What is 410 steel bicycle tubing?
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times
I recently bought a 1986 Raleigh Sport that is designated as "all steel Raleigh 410 tubing". What is that?
I've seen one post that said it's the same as what is now referred to as "hi-ten" steel. Is this correct?
Thanks!
Thanks!
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Most likely. The numbers usually refer to the metallurgical mix in the tubing but that Asian bike might just have a sticker so it has something to proclaim. As we used to say about some bikes, "All the CroMo is in the sticker." However, the Google tells us that 410 is stainless but I doubt your bike is made of that.
Likes For thumpism:
Quoted: 171 Post(s)
Liked 278 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
They don't even spec the tubing in the catalog, so it's a good bet that they used straight-gauge high-tensile steel for the Sports model. As they had for decades and decades before.
RUSA #7498
Quoted: 171 Post(s)
Liked 278 Times
So this 410 stuff is probably the same run-of-the-mill tubing that was always used on the Sports?
Liked 2,568 Times
That's my thinking. Maybe not the same exact alloy as was used in 1936, but you have to think that if they were using chromoly and/or butted tubing on this model, they'd say so. You don't keep that kind of thing a secret if you can charge more for it.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Most of the old Raleigh 3 speeds were 1020, 2030, and possibly 1040 steel.
1020 is a low carbon (0.20%), low nickel steel. The 20xx series are higher nickel alloys with more carbon (0.30% for 2030, 0.40% for 2040). The 41xx series are chrome molybdenum alloys (with 4130 being what most "chro-mo" frames use).
All steel alloys basically have the same density (weight per cc). What changes is strength. The 1020 steels are down around 410 MPa, I'm going to go out on a limb and say this may be where the "410" designation comes from the 20xx steels around 480 MPa, and 4130 is around 590 MPa. As strength goes up, tube walls can be made thinner which makes the frame lighter. In theory a straight gauge 4130 frame can be 43% lighter than 1020 and 23% lighter than 2030. In actuality, the "high-ten" frames were often over-built for durability and to allow for steel quality variation, so two or more times the weight of a 4130 frame is not uncommon.
Likes For dedhed:
Liked 2,568 Times
I like the way you think, @dedhed.
Likes For ThermionicScott:
Quoted: 171 Post(s)
Liked 278 Times
SE Wis
Liked 3,401 Times
Besides "410" has more cachet than "The cheap heavy stuff"
Likes For dedhed:
Likes For JanMM:
minimalist cyclist
Bikes: yes please
Quoted: 1120 Post(s)
Liked 1,643 Times
Likes For Deal4Fuji:
Quoted: 171 Post(s)
Liked 278 Times
Likes For riverdrifter:
If you build with a higher strength steel , you can use less to do the job (thinner tube wall) but that costs more
And requires a more careful building, slowing production volume.. per hour ..
Likes For fietsbob:
