Need new gravel bike suggestions
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times
I'm sure several have asked for new gravel bike suggestions, but new models and deals are constantly changing so... I'm asking again.
Needs include lots climbing, real gravel roads, maybe easy mountain bike trails too.
I can't imagine a 50/34x11/32 will do it since that is the same gearing on my road bike. The hills here in the Catskills demand that type of gearing for a Clydesdale like me, but still a fast B+/A rider
Please post suggestions w/ links where to buy. Budget about $2,000
Thanks
Thanks
Overview:
Complete Bikes - Black Mountain Cycles
Disc:
MCD Complete - Black Mountain Cycles
Rim:
Monster Cross Bikes - Black Mountain Cycles
You can pick/swap out parts as you desire, Mike will work with you on that. I am going with a compact crank 48/32 and 36/11 in the back so that gives this Clyde a better than 1:1 lowest gear.
Disc:
Rim:
Thanks
Thanks
https://www.diamondback.com/haanjo-exp-carbon
Triple crank (for climbing options) / carbon frame / Spyre mechanical brakes.
If there's any 2017's left, then I'd consider that for an option.
Just how fast you can ride it will depend on you, I suppose.
For your planned use of the bike I really think you'd need to go alu or carbon for a bit of weight saving over a steel frame.
A lighterweight tyre would help with rolling.
Quoted: 185 Post(s)
Liked 36 Times
Gravel Bike
Thanks
Thanks
Quoted: 56 Post(s)
Liked 14 Times
For ready made, gearing that you're requesting, I'd say the Specialized Diverge for 2018 in the E5 alum frame would get a bike that's under 2000, takes a wider tire, is 105 equipped, using a 48/32 crank, and 11-32 behind. Not sure what your local dealer situation is however.
Quoted: 185 Post(s)
Liked 36 Times
I was also quite tempted by the gearing of the Diverge (compared to the compact that most of its competition sports), but 38s are effectively the widest tires that the bike will take. This is only a problem on the E5 models, not the carbon, but is a pretty big deal for some buyers. I would also say that $1900 is a little bit spendy for what you get on the E5 Comp. About $300 of that is for the "Specialized" on the tube. Still, test rode a couple last week and they were very nice bikes.
Didn't see tire size requirement in your post. Raleigh has the Tamland 1 for a hundred dollars less, similarly equipped, that would also get you a 46/34 crankset, so not quite as low, but decent. I'm afraid I'm not sure where to recommend a gravel bike with 105 level drive train that's 1600 or less, so if you already know of that product, I guess I'd go with that. The Diverge is one that still has short enough rear stays, etc to behave like a real road bike, cause that's basically what it is...just takes a little fatter tire. Personally, I ride a lot of gravel on 700x35's that in reality measure 38, I ride in a lot of wind, and deep, sandy gravel. The bike they are mounted on will run up to 44's, but I so far haven't felt the call to go bigger. I tend to ride a diverge with 700x32's about as often. I like big tires fine, and don't find them any sort of a hindrance to my riding, but I tend to take a straight up road bike, or the diverge for group rides.
Quoted: 56 Post(s)
Liked 14 Times
Wasn't my post. Just pointing it out in case he cared. A lot of people buy gravel bikes with the plans on equipping really wide tires at least on some rides.
That really isn't a fair comparison. No one pays full MSRP for a Raleigh. Their website regularly discounts that bike down into the $1400s, even if you don't use the corporate account trick. Amazon and Nashbar were selling it for $1300-$1400 all year. You just don't see that sort of discount on Specialized unless it is prior year inventory liquidation.
Fuji lists their Jari 1.3 with 105 and TRP HY/RD brakes for $1800. They don't have a 105+Spyre model but it is safe to say that if they did it would be noticeably less than that. Cannondale sells a 105+Spyre Synapse for $1499 (endurance, not gravel admittedly). Jamis sells a Renegade model with Tiagra+Spyre for $1200. They do not have a 105+Spyre (wish they did), but it is safe to say that it would not anywhere near $1900. Diamondback's Haanjo Trail has Ultegra and hydraulics for only $1999. GT's Grade Alloy Expert has 105+TRP HY/RD for $1449 also, but that price is ridiculously low for some reason.
I am too lazy to look for other comparables, but the only other brand I can think of that asks that much for a 105+Spyre gravel bike is Norco. Undoubtedly there are others, but I bet most/all of them are boutique-y. $1600-$1700 is a more appropriate price when you are not paying a brand premium. Don't get me wrong, if they can get it (and they obviously can), more power to them. Their checkered history of litigation aside, Specialized has earned their brand cache. I even seriously considered it and only ruled the Diverge E5 Comp out because of the tire width issue.
Raleigh has the Tamland 1 for a hundred dollars less, similarly equipped...
The Raleigh tamland, willard, and roker can be a great bargain if you time the purchase right. I bought a brand new tamland off eBay for under $800 last fall.
Here are two from Kona and Specialized.
Kona Rove NRB - 650B plus size. My wife has one and she loves it.
Specialized Sequoia Elite - although somewhat heavy (beefy steel frame), this is a pretty neat setup that can handle big rubber and has a really forgiving gear ratio.
Both are well within your price range. Both can be used on rooty singletrack. Both have tubeless-ready rims with tires that can be run tubeless. Both have through-axles, tapered headsets, and carbon forks.
I think you need to go to a Spec or Kona dealer to get them.
Quoted: 352 Post(s)
Liked 8 Times
Quoted: 8 Post(s)
I didn't like the cable brakes on the Tamland either.I bought a Diamondback Haanjo Trail Shimano hydraulic, brakes,700 x 40 tires,2x11 46 36 front 11x 31 rear.I liked the Raleigh stuntman but decided it was to heavy and didn't want 1x11 on gravel bike
I got the Jari 1.3 a few months back on sale for $1500. Just road the Black Fly in the Adirondacks a few weeks ago and the bike was great. Gearing was plenty low. Only issue was a flat about 10 miles from the finish. 35's are a pretty nice middle ground between on, and off road use. For grave racing I would definitely fit bigger ties next time. Stan's says I can go up to 45 mm on the stock wheels.
Do you want something racy and road bike-like or more upright and touring bike-like?
If the former, I like the Trek Checkpoint ALR 5 and Specialized Diverge Sport . If the latter, I like the the Salsa Vaya and (similar) All City Space Horse. All are in your price range. If these don't work, there are about 50 bazillion other options.
Quoted: 1218 Post(s)
Liked 298 Times
see what you can get custom built for $2k
https://www.chumbausa.com/new-produc...um-coming-soon
when I think jeep trail & with light mtb trail, I'd go heavy and big tires.
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
Frame and steel unicrown fork is $1450. Frame and carbon fork is $2k. Not much room for the components.
Bikes: Cube Agree and others . . .
Quoted: 11 Post(s)
Warning: bitter buyer's remorse rant follows. I would avoid the Sequoia Elite at its nominal retail price. I have one and I love most things about it, except I hate its weight. It's just too damn heavy. I spent months trying to ignore the fact that it's a tank, though often it can be a lot of fun. I literally called the shop that sold me the bike this morning, hoping for a decent trade-in, or cash, but of course that ain't happening. So now I'm weighing (ha) options like lighter wheels, lighter seat post, etc., but I think I'm just going to chalk it up to my N+1 foolishness, since the frame is the main weight culprit. I suppose it might make a decent camping/touring, "adventure" bike, but I don't do that, and it's still too heavy for the price. It's now my (expensive) grocery hauler.
Quoted: 15 Post(s)
A warbird apex 1 might fit your needs, too - and it is under 22lbs stock. Sort of stuck with that paint scheme, though.
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
The Haanjo Trail with full Hydro Ultegra is something like $1300 after the corporate discount. That's pretty ridiculous.
https://www.diamondback.com/road-bik...njo-trail-6940
2019 Salsa Warbird
2019 Salsa Warbird
Liked 298 Times
However!!! for single track, jeep road, off the beaten path, hills! , loads, extra water, I am guessing that coasting down the hills, and plodding along the flat ridges enjoying the views a 36 or 38 is enough.
Quoted: 11 Post(s)
I'm not certain. It's a big frame and has racks right now. I'll be taking them off. I'll weigh it then. I'm also thinking about new wheels, but I'm not enthusiastic about that option. I'm pondering trading it in and getting a decent fixed-gear bike. I'll post the weight this weekend.
