Weird wheel rattle - but only when under pressure.
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
I have a front Mavic Open Pro rim on my Bottecchia that has a very specific rattle that sounds like I lost a nipple in it when I built it (which I don't remember). It's in a very specific spot in the wheel and rattles when you shake it. So, I took the tire and rim tape off with the thought that I would take out a spoke near the rattle and maneuver out whatever was in there. But, when I put the now bare rim on a wheel stand the rattle disappeared. Shook the rim - no rattle. Put the rim tape, tire and tube back on, pumped it up, and the rattle is back.
What's causing this?
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
A loose eyelet is the only thing I can think of.
Quoted: 77 Post(s)
Liked 76 Times
What I've learned after some research is that this is a common issue with Open Pro rims. Apparently, there is a little piece used to align the rims when welded that is held in place with couple of dimples punched into the rim bed (see image). This little piece breaks loose and rattles around between the islets. People fix this by either punching deeper notches in the rim or drilling a small hole and injecting glue or epoxy.
Mavic Open Pro rim at the seem.
Likes For keithdunlop:
Quoted: 503 Post(s)
Liked 436 Times
Quoted: 77 Post(s)
Liked 76 Times
Solution
For those who may have this same issue with Mavic rims, I have solved the rattle -- drilled a small hole in the rim, prepared some epoxy (super glue is too brittle when dry), and used a 1ml syringe to inject the epoxy into the hole. Problem solved.
Interesting. I may look into this for an Ultegra rear wheel that has rattled since the day I bought it. Did you try punching the dimple deeper first, or go directly to the drill-and-glue?
Quoted: 77 Post(s)
Liked 76 Times
I went directly to drill-and-glue. I was suspicious about whether a deeper punch would really hold the loose piece in place, and I was concerned about a new punch becoming a hole. The epoxy solution seemed like a more permanent fix.
