Tire Changes with a Nexus?
Tractorlegs
Bikes: Schwinn Meridian Single-Speed Tricycle
Quoted: 119 Post(s)
Liked 60 Times
Newbie Question: I'm a commuter thinking of going to a bike that has a Nexus 3 speed hub, and was curious how complicated a rear tire repair on the road is? Do ya have to disconnect the cable and re-install and adjust with every puncture, or is there a simple way to do these repairs?
Trikeman
Trikeman
If everything is adjusted correctly to begin with, it's pretty easy. The box on the drive side of the hub comes of with just a set screw. Mind the shifter rod which will be sticking out of the axel. Undo the wheel nuts and the wheel will come right out.
...unless you also have a coaster brake on the hub. Then you'll need to undo the torque arm fixing bolt as well.
Wheel assembly in reverse, when you get to the shifter, it should go on to the same position as it came off, no adsjustment necessary. Realistically, it may get off a bit, but adjustment is easy enough.
Sausage King
Bikes: 2008 Specialized Langster, Kilo WT, 1986 Dahon Classic Folder, 1986 Panasonic Mountain Cat
I recently switched to Schwalbe Marathons. No more punctures, no worries.
Quoted: 5793 Post(s)
Liked 2,584 Times
The only difference is the keyed anti-torque washers which are no big deal, and the cable which does have to be disconnected, which implies re-adjusting then setting as the last step when re-assembling. that also is no big deal, as you'd need to know how anyway.
If the thought of losing 1 minute making the gear adjustment bothers you, there are some quick-connect cable clips used on folding bikes and you can buy a set and fit them to your cable.
FB
Chain-L site
FB
Chain-L site
