristAir
chicken pecker
ChristAir's Avatar
Lower teeth count! Lower teeth! I'm a math major with a 3.6 GPA, I know what I'm saying. You should consider a job in comedy.
Old 05-11-08, 11:07 PM
ChristAir
chicken pecker
ChristAir's Avatar
And "knob"?
Old 05-12-08, 04:55 AM
wethepeople
Long haired freak.
He's keeping the front gear the same, only going lower in the back. That means he's getting a higher gear.
I don't give a **** if you're a math major or the good lord himself, you're stupid and it's spreading through the BMX forum like cancer. Go away.
Old 05-12-08, 05:35 AM
bmx2478
bike ri-durrr
bmx2478's Avatar
Bikes: one with wheels
wtp is right.
Christ, it's alright if you don't know everything about bmxing, that's what the forum is for, learning.
But it really is getting annoying that you post about 1000 times a day, most of which are useless or incorrect information.
bmx2478 is offline
Old 05-12-08, 07:57 AM
ChristAir
chicken pecker
ChristAir's Avatar
Learn to read WTP. His front sprocket will be changed out as well.
Old 05-12-08, 08:04 AM
ascend
free mallocs
(36/13 = 2.77) > (44/16 = 2.75). Just. Changing both is still going to make his gearing higher, not lower -- though by such a small margin it doesn't matter.
ascend is offline
Old 05-12-08, 08:08 AM
ChristAir
chicken pecker
ChristAir's Avatar
I know that! Smaller gears have always been hot. I'm saying 36/13 looks a whole lot better than 44/16. I am not talking about changing gear ratios.
Old 05-12-08, 03:23 PM
NJ Jersey Fresh
Im running out of popcorn...
NJ Jersey Fresh is offline
Old 05-12-08, 04:51 PM
minichamp31
Yeah. I Race.
Ok, to settle this I will be getting a smaller front sprocket and freewheel, which will in turn actually make my ratio a little bit higher. So I guess you could say I'm getting a higher gear, but I'm getting smaller sprockets.
Old 05-13-08, 12:48 AM
fuzzbox
Your imaginary friend.
fuzzbox's Avatar
Bikes: A sweet Quamen ATL custom, GT Mach 2
Did you ask your local stores? They could probably dig around for you and order without you doing work.
Every passing minute is another chance to turn it all around.
fuzzbox is offline
Old 05-14-08, 04:57 PM
minichamp31
Yeah. I Race.
No, I haven't asked any of my LBS's yet, but I could. And do you mean I could get one without ordering it?
