Go Back  Bike Forums > Bike Forums > BMX
All City Def Wish ? Vintage ?
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
Old 09-03-20, 09:48 AM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Liked 781 Times in 498 Posts
All City Def Wish: fixed gear bmx 29er large frame velocity wheels, rare bike.
I recently bought this bike thinking it would be fun.
Can not find much info on the net for such a model so looking for more help.
It is large and fits me pretty well. Very solid and comfortable to ride.
Heavy duty steel frame with one lug at TT to HT.
Below is what I did find on the web and Im not even sure its for the same model?
If you like your fixed gears with fat meats the Def Wish is for you. It's great as an all-arounder or a 700c fixed freestyler.
It’s got a mid BB, 14mm dropouts, 45/45 internal headset, and updated geometry. We’ve also redesigned the headtube, gussets, rear end, and given it larger overall tubing diameters. The crown jewel of this beast though, is that it fits a 29’er tire slammed without the need for dramatic dimples on the chainstays.
The Def Wish is sold as a frame only, and was designed to be used with our Dropout fork.
DESCRIPTION
The Def Wish continues the evolution of fixed freestyle 700c bikes and sets a new standard for monster fixed excellence. It’s got a mid BB, 14mm dropouts, 45/45 internal headset, and improved geometry. We’ve also redesigned the headtube, gussets, rear end, and given it larger overall tubing diameters. The crown jewel of this beast though, is that it fits a 29’er tire slammed without the need for dramatic dimples on the chainstays.
joesch is offline
Old 09-04-20, 08:05 AM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Can anybody explain the rear dropout drillout's?
I assume without a screw that helps prevent tire slipping, some type of add-on is possible to hold the axle in place?
As pictured, the current setup has the tire very far back so this will probably be an issue that I would like to improve.
TIA for any responses ...
joesch is offline
Old 09-04-20, 09:05 AM
REDMASTA
REDMASTA's Avatar
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times in 64 Posts
change the tires and gearing and do what you like with it. the axle nut holds the wheel in place nothing else should be added.
REDMASTA is offline
Old 09-04-20, 03:54 PM
joesch
joesch's Avatar
Quoted: 601 Post(s)
It very common to have a screw that helps hold the axle in place. Even more important with single speeds although common on nice steel road frames. I just had not seen the hole cutouts before and figure they have a purpose since drillium to save weight on this kind of frame would be silly.
joesch is offline
Old 09-04-20, 08:34 PM
Bikerider007
Bikerider007's Avatar
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times in 30 Posts
Bmx have become more like road with 29"/700c size and derailleurs now. This looks like a beefy FGFS with some bmx touches.
Bikerider007 is offline
Old 09-04-20, 11:15 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
All City dates from 2009 ish and started out making bikes for niches in the fixie market. This looks like such a one. Bikeforums actually has a “fixed gear freestyle” subforum but I don’t think it’s active.
Genesis 49:16-17
Darth Lefty is offline
Old 09-05-20, 07:45 AM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Yes much heavier than I expected especially with the current wheel/tire setup. The tires are new knobbies so I will replace with some more slick types for practicing some free style ... want to learn to slide stop.
joesch is offline
Old 09-05-20, 08:19 AM
Darth Lefty
Disco Infiltrator
Found this, which matches your ad copy text with more detail
https://allcitycycles.com/blog/introducing_the_def_wish
Genesis 49:16-17
Likes For Darth Lefty:
Old 09-05-20, 09:49 AM
Bikerider007
Bikes: Yes
Quoted: 460 Post(s)
A big part of FS and skid is the gearing.
Old 09-05-20, 09:50 AM
REDMASTA
REDMASTA's Avatar
Quoted: 278 Post(s)
no they are not meant to hold the wheel. they help align the wheel and adjust chain tension. they are backed off after the axle nuts or bolts are torqued correctly to hold the wheel. relying on those screws is a good way bend them and get stuck in your frame. look for the recent post with a all-city big block where this happened.
REDMASTA is offline
Likes For REDMASTA:
Old 09-05-20, 02:23 PM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Yes good explanation. Alignment and bolt tensions are keys to not impacting the backed off screws
joesch is offline
Old 09-05-20, 02:56 PM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Darth Lefty Thanks great ref
joesch is offline
Old 09-16-20, 02:32 AM
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 886 Post(s)
Liked 1,000 Times in 526 Posts
That looks like a great bike, I would like to have one.
Hate the straight fork though.
bwilli88 is online now
Old 11-04-20, 05:50 AM
hsuBM
jj
Quoted: 140 Post(s)
Liked 110 Times in 78 Posts
It will be Vintage in 15-25 years. Right now it’s just old and weird.
As an investment, you can pull the wheels and bars with their grips, wrap them in something protective and box them.
Get some other wheels with brake surfaces and some brakes on there to turn it into a usable cruiser in the meantime.
hsuBM is offline
